Group and sort Resource Usage Spreadsheet columns in the Resource Assignments window
If you choose Customize
  1. In the Group By column, double-click the cell, then select the field by which you want to group.
  2. Click Sort, then select the field names you want to sort by for the grouping. Click OK.
  3. To change a group's display color and font, double-click the appropriate Font & Color field.
  4. To group and sort by additional fields, repeat steps 1 and 2.
Tip
Copyright © 1999, 2023
Last Published Thursday, January 12, 2023
