Estimate Name: The name of the selected estimate.
Method: The method used to perform the selected estimate.
WBS: The code for the WBS element on which the selected estimate was performed.
Resource: The resource code used to filter the WBS element on which the selected estimate was performed, if any.
Total Activities: The total number of activities that qualified for the selected estimate when the estimate was either saved or applied.
Date: The date the selected estimate was saved or last performed.
