Restarting OBI Services
If changes are performed that require the Oracle Business Intelligence (OBI) server to be restarted, use the steps in this section to restart the OBI services.
Complete the following steps to restart the OBI services:
- Log in to the OBI Enterprise Manager URL with an account that is a member of the WebLogic BIAdministrator group (for example, weblogic):
http://<server>:<port>/em
where <server> is the server name or IP address of the server where OBI is installed and running, <port> is the listening port number for OBI, and /em is the default context for OBI Enterprise Manager.
- At the top left of the screen, click the Target Navigation icon to expand the Target Navigation tree. Click the arrow icon next to the leaf node called Business Intelligence to expand this folder.
- With the Business Intelligence leaf node expanded, the biinstance hyperlink should appear below the Business Intelligence leaf node.
- Click the biinstance hyperlink. This will display on the right portion of the screen, the properties and available configuration options for this deployment of OBI.
- Click the Availability tab.
- From the Processes tab, click Restart All to restart all Oracle Business Intelligence processes.
- When prompted to confirm, click Yes.
- When the OBI deployment restarts, click the username at the top right of the screen and select Log Out.
Note: Restarting the OBI services temporarily disables all functionality within OBI without warning. Therefore, Oracle highly recommends that all OBI users save their work prior to restarting.
Last Published Tuesday, December 20, 2022
