Adding the ELOCATION_MAP for MVDEMO
Primavera Analytics uses a base map called E_LOCATION. To add this base map to MVDEMO, complete the following steps:
- Access the MapViewer:
http://<machine>.<domain>:9704/mapviewer
- Select the Admin link.
- Log in to MapViewer using the same administration user you use to log in to the WebLogic and Enterprise Manager console.
- Select Create Tile Layer.
- Select Oracle Maps and click Continue.
- In the Name field, verify the name is elocation_map.
- In the Data Source field, select mvdemo.
- Select Submit.
- Select Manage Tile Layers and verify ELOCATION_MAP with Data Source mvdemo is there.
Last Published Tuesday, December 20, 2022
