Use the Select Resource Curve To Copy From dialog box to choose an existing resource curve on which to base your new curve.
Display Options bar: Click to change the display or preview how the dialog box will print.
Resource Curve Name: Lists all defined default and global resource curves. Select the curve whose percentages you want to copy for your new resource curve.
Select: Click to copy the selected curve's percentages to your new resource curve.
