Logging in to IBFA
The default security setting for a new installation is Custom and requires a login to access.
- IBFA requires a login to access. Click the Show FrameworkAdmin Menu link to display the login.
- Enter the default User ID and password:
User ID: admin
Password: insbridge
- The IBFA home page is displayed.
Troubleshooting
For MS Windows 2012 R2 installations, you may receive an error when accessing IBFA for the first time: The data protection operation was unsuccessful. This may have been caused by not having the user profile for the current thread’s user context, which may be the case when the thread is impersonating.
If this error is presented, locate the Insbridge Application Pool on the server where Insbridge was installed. Administrative Tools -> IIS Manager -> ORACLE_FSGBU_INSBRIDGE, right click, and select Advanced Settings. Change the Load User profile to True.
Updating IBFA Security
- It is recommended that you change the login password immediately. You do not have to change the password.
- On the left side menu, select Security ->Change Password.
- Enter in the default password for the old password and enter in the new password of your choice. Confirm the new password and click Update. A success message is displayed when the admin password is updated. If an error message is displayed, make corrections and try again.
- If you do not want to require a login, you can change the security to None. This changes the default landing page to the IBFA home page and removes any login requirements.
- On the left side menu, select Security.
- Select None for Framework Administration Web Security for no security. The landing page will be updated the IBFA home page and no login will be required.
Note: You also can select to use Windows security. Please see the IBFA user guide for more information on setting up Windows security.
