Setting Up R
After installing R, set up the R script to connect directly to STARUSER and calculates the predicted outcome for pre-selected projects as follows:
- Create table etl_aa, which contains the project_object_id for the projects that will be calculated.
CREATE TABLE etl_aa(project_object_id number(19));
- Insert the project_object_id for the selected project.
INSERT INTO etl_aa(project_object_id) values (4351);
INSERT INTO etl_aa(project_object_id) values (4352);
INSERT INTO etl_aa(project_object_id) values (4354);
INSERT INTO etl_aa(project_object_id) values (3577);
INSERT INTO etl_aa(project_object_id) values (4049);
INSERT INTO etl_aa(project_object_id) values (4301);
commit;
- Open R Studio.
- Install the following packages: rJava, RJDBC, glm2
install.packages("rJava")
install.packages("RJDBC")
install.packages("glm2")
- Set the working directory to a folder that contains ojdbc6.jar.
- Open the attached R script.
- Change the database connection.
- Run the script.
The results will be in W_UDF_PROJECT_D
Related Topics
Prerequisites for Advanced Analytics Example
Setting Up Oracle R Enterprise (ORE)
Last Published Tuesday, December 20, 2022
