ESI System Configuration
To use ESI’s IBFA Framework functionality, you need to send down the API key when you do the ESI API call.
When IBFA is installed, a default API key is generated and saved in IBFA. You can find it in IBFA-> Insbridge -> Security -> External API Access. You can disable ESI’s IBFA functionality by setting it to “Disabled”. For security purpose, you may want to change the key once in a while. To change the key, click Generate Key and then click Update. Every key generated is unique.
