Specify Project Bar Chart data and display options
  1. Display the layout, then click the Display Options bar (in the right pane) in the Top Layout window and choose Top Layout Options, Bars.
  2. In the Display section, select the category of data to include in the Project Bar Chart, then, in the Show Bars section, select at least one and up to three fields within that category to display as a bar.
  3. To select the color for a bar, click the Color button next to its field.
    If you choose to show more than one bar, mark or clear the Show Stacked checkboxes to indicate whether to show the bars side-by-side or stacked one upon the other.
  4. To preview the Project Bar Chart without closing the Bar Chart dialog box, click Apply.
  5. When you are finished specifying bar options, click OK.
Copyright © 1999, 2023
Last Published Thursday, January 12, 2023
