Step 8: Verifying the Component Services
Next, you should verify the component services.
- Click Start -> Server Manager -> Tools->Component Services.
- Expand the Component Services option under console Root.
- Expand Computers-> My Computer -> COM+ Applications.
- Expand each Insbridge COM+ library to make sure there are components listed underneath each compartment.
There should be 3 Insbridge Com+ Applications libraries:
- Insbridge Com+ Administrator 4.5
- Insbridge Com+ SoftRater Engine
- Insbridge Com+ SoftRater Library
Note: If any COM+ library is missing, run the Insbridge install again from the msi file and choose uninstall. Then rerun the IBFA install. Uncheck the RateManager Install. Then check again to see if all the libraries are listed. If they are still not listed, please log a Service Request with Support.
Verify the Identity of the Com+ Applications Libraries
Please note that you should not have to make any changes to any COM+ Application library. The installation will automatically apply the Insbridge user name and password that you created earlier to the necessary libraries.
- Select the Insbridge Com+ Administrator 4.5.
- Right click and select Properties.
- Select the Identity tab.
- Verify that the User is Insbridge. If the user is System Account or is not set to the Insbridge user, change to the Insbridge user set up earlier.
- Repeat for the other com+ services.
- On the Insbridge Com + SoftRater Engine Properties, check the “Leave running when idle” option. This option allows cache to hold for loading. His setting is necessary for Windows SoftRater with cache enabled.
