Step 1: Insbridge Local User Account Setup
Before starting the installation, create a local user account where the Insbridge Framework is being installed.
To Create a New User:
  1. Select Start -> Administrative Tools -> Computer Management.
  1. Select System Tools -> Local Users and Groups.
  1. Select Users.
  1. Right click and select New User.
  1. Add a new Insbridge user. Enter user name and password information. Uncheck User must change password at next logon. Check User cannot change password and Password never expires.
  1. Click Create.
  1. Close the Add New User screen and select the Insbridge user. Right click and select Properties.
  1. The Insbridge User should be assigned to the local Users group and have the same permissions as the internet guest account.
Ideally, the Insbridge user should be added to the local Administrators group. If the Insbridge user cannot be a part of the local administrators groups, please make sure that the Insbridge user has permissions on the Insbridge Messaging Service and the Insbridge Task Manager Service.
  1. Click OK. Ensure to keep the Insbridge user information close at hand. You will need it for the installation.
Copyright © 2022, Oracle and/or its affiliates. All rights reserved. About Oracle Insurance| Customer Support
