Clearing Temp Files
Because Insbridge is a web-based application, you may need to clear out your browser’s temporary file periodically. Keeping the temporary file clear may improve performance by clearing off space from your hard drive.
- Open up a regular browser window, not a RateManager screen. On the top menu bar, click Tools
Internet Options...
- Click Delete… in the Browsing History section of the General Tab, located in the middle section.
Note: To view your temp files or to define your temp file settings, click Setting. This opens an information screen where you can make adjustments.
Delete Files
The Delete Browsing History is displayed.
Temp File Warning Message
- You can select to delete other content in addition to the temp files.
- Removing stored pages forces the browser to get the page. This may result in slower page loading. However, deleting older pages will help to make sure that you are viewing the most current version of a page.
- Check the content you want to delete.
- Click Delete to clear the temp files and other browser history.
- Depending upon the amount of files that need to be deleted, this may take a few minutes. When the temp files have been removed, you will be returned to the previous page.
- Click OK to close the Internet Options box and continue working.
If you do not want to clear your temp file, click Cancel to return to the previous screen.
