Row and Data Attributes
The Row attribute identifies the previously defined target table variable, and criteria. Each Row is defined by:
  • num – the number of the row in the order they should be in inserted into the table.
The Data attribute represents each data element in a cell (intersection of row/column) in the table variable. Each Data is defined by:
  • columnName – the previously defined name of the target column. This field is primarily for informational purposes intended to provide descriptive information for persons creating or reviewing the XML file.
  • columnNum [required] – the numeric value that represents the order that the previously defined table variable, and criteria appear in the table.
  • id [required] – the previously defined universally unique identifier of the target
TYPE
NAME
OCCURANCE
REQUIRED
RESTRICTIONS
Node
TableData
1
No
Node
TableVariable
1
No
Attribute
name
No
String type. Does not allow some special characters.
Attribute
id
Yes
Allows String type
Node
Row
Unbounded
No
Attribute
num
No
Integer Type
Node
Data
Unbounded
No
Attribute
columnName
No
Attribute
columnNum
Yes
Integer Type
Attribute
id
Yes
Allows String Type
XML Example
<TableData>
<TableVariable name="AccountsReceivableLimit" id="47D92217-3E01-40D1-A2B0-A19D875E43CF">
<Row num="1">
<Data columnNum="1" columnName="AccountsReceivableLimit" id="">10000 through 999999999</Data>
<Data columnNum="2" columnName="BusnPrsnlPropLimit" id="">1 through 999999999</Data>
<Data columnNum="3" columnName="FunctlBusnPrsnlPropValtnApply" id="">Yes</Data>
</Row>
<Row num="2">
<Data columnNum="3" columnName="FunctlBusnPrsnlPropValtnApply" id="">No</Data>
</Row>
<Row num="3">
<Data columnNum="2" columnName="BusnPrsnlPropLimit" id="">0</Data>
</Row>
<Row num="4">
<Data columnNum="1" columnName="AccountsReceivableLimit" id="">0</Data>
</Row>
</TableVariable>
</TableData>
Where: … indicates XML contents.
Copyright © 2022, Oracle and/or its affiliates. All rights reserved. About Oracle Insurance| Customer Support
