Use the Filter dialog box to modify a filter.
Filter Name: The name of the filter. You can type a new name.
Display Options bar: Click to optimize or print the list of filters.
Display all rows: Lists each filter criteria item.
Parameter: Lists the parameter specified for each filter criteria.
Is: Lists the corresponding operator for each filter criteria.
Value: Lists the value for each filter criteria.
Add: Adds a new filter criteria.
Delete: Removes the selected filter criteria.
Cut: Cuts the selected filter criteria so you can move it to another position in the filter.
Copy: Copies the selected filter criteria.
Paste: Pastes a filter criteria.
Arrows: Change the selected filter criteria's position in the filter definition.
Note
- When you type a value for duration or units in the Value field, the value is entered into the database without being converted to hours. So, for example, if you enter 2d, the value stored is 2 days, not 16 hours. If you do not specify a unit when entering a value (for example, you enter 2 rather than 2d), the time unit defaults to the time unit specified in user preferences (User Preferences, Time Units tab).
Tip
- To have the data in your filter criteria reviewed to eliminate redundancy, from the Display Options bar, choose Optimize.
