Select Tracking Layout dialog box
Use the Select Tracking Layout dialog box to assign a tracking layout to a threshold or an issue. When you assign a tracking layout to a threshold or issue and use the Issue Navigator, you can more quickly open and track the issue using the specified layout.
Display Options bar: Lists option for changing the table font and colors.
Tracking Layout: Lists the names of existing tracking layouts. To sort the display, click the Tracking Layout column label.
Display Type: Lists each tracking layout's display type. To sort the display, click the Display Type column label.
Select: Assigns the selected tracking layout to the selected threshold or issue.
Clear: Removes the selected tracking layout from the selected threshold or issue.
Related Topics
Issue Navigator dialog box
Copyright © 1999, 2023
Last Published Thursday, January 12, 2023
