Select Shift dialog box
Use the Select Shift dialog box to select a shift for a timescaled layout when you choose a Day/Shift date interval for displaying profile or spreadsheet data.
Display Options bar: Click to change the shifts display.
Search: Type a shift name to display a filtered list of shifts beginning with the letters typed.
Shift Name: Lists each available shift.
Select: Click to select the highlighted shift.
Clear: Click to clear your shift selections.
Copyright © 1999, 2023
Last Published Thursday, January 12, 2023
