Depending on the type of product you are working with during origination, the Tools screens enable you to calculate Lease and Vehicle value details.
Tools in the main menu are standalone and information calculated using them can only be viewed. They cannot be copied to the application / contract.
Whereas, Tools that appear as a sub-tab in Underwriting and Funding Tabs, allows you to import the contract values, do necessary calculations and copy the calculated values to the respective Contract / Decision tabs.
The Lease Calculator screen facilitates you to calculate various lease parameters such as Payment, Interest Rate, Residual Percent, Gross Capitalized Cost, Term and Lease Amount. You can define flexible repayment options, repayment/rate schedule and generate amortization schedules.
This screen is similar to the Lease Calculator screen opened from Underwriting or Funding screens; however, calculators opened from Tools master tab are standalone and do not link calculations or lease information to any specific application.
Based on the type of lease calculation method, the following calculation parameters are available in Lease Calculator screen:
Lease Calculation Method |
Calculation Parameters Available |
To Calculate |
Rent Factor |
Calculate Payment |
Base Payment |
Calculate Rate |
Rate |
Calculate Residual Percent |
Residual % |
Calculate Gross Capitalized Cost |
Interest Rate and Amortized |
Calculate Payment |
Base Payment |
Calculate Interest Rate |
Rate |
Calculate Term |
Term |
Calculate Lease Amount |
Note
If you want to clear (or “refresh”) the lease calculator at any time, click Initialize in the Lease Calculator section.
To calculate a lease payment
Field: |
Do this: |
Calc Method |
Select the type of lease calculation method as one of the following:
Note: Based on the above selection, some of the fields in Lease Calculator screen are either enabled or disabled, and if enabled some may be displayed in view only mode with default supported option. The same is detailed in respective fields. |
Contract Dt |
Enter the contract date. |
First Pmt Dt |
Enter the first payment date. Ensure that the payment date is later than the contract date. Note: This field is disabled for ‘Rent Factor’ type of lease calculation method and the value is defaulted from Contract Date. However, for ‘Interest Rate’ type of lease calculation, this field is either editable or displayed in view mode based Rent Collection Method. |
Maturity Dt |
View the maturity date. |
Enter the gross capitalized cost. |
Capitalized Cost Reduction |
Enter the capitalized cost reduction. |
Adjusted Capitalized Cost |
View the adjusted cap cost. |
Residual Value (-) |
View the residual value. |
Residual% |
Enter the residual percentage. |
Depreciation Value (=) |
View the asset depreciation value. |
Rent Charge (+) |
View the rent. |
Rate |
Enter the rate. |
Rent Factor |
View the rent factor. Note: This field is displayed only if the lease calculation method is ‘Rent Factor’. |
Total of Base Pmts (=) |
View the total of payments. |
Term |
Enter the term. |
Base Payment |
View the base payment amount. |
Balloon Pmt Amt |
Specify the balloon payment amount. Note: This field is displayed only if the lease calculation method is ‘Interest Rate’. |
Calculator Options section Note: Except for Rent Collection Method (as Advance or Arrears), the other fields in this section are available only for ‘Interest Rate’ type of lease calculation method and the default values are populated from Setup > Contract screen. Also the Rent Collection Method field is view only for ‘Rent Factor’ calculation method. |
Rent Collection Method |
Select the applicable rent collection method from the drop-down list. If the lease calculation method is selected as Rent Factor, the rent collection method is set to ADVANCE by default. For Interest Rate calculation method, you can either select ADVANCE or ARREARS. In case of ADVANCE, the first payment date is displayed in view only mode and value is automatically populated from contract date. The first bill would be generated on contract date. In case of ARREARS, you can specify the first payment date as future date (but not the contract date) and bill would be generated from first payment date. |
Billing Cycle |
Select the billing cycle frequency from the drop-down list. System displays the applicable billing cycle by default based on the product and the calculation method defined at Setup > Products screen. The editable nature of billing cycle is controlled by the system parameter UIX_BILL_CYCLE_ALLOWED_IND. System supports ‘Biennial’ (once every 2 years) and Triennial (once every 3 years) type of billing cycles. Based on BILL_CYCLE_CD lookup, the billing cycle ‘frequency’ can be defined. During ‘Term’ calculation, the 'Rate' field is always considered as per Year only. System displays an error to refine the input data if the calculation for Biennial term goes beyond 15 years and Triennial term goes beyond 10 years. For additional considerations of Biennial and Triennial term calculations (if any), refer to product release notes available at OTN library. |
Balloon Method |
If the lease calculation method is selected as Interest Rate, then the balloon payment method for accounts funded using this instrument is ‘N + 1 PMTS’ by default. Amortization happens based on N+1 payments. |
Accrual Base Method |
Select the accrual method used to calculate interest accrual for this instrument from the drop-down list. |
Time Counting Method |
Select the time counting method used to calculate interest accrual for this instrument from the drop-down list. |
Installment Method |
For ‘Interest Rate’ type of lease calculation method, the installment method by default is EQUATED PAYMENTS where-in, the installment amount is same for all billing cycle. |
Bill Method |
Select the billing method for accounts funded using this instrument from the drop-down list. |
Accrual Start Dt Basis |
Select to define the start date from when the interest accrual is to be calculated for this instrument from the drop-down list. Note: If you select the Effective Date, then the interest is calculated from the Contract date + Start Days (indicated below). If you select the Payment Date, then the interest is calculated based on (first payment date + Start Days (indicated below) minus one billing cycle). |
Accrual Start Days |
Specify the number of grace days after which the interest accrual is to be calculated. Ensure that the number of grace days is less than first payment date. |
First Period section |
Calendar Days |
View the number of calendar days between contract date and the first payment date. The calendar days will differ based on the calendar method selected. |
Interest |
View the profit accrued for the calendar days. |
If the calculation involves flexible repayment options, you can include the same through the following options:
Note
This section is not available for ‘Rent Factor’ type of lease calculation method.
Option |
Description |
Flexible Repayment Allowed |
Select the check box to include a flexible repayment schedule in calculation. On selection, the ‘Payment Change Schedule’ and ‘Rate Schedule’ sections are displayed in addition to ‘Repayment Schedule’ and ‘Amortization Schedule’ sections. |
Type |
Select any of the following repayment type that you want to use from the drop-down list.
will enable the months that can be selected for skipping payments, but not the maturity month and applicable only for MONTHLY PAYMENTS AND ARREARS METHOD. |
Field: |
Do this: |
Seq |
Specify the sequence number of the repayment schedule. |
Pmt Amt |
Specify the repayment amount borrower agreed to pay during the schedule. |
# of Payments |
Specify the number of payments borrower agreed to pay for stated repayment amount during this schedule. |
Generated |
View if the repayment schedule is generated. |
Field: |
Do this: |
Seq |
Specify the sequence number in which the repayment is calculated. It prioritizes the calculation. |
Option Type |
Select one of the following repayment option type: Step up step down bullet |
Frequency |
Select the frequency of payment. The default value is Term. |
Period |
Specify the loan period. |
# of Adj. |
Specify the number of times the step up, step down or bullet needs to happen. |
Value |
Specify the value. For step down, value ranges from 1 to 99 For step up, value ranges from 1 to 990 For bullet, value ranges from 1 to 99999999 |
Field: |
Do this: |
Seq |
Specify the sequence number of the rate schedule. |
Rate |
Start Dt |
Specify the date on which the borrower agreed to make the first payment. |
When you fund the lease application, system copies repayment schedule information to the lease account on Customer Service screen where it appears in the Repayment Schedule section.
You can use the calculated payment data to derive the Amortization Schedule. Click Amortize in the ‘Amortization Schedule’ section. System generates an amortized schedule with the calculated data and based on the ‘Rent Collection Method’ the first bill is generated with the following headers:
Field: |
View this: |
Seq |
Payment number. |
Pmt Dt |
Payment date. |
Pmt Amt |
Payment amount. |
Principal Amt |
Component of the payment amount allocated towards reduction of the principal balance. |
Interest Amt |
Component of the payment amount allocated towards reduction of the interest balance. |
Balance Amt |
Remaining principal balance. |
You can click Print Report to extract a PDF version of the generated amortized schedule.
You can generate a summarised report using the calculated lease details in the format of quote with lease details and charges.
In the Lease Calculator screen, click Print Quote. The system generates a PDF document to the default downloads repository consisting of the following information in the respective headers:
Lease Details
The Lease Details section consists of Contract Start Date, Contract End Date, First Payment Date, Total Lease Term, and Rate.
Payment/Finance Charge
The Payment/Finance Charge section consists of gross capitalized cost, adjusted capitalized cost, percentage of residual value, rent factor, base payment, and total of base payments including rental charges.
Depending on the screen from where you have accessed the tools sub tab, you can copy the calculated values to either Contract or Decision tab. If you are in Underwriting stage, you can copy the values to decision tab. Similarly during Funding stage, you can copy the values to contract tab.
Click Copy to Contract/Decision. The calculated details are copied to the respective fields in Contract/Decision tab.
The Vehicle Evaluator screen allows you to calculate the value of a vehicle. You can use the Vehicle Evaluator screen to calculate the value of either a vehicle you are entering as the new collateral or vehicle currently listed as the application’s collateral.
The Vehicle Evaluator screen can be cleared or refreshed at any time by clicking Clear.
To calculate a vehicle value
-or-
Complete the fields in the Vehicle section.
Field: |
View this: |
Year |
The asset year. |
Make |
The asset make. |
Model |
The asset model. |
Body |
The asset body style. |
Usage |
The asset usage or current mileage. |
Weight |
The asset weight. |
In the Valuation (Total Value) block, view the returned information:
Field: |
View this: |
MSRP |
Manufacturer’s suggested retail price value of the asset. |
Total |
Total value of the asset. |
Usage |
Adjusted usage value of the asset. |
In the Base and Attribute Value section, view the returned information:
Field: |
View this: |
Base Retail |
Total retail value of the asset. |
Base Loan |
Base loan value of the asset. |
Base Trade |
Base trade value of the asset. |
Retail |
Retail value of the asset attributes. |
Loan |
Loan value of the asset attributes. |
Trade |
Base trade value of the asset attributes. |
In the Attributes section, view the following information:
Field: |
View this: |
Attribute |
Asset attribute. |
Retail |
Attribute retail value. |
Loan |
Attribute loan value. |
Trade |
Attribute trade value. |
Standard |
Standard indicator. If selected, indicates that the attribute is a standard. |
Package Incl |
If selected, indicates that the attribute is inclusive. |
Selected |
If selected, indicates that the attribute is selected. |
If you want to re-calculate the values using other data in Total Value and Base and Attribute Value section, do the following:
The system updates the values in Total Value and Base and Attribute Value sections.
If you choose, use Attributes section to select or clear the Selected box for attributes of the vehicle. This automatically updates the values in Total Value and Base and Attribute Value sections. (Note: Attribute amounts within brackets reduce the amount in Totals field in the Total Value section.)
To copy the calculated value to the Collateral link
You can copy the calculated value to Collateral link only if you have accessed the tools tab either from Underwriting or Funding Tab. Accessing Tools from the main menu does not support this option.
The system uses calculations on the Vehicle Evaluator screen to complete Valuation sub screen on Collateral link. Any pre-existing collateral is no longer the primary collateral.
The Depreciation Calculator screen facilitates you to simulate depreciation calculation of an asset based on asset acquisition cost and using specific depreciation method, frequency and term. Further, you can view the depreciation amortization schedule based on calculation.
Depreciation Calculator is a standalone tab and information calculated here can only be viewed. They cannot be copied to the application / contract.
If you want to clear (or “refresh”) the Depreciation Calculator at any time, click ‘Initialize’ in the Parameters section.
To calculate an asset depreciation
Field: |
Do this: |
Depreciation Method |
Select the asset depreciation method to be used for calculation as one of the following from the drop-down list. - FLAT RATE: This method is used to depreciate the asset over a fixed time using a fixed rate. This method of calculation is similar to Written Down Value Method (Diminishing Balance Method / Reducing Installment Method). - LIFE BASED: This method is used to depreciate the asset over a fixed time using the specified rates. This method of calculation is similar to Straight Line Method (Original Cost Method / Fixed Installment Method). On selecting this option, ‘Depreciation Rate Schedule’ sub tab is enabled to define depreciation rates slab. |
Acquisition Cost |
Specify the asset acquisition cost. |
Acquisition Dt |
By default, current system date is selected as the asset acquisition date. You can modify the same using the adjoining calendar. Based on this date depreciation accounting is done and is calculated till the term specified. |
Term |
Specify the total term for depreciation calculation. |
Depreciation Percentage |
Specify the percentage of depreciation to be calculated during the above term. This option is not available for life based depreciation method. |
Depreciation Convention |
Select the frequency at which the asset depreciation is to be calculated from the drop-down list. |
Total Depreciation Amt |
The total depreciation amount is auto calculated and displayed on clicking Calculate button. |
