Replace selected resources with dialog box
Use the Replace selected resources with dialog box to replace the selected resource for an activity.
Display Options bar: Lists options for changing resource columns, filters, grouping and sorting, font, and colors.
Resource ID: Lists the ID of each resource in your organization.
Resource Name: Lists the name of each resource in your organization.
Primary Role: Indicates the primary role assigned to a resource.
Default Units/Time: Lists the default units/time for each resource in your organization.
Select: Applies your selection and closes this dialog box.
Clear: Removes the selected resource from your current activity, or issue.
Related Topics
Introduction to Resource Security
Root Node
Current Project Resources
Copyright © 1999, 2023
Last Published Thursday, January 12, 2023
