General tab - Work Product and Document Details
Title: The selected work product or document's name. You can type a new name.
Version: The selected work product or document's version number. You can type a new number.
Revision Date: The date of the selected work product or document's last update. Click to select a new date.
Document Category: A classification used to organize various document types. For example, you could create document categories for purchase orders, specification documents, or change orders.
Author: The person who created the selected work product or document. You can type a new name.
Reference No.: The selected work product or document's reference or catalog number. You can type a new number.
Status: The selected work product or document's status for the open project. You can select a status.
Deliverable: Mark this checkbox to indicate that the work product or document is a project deliverable.
Note (P6 EPPM Only)
Copyright © 1999, 2023
Last Published Thursday, January 12, 2023
