The Preview Changes to Project dialog box provides a print function that allows you to print a report that lists the differences between the reflection and the source project.
- In the Projects view, right click on the reflection that you want to print a difference report.
- In the context menu, click Merge Reflection into Source Project. If there are any changes to merge, the system responds by displaying the Preview changes to project dialog box.
- In the Group Changes By, choose how you would like group the changes.
- Expand or collapse the nodes as you would like the information to be displayed in the printout.
- Right click anywhere inside the grid and choose Print Preview from the context menu.
- To set the default printer, paper size, and page orientation, click
- Click  to print the difference report. to print the difference report.
