Oracle Software Delivery Cloud
Prior to installation, please make sure the source machine(s) where Insbridge will be loaded has an unzip utility. An unzip utility for most platforms is available on the Oracle Software Delivery Cloud download page.
Files are downloaded with part numbers as file names. Please make note of the part numbers you have downloaded and the corresponding file name. You may be asked to provide the part numbers or the file name if you contact Oracle Support.
The installation downloads you can select are:
  • Insbridge - Windows – Required for all RateManager installations. The Insbridge installation is for a 64-bit system.
  • Insbridge - WebSphere - eng – Required if you are using WebSphere.
  • Insbridge - WebLogic - eng – Required if you are using WebLogic.
  • Insbridge - TomEE - eng – Required if you are using TomEE.
The Insbridge - Windows folder contents:
  • Databases
    • SQL Server
    • 2012
    • RateManager – IBRM
      • Latin1_General_BIN
        • DATABASE_BACKUP_IBRM_TEMPLATE_CASE_SENSITIVE.bak
      • SQL_Latin1_General_CP1_CI_AS
        • DATABASE_BACKUP_IBRM_TEMPLATE.bak
    • Security – IB_CLIENT
        • DATABASE_BACKUP_IB_CLIENT_TEMPLATE.bak
    • SoftRater – IBSR
        • DATABASE_BACKUP_IBSR_TEMPLATE_CASE_SENSITIVE.bak
        • DATABASE_BACKUP_IBSR_TEMPLATE.bak
    • 2016, 2017, 2019
    • SoftRater – IBSR
    • Oracle BI Publisher
      • OBI_PUBLISHER.exe
    • Oracle Client
      • ODAC121012_x64.zip
    • Oracle Insurance Insbridge Enterprise Rating (x64).exe
    You are required to run the installation file and create the IB_CLIENT database for any new installation.
    The other folders and files may not be needed, depending upon the kind of setup you want. Everything for a Windows only installation is in the 5.6.2-Insbridge-windows folder. If you want to incorporate a Java environment, please download the corresponding SoftRater file. SoftRater downloads are not required if you are running in Windows only.
    Internet Explorer
    IBSS and IBFA are accessed via web browser. Please verify that you are using Internet Explorer 11 or Microsoft Edge *.
    * Run in Compatibility mode
    Copyright © 2022, Oracle and/or its affiliates. All rights reserved. About Oracle Insurance| Customer Support
