Adding to Trusted Sites
Add the RateManager URL to the Trusted sites listing. This may be helpful if you are accessing RateManager outside of the company network.
  1. Open up IE.  Ensure that you do not have any other windows or tabs open.
  1. Browse to Tools Navigation Path Internet Options. This opens the Internet Options screen.
  1. Select the Security tab.
Selecting Trusted Sites
  1. Select Trusted sites.
  1. Click the Sites.
Adding RateManager to Trusted Sites
  1. Enter the RateManager URL address. This adds RateManager to the List of Intranet sites.
  1. Close the screen.
  1. Click OK to close the Local Intranet sites screen.
Note: If the RateManager URL is not https, you will need to uncheck the https requirement. Close the screen.
Copyright © 2022, Oracle and/or its affiliates. All rights reserved. About Oracle Insurance| Customer Support
