Select Calendar To Copy From dialog box
Use the dialog Select Calendar To Copy From box to copy the settings from the selected global, project, or shared resource calendar when creating a new calendar. You can then customize this calendar to meet specific needs.
Display Options bar: Click to change the calendars display.
Calendar Name: Lists calendar names for the current calendar type. To sort the display, click the Calendar Name column label.
Default: If your current display is Global Calendars, indicates the default global calendar. To sort the display, click the Default column label.
Select: Copies the selected calendar.
Copyright © 1999, 2023
Last Published Thursday, January 12, 2023
