Select Code dialog box
Use the Select Code dialog box to select a value to assign to the filter.
Display Options bar: Click to change the display.
Code: Lists the available code value choices.
Code Description: Lists a description of each code value.
Select: Assigns the selected code value to the filter.
Copyright © 1999, 2023
Last Published Thursday, January 12, 2023
