RM IIS Login Error
If an error is presented when accessing RM, check the Enable XMLHTTP option on Advances security settings for Internet options may resolve the issue.
- Open up IE. Please ensure that you do not have any other windows or tabs open
- Browse to Tools -> Internet Options. This opens the Internet Options screen.
- Select the Advanced tab
- Scroll down to the Security section.
- Check Enable native XMLHTTP support.
- Click Apply and then OK.
