More Detail: Set Resource Analysis Preferences
You can set user preferences to specify which projects to include and which dates and interval you want to use to calculate values for a resource profile.
  1. To display the Resource Analysis tab, click it.
  2. If you chose the Show Remaining Bars As, Total Remaining option, to specify which closed projects you want to include, if any, select an option in the All Projects section.
  3. To specify which dates you want to use to calculate remaining values, in the Time-Distributed Data section, select a date option.
  4. To specify the interval you want to use for live spread data calculations, in the Interval for Time Distributed Resource Calculations field, select an option.
Note
Related Topics
User Preferences dialog box
Copyright © 1999, 2023
Last Published Thursday, January 12, 2023
