Adobe Acrobat Reader
Adobe Acrobat Reader is required to view select reports in RateManager.
To verify Adobe Acrobat Reader, click Start -> All Programs. Adobe Acrobat Reader should be listed as an available program.
You also may have the Adobe Acrobat Reader icon on your desktop.
Acrobat Reader is available from http://adobe.com/products/reader.html.
No Adobe Acrobat Reader
If you do not have Adobe Acrobat Reader, a message is displayed when you attempt to open the report. The InsbridgeDocument.aspx file can be opened with Adobe Acrobat Reader only.
