Use the Function Point Estimation - Data & Transactions dialog box to calculate the Unadjusted Function Point Count (UFP) for the WBS element you are estimating.
Internal Logical File (ILF) - Low/Average/High Complexity: The number of low, average, and high complexity ILFs to be developed under the WBS element you are estimating. You can type a new number for each level of complexity.
External Interface File (EIF) - Low/Average/High Complexity: The number of low, average, and high complexity EIFs to be developed under the WBS element you are estimating. You can type a new number for each level of complexity.
External Input (EI) – Low/Average/High Complexity: The number of low, average, and high complexity EIs to be developed under the WBS element you are estimating. You can type a new number for each level of complexity.
External Output (EO) - Low/Average/High Complexity: The number of low, average, and high complexity EOs to be developed under the WBS element you are estimating. You can type a new number for each level of complexity.
External Inquiry (EQ) - Low/Average/High Complexity: The number of low , average, and high complexity EQs to be developed under the WBS element you are estimating. You can type a new number for each level of complexity.
Clear: Clears all displayed values.
