Using Undo
The Undo command (Edit, Undo) allows you to change information back to its pre-modified value in the Activities, Resources, and Resource Assignments windows. Undo stores each action performed in sequence, beginning with the most recent action performed. The following actions will clear the Undo history in P6 Professional:
When connected to a P6 EPPM database: Opening the Project Portfolios and User Preferences dialog boxes
When connected to a P6 EPPM database: Opening the OBS, User Defined Fields, Resource Codes, and Activity Codes dialog boxes
Notes
Copyright © 1999, 2023
Last Published Thursday, January 12, 2023
