Adding RateManager to Intranet Sites
- Open up IE. Please ensure that you do not have any other windows or tabs open.
- Browse to Tools-> Internet Options. This opens the Internet Options screen.
- Select the Security tab.
To add to Intranet, select Local Intranet and the click Sites.
Click Advanced to view the local intranet sites.
Enter the RateManager URL address. This adds RateManager to the List of Intranet sites.
Close the screen.
- Click OK to close.
Note: If the RateManager URL is not https, you will need to uncheck the https requirement. Close the screen.
