View a profile of resource allocation for a specific project
  1. Open one or more projects for which you want to view a resource profile.
  2. In the Activities window, choose View, Show on Bottom, Resource Usage Profile.
    You can also click the Layout Options bar, then choose Show on Bottom, Resource Usage Profile.
  3. In the right pane of the bottom layout window, click the Display Options bar and make sure Show All Projects is not selected. A check next to Show All Projects indicates that it is selected.
    To view resource allocation by resource, click the Display Options bar in the left pane of the bottom layout window, then choose Select View, By Resource.
    To view resource allocation by role, click the Display Options bar in the left pane of the bottom layout window, then choose Select View, By Role.
Tip
Notes
Copyright © 1999, 2023
Last Published Thursday, January 12, 2023
