Step 4: Assigning Permissions: Windows Temp Folder
Permissions must be assigned for the Windows Temp Folder for MSMQ and for the application pool default identity. Prior to assigning permissions, please verify the Insbridge application pool identity.
Assigning Permissions in the Windows Temp Directory:
- Find the WINDOWS folder, most likely on your C drive.
- Right click the Windows-> Temp folder.
- Select Properties. The Temp Properties screen opens.
- Select the Security tab.
- Click Edit.
- On the Permissions for Temp screen, select the Insbridge user and click Add. If the Insbridge user is not found, cancel out and return to the Local Users and Groups area in Server Manager and verify the Insbridge user was created.
- Update the permissions. The Insbridge user requires Full Control.
- Click OK to close the Permissions for Temp screen.
- Click OK to close the Temp Properties screen.
