17. Batch Transactions
17.1 Introduction
This chapter discusses about the various batch transactions handled in the application. We can categorize them in to the following:
17.2 Advances
You can enter multiple advances to the account for the draws made by customers. Advances can be entered either by manual entry or batch upload.
Manual Entry
This screen uses the same concepts and has similar features as the Payment Entry screen. An advance can be paid to one or more payees. The payee can be a standard payee that can be selected from a predefined list of values or a non standard payee. For non standard payees, you must enter the details of the remittance.
Oracle Financial Services Lending and Leasing creates entries for the posted advances on the AP Transaction screen. These entries can be used to process the remittances.
Batch Upload
With the advance load process, a batch of advances can be loaded into Oracle Financial Services Lending and Leasing (similar to lockbox processing).
Using the Advance Entry screen, you can enter and view a batch of advance transactions. You can then complete the following tasks:
17.2.1 Advance Entry Tab
The Advance Entry tab enables you to view either all batches or only open batches. You can choose which batch you want to view using the View Options section. Viewing all batches enables you to locate batches with a status of open, reverse, hold, error, or posted.
To view open batches
  1. On the Oracle Financial Services Lending and Leasing Application home screen, click the Servicing > Servicing > Batch Transaction > Advances > Advance Entry.
  2. In the View Options section, click Open Batch Only. In the Batch section, the system displays all batches with a status of open that have not been posted.
To view all batches
  2. In the View Options section, click All Batches. In the Batch section, the system displays all batches regardless of the status.
If a batch contains a payment with an error status, the Error Reason field displays the cause.
17.2.1.1 Entering and Posting Advances
The Advance Entry screen enables you to manually post batches of advances. A batch can consist of one or more accounts.
To enter and post a batch for advance transactions
  1. On the Oracle Financial Services Lending and Leasing A home screen, click the Servicing > Servicing > Batch Transaction > Advances > Advance Entry.
  2. Perform any of the Basic Operations mentioned in Navigation chapter.
A brief description of the fields is given below:
Field:
Do this:
Company
Select the portfolio company.
Branch
Select the branch.
Date
Specify the batch date.
Batch Type
Select the batch type.
Total #
Specify the total number of advances in the batch.
Total Amt
Specify the total amount of advances in the batch.
Batch #
View the batch number (system generated).
Batch Sta­tus
View the batch status.
Ctrl Total #
View the total number of advances in the batch (actual).
Ctrl Total Amt
View the total amount of advances in the batch (actual).
  1. Perform any of the Basic Actions mentioned in Navigation chapter.
  2. In the Advances section, perform any of the Basic Operations mentioned in Navigation chapter.
Field:
Do this:
Account #
Select the account number.
Account #: Title
View the account title.
Date
Specify the advance effective date.
Currency
View the currency associated with the transaction.
Amount
View the advance amount.
Promotion
Select the promotion associated with advance.
Mode
Select the advance mode.
Reason
Select the reason for the advance.
Status
View the advance status.
Error Reason
View the reason for error.
Reference
Specify any reference information (such as check number).
  2. In the Advance Allocations section, you can record the advance payments (usually called ‘Tranche’ - slice or portion) of total disbursement. Perform any of the Basic Operations mentioned in Navigation chapter.
Field:
Do this:
Validate Payee
(Optional) Select this check box to validate and list all the registered third-party payee maintained in the system.
If selected, the ‘Name’ field below is rendered as a drop-down list. Else, the same is a free text field to specify the Payee Name.
Amount
Specify the advance amount to be paid to this payee.
Type
Select the payee type as CUSTOMER, BUSINESS, or THIRD PARTY from the drop-down list. Based n selection, system auto populates the Payee # and Name of Customer, Business or Vendor details respec­tively.
Payee #
Based on ‘Validate Payee’ option selected, you can either select the payee number from the drop-down list or specify the payee number.
Name
Specify the payee name.
Pmt Mode
Select the payee payment mode from the drop-down list.
Country
Select the country where the payee is located from the drop-down list.
Address Line 1
Specify the address line 1 for the payee.
Zip
Select the zip code where the payee is located from the drop-down list.
City
Specify the city where the payee is located.
State
Select the state where the payee is located.
Bank Name
Specify the payee ACH bank name.
Routing #
Specify the payee ACH bank routing number.
ACH Account
Select the payee ACH bank account type from the drop-down list.
ACH Account #
Specify the payee ACH bank account number.
BIC
Select the Business Identifier Code from the drop-down list. The list displays the BIC codes defined in the system.
IBAN
Specify the IBAN (International Bank Account Number). IBAN is used for identifying bank accounts across national borders with a minimal of risk of propagating transcription errors.
Ensure that value entered satisfies the check-digit validation based on modulo 97. On save, system automatically validates the IBAN number length based on country code, characters, white spaces, and check­sum. Validation is also done during posting non-monetary transaction (ACH Maintenance).
You can maintain the IBAN length and other details required as per the country code in the user defined table (Setup > Administration > System > User Defined Tables).
Note: IBAN for 'NL' country code (IBAN_FORMAT_NL) is defined by default with length of IBAN as 18.
Comment
Specify a comments for this advance allocation.
Currency
Specify the currency for disbursement.
The system updates the display only Total # and Total Amt fields in Batch section to record the contents of Advance section.
When you want to post a batch transaction on Advance Entry screen, ensure that contents of the display only Total # and Total Amt fields match with contents of the required Total # and Total Amt fields in Advance group section.
  1. In the Action section, click Post.
The system changes batch status from OPEN to PROCESSING and submits batch to the job service. After the batch has been processed, system changes the batch status to POSTED or ERROR.
The posted advances can be viewed on the Customer Service screen’s Transaction screen. The system creates entries for the posted advances on AP Transaction screen. These entries can be used to process the remittances.
17.2.1.2 Holding a Batch of Payment Transactions
Only the batches with the status of Open can be put on hold.
To hold the batch of payments transactions
  2. On the Advance Entry screen, click Open Batches Only in the View Options section. Details regarding the selected batch appear in the Advances section.
  3. Use the Batch section to search for and select the batch you want to hold.
  4. In the Action section, click Hold/Open.
The system changes the batch status from Open to Hold.
17.2.1.3 Opening or Removing Hold on the Batch of Payment Transactions
Only the batches with a status of Hold can be opened.
To open (or remove hold) on the batch of payments transactions
  1. On the Oracle Financial Services Lending and Leasing Application home screen, click the Servicing > Servicing > Batch Transaction > Advances > Advance Entry tab.
  2. On the Advance Entry screen, click All Batches in the View Options section. Details regarding the selected batch appear in the Advances section.
  3. Use the Batch section to search for and select the batch with the status of hold you want to open.
  4. In the Action section, click Hold/Open. The system changes the batch status from Hold to Open.
17.2.1.4 Reversing a Batch of Payment Transactions
Following are the pre-conditions while reversing a Batch of Payment Transactions:
To reverse the batch of payment transactions
Batches can be reversed in case of problems with the batch. This will reverse all advances that have been posted.
  3. Use the Batch section to search for and select the batch with posted status you want to reverse.
  4. In the Action section, click Reverse.
The system changes batch status from posted to Processing and submits batch to the job service. After the batch has been processed, the system changes batch status to Reverse.
You can verify the reversal either using Transaction screen on Customer Service screen for each account in the batch, or by running payment history report.
17.2.2 Advance Maintenance Tab
The Advance Maintenance tab on the Advances screen enables you to perform maintenance functions on individual advances that have been posted. The common functions are as follows:
Function:
Purpose:
Modify
enables you to modify advance attributes such as amount, account number, and date.
Reverse
enables you to reverse the advance from the account completely.
In all cases, the system performs ’true backdating’ to post the transaction based upon transaction date. Interest recalculations are automatic and all necessary transactions can be sent to the general ledger for automatic reconciliation.
Suspended advances
In case of advances that are not posted to accounts due to issues such as incorrect account condition, the advances are posted to suspense. You must process these advances using the work queue for suspense advances. This would typically involve identifying the correct amount or correcting problems with the account before attempting to re-post the advance. In this case, the advance is moved out of the suspense account and posted to the specified account.
To view advances
  1. On the Oracle Financial Services Lending and Leasing Application home screen, click the Servicing > Servicing > Batch Transaction > Advances > Advance Maintenance tab.
  2. In the View Options section, select which advance you want to view:
    Choose:
    View this:
    Posted
    Posted advances.
    Suspense
    Suspended advances. In cases of advances that have been posted to suspense, the Suspense work queue can be used to process them (similar to suspense payments).
    All
    All advances.
The system displays the selected payments in the Advances section.
  1. Perform any of the Basic Operations mentioned in Navigation chapter.
A brief description of the fields are given below:
Field:
View this:
Advance Id
View the system-generated Advance Id gener­ated while posting an advance transaction onto an account. The Advance Id is generated during any of the following AP transactions:
- For advances to account generated in OFSLL
- For transactions posted from third party sys­tem to OFSLL through ‘AdvanceDisbursement’ and ‘Advance Entry’ RESTful web service to maintain advance balance on account and cre­ate Payable Requisition (AP Txn).
Account #
Account number.
Title
Account title.
Loan Currency
Select the Loan currency
Txn Date
Advance effective date.
Txn Amount
Advance amount.
Mode
Advance mode.
Reason
Advance reason.
Reference
Reference information for advance.
Status
Advance status.
Company
Portfolio company.
Branch
Portfolio branch.
Batch #
Batch number.
Batch Type
Batch type.
Date
Displays batch date.
17.2.2.1 Modifying/Correcting Advance Transactions
In some cases, an advance may be valid, but how it was posted was incorrect; for example, advance was posted to the wrong account, with the wrong date, or with incorrect spread data. The Advance Maintenance screen enables you to correct such errors.
To modify/correct an individual advance transaction
  1. On the Oracle Financial Services Lending and Leasing Application home screen, click the Servicing > Servicing > Batch Transaction > Advances > Advance Maintenance.
  2. In the View Options section, click Posted.
  3. In the Advances section, select the advance you want to modify and click Edit.
  4. In the Action section, click Modify.
  5. In the Details section, update the fields with information about the advance you want to modify.
    Field:
    Do this:
    Account #: Title
    Select account number.
    Loan Currency
    Select the Loan currency.
    Amount
    Enter advance amount.
    Txn Dt
    Enter advance effective date.
    Reason
    Select the reason for error.
  6. Click Save And Return.
The system modifies the original advance and posts the new advance.
17.2.2.2 Reversing Advance Transactions
To reverse an individual advance transaction
  3. In the Advances section, select the advance you want to reverse and click Edit.
  5. In the Details section, complete the Reason field (if you choose). You need not have to update any other fields when reversing a transaction.
The system reverses the original advance.
The reversed advance can be viewed when you load the account on Customer Service screen from Customer Service screen’s Transaction screen.
17.2.3 Search Tab
A Search link is available on the Advances screen to help locate information such as an account’s number, company and branch. This is information that is used on the Advance Entry and Advance Maintenance screens.
To search for an account
  1. On the Oracle Financial Services Lending and Leasing Application home screen, click the Servicing > Servicing > Batch Transaction > Advances > Search tab.
  2. In the Search Criteria section, use Comparison Operator and Value columns to enter search criteria you want to use to locate an account.
  3. Click Search.
System displays result of the search in Results section at the bottom of the screen.
You can click Reset Criteria at any time to clear Comparison Operator and Values columns on the Search Criteria section.
17.3 Payments
Oracle Financial Services Lending and Leasing enables you to post payment transactions to accounts in a batch mode, either by manual entry or by using data files. These transactions can be posted in real-time or in batch mode.
This chapter explains how to use the Payments screen to complete the following tasks:
Payments can be entered in Oracle Financial Services Lending and Leasing in a variety of ways:
The manual entry option is useful in a low volume or a branch scenario when customers make payments in person or through the mail. The lockbox and ACH options allow for processing payments electronically without manual input.
The Payments screen in Oracle Financial Services Lending and Leasing consists of the following tabs and the functionality of each tab is explained in detail below:
17.3.1 Lockbox Payments
Oracle Financial Services Lending and Leasing can accept payments from lockboxes in the NACHA format. The NACHA format is an industry standard that can be used to post multiple batches of payments at one time. The Lockbox Load Batch Process can be configured to run at any time of the day and at multiple times if needed. All payments from the lockbox file are loaded into the system as batches. Any errors identified by the system during the load process are logged.
17.3.2 ACH Payments
Oracle Financial Services Lending and Leasing enables you to post directly from the ACH file that has been created for customer payments. This is controlled by the ACA_PAYMENT_AUTO_LOAD system parameter. If the parameter is set to Y, the system automatically creates payment batches for the payments in ACH file and posts them on the day of payment.
Batch NSF Processing
Oracle Financial Services Lending and Leasing provides the upload of the rejected ACH ’Payment Request Files’ sent by financial institution/lender to allow for improved NSF processing for all returned payments. This is done using a ‘Batch Mode’ process.
Oracle Financial Services Lending and Leasing supports upload of payment files through lockbox uploads. In addition to the Payment file, system also provides the upload of Payment Return files through lockbox uploads. The system provides an upload of the ‘Entry Detail Addenda Record’ in NSF Notification file received from the client’s financial institution. This record pertains to payment returns.
17.3.3 Bulk Upload of Payment Transactions
OFSLL supports bulk upload of payment transactions into the system in addition to the option of manually creating the records in the Payment Entry tab.
During the bulk upload process, a set of payment transactions can be grouped together into a single file, in a specific file format and uploaded into the system using the Process File interface. The upload file is then processed through a batch and after successful validation, individual records are created automatically in ‘Payment Entry’ tab with appropriate status.
While creating the upload file, it is necessary to maintain the details in specific format and to ensure that all the payment transactions are uploaded correctly without any issues during validation. The bulk upload file format supports One Header and Multiple Detail records and the currency defined in the header is applicable for all the records. Example of header record is indicated in the following table:
Company
Currency
Mode
Reason
Total #
Total Amt
Action
US01
USD
CASH
PAYMENT MANUAL
3
3000
POST / REVERSE / VOID
In the header record, all the fields are mandatory except ‘Reason’. Each field information is validated with the data maintained in the system and in case of any discrepancies, the entire payment upload batch is rejected. For example, when the specified company code or currency code is not maintained, or if ‘Total Amount’ contains a non numeric data, the entire batch is rejected from processing.
The details of each transaction need to be maintained in the following format as indicated with system defined validations:
Field Name
Expected Values
Mandatory (Y/N)
Validation
Account #
Account Number
Y
Mismatch in Account # is posted as ‘Suspense’ (Account Number as ‘0’) against ‘Company’ specified in header.
For suspense account, system defaults the spread where Status, Condition, and State = ‘ALL’.
Pmt Date
Payment Date
Y
Payment date cannot be beyond the GL date.
Pmt Amount
Payment Amount
Y
Payment Amount should not contain non-numeric or negative amount.
Spread
Spread
(Spread Code)
N
Spread Code has to be valid.
If left blank, default spread is applicable based on spread matrix or value defined in contract.
Reference
Free Text
N
NA
Based on the value defined in CLOB system parameter ‘CMN_FILE_PROCESS_TO_LOB’, the file is either processed through Process Files interface (if value is ‘Y’) or Database Files system (if value is ‘N’). For database file upload, the payment transactions file has to be placed in ‘IBU’ directory for upload and for process files interface, the file is shared in common access folder and uploaded by accessing it from the ‘Incoming Process File’ tab. For more information, refer to DashBoard > Process Files section.
On initiating the file upload in ‘Process Files’ screen, new batch job ‘IPUPRC_BJ_100_01’, under Batch Job Sets ‘SET-IFP’ is created to process the same. Each batch can process specific number of records as per the ‘Parameter Value’ defined in the system parameter ‘LBX_TXN_GROUPING_CNT’ (BATCH SIZE OF PAYMENT UPLOAD RECORDS). Note that a batch can get rejected from processing if the total number of records exceed the parameter value or the ‘Total #’ specified in the file header.
While uploading the batch, ensure that the following lookup details are maintained in Lookup Code ‘PAYMENT_UPLOAD’ with Sub Code as ‘PAY’ in Lookup Type ‘GROUP_SUB_TYPE_CD’.
Once the batch is successfully executed after validation, system identifies the 'Header' and 'Detail' records in payment file and creates individual records with the same batch name in 'Payments' and 'Payment Txns' sections automatically. The status of the Batch is updated depending on the status defined in system parameter ‘PMT_BATCH_POSTING’ (PAYMENT BATCH POSTING PREFERENCE) as OPEN or HOLD or POSTED.
17.3.3.1 Bulk Reversal and Void of Payment Transactions
OFSLL also supports bulk reversal and void of payment transactions through the same process file upload interface. Here payment reversals/voiding can be done to individual accounts, or at customer/business level to all linked accounts or at master account level to all its associated accounts by providing appropriate reference.
During bulk reversal/void process, a set of payment transactions can be grouped together into a single file, in a specific file format and uploaded into the system using the Process File interface. The file is then processed through respective batch jobs IPUPRC_BJ_100_01 (for accounts), IPCPRC_BJ_100_01 (customer / business) after successful validation, individual records are posted on to respective accounts indicating Void and Reversals.
While reversing/voiding payments in bulk, it is necessary to maintain the details in specific format and to ensure that all the payment transactions are added correctly without any issues during validation. The bulk reversal/void file format supports One Header and Multiple Detail records and the company defined in the header is applicable for all the records. Example of header record is indicated in the following table:
Company
Total #
Total Amt
Action
US01
3
3000
In the header record, all the fields are mandatory except ‘Reason’. Each field information is validated with the data maintained in the system and in case of any discrepancies, the entire payment reversal batch is rejected.
The details of each reversal transaction need to be maintained in the following format as indicated with system defined validations:
Customer # /Business #
Customer Type
Master Account #
Payment Hierarchy
Currency
Pmt Date
Amount
Reference
Mode
Reason
1001
C
Hier­archy 1
USD
2/2/2018
1000
23457
CASH
PAY­MENT MAN­UAL
1001
C
Hier­archy 2
USD
2/2/2018
1000
23458
CASH
PAY­MENT MAN­UAL
1001
C
Hier­archy 3
USD
2/2/2018
1000
23456
CASH
PAY­MENT MAN­UAL
For more information, refer to above ‘Bulk Upload of Payment Transactions’ section.
17.3.4 Manual Entry
The Payment Entry screen enables you to manually post batches of payments. You can enter payment details such as payment date, payment reason and mode, and payment amount for each batch. A batch is comprised of a number of payments. Oracle Financial Services Lending and Leasing provides audit controls to audit the actual payments entered.
Each batch needs to be associated with a company and one or all branches within the company. The system verifies the actual number of payments against the total of payment amounts you enter.
17.3.5 Customer Based Payments
The Payment Entry screen enables you to manually post customer based payments to a single customer account or multiple accounts linked to same customer. System accepts such type of payments based on Customer / Business # and allocates to the accounts linked to the customer. The allocation is based on the payment hierarchy which contains the account selection criteria and sorting order defined in setup (Setup > Administration > User > Payment Hierarchy screen).
To facilitate customer based payments, the system parameter UIX_CUSTOMER_BASED_PMT_IND has to be set to ‘Y’ which enables ‘Customer / Business #’ and ‘Payment Hierarchy’ fields along with ‘Populate Accounts’ button in ‘Payment Entry’ screen.
Customer based payments can be entered into the system by manually creating in Payment Entry screen, bulk upload through file upload process and through ‘Customer based Payments’ web services.
In the Payment Entry screen, when payment has to be allocated to multiple linked accounts of the customer, select Multi Account check box, select Customer / Business #, Payment Hierarchy details and click ‘Populate Accounts’ button. System populates the accounts based on the account selection criteria defined in Payment Hierarchy setup screen.
Following validations are considered while filtering the accounts for payment allocation:
However note that, based on payment and outstanding dues on the accounts, sometimes the entire payment allocation may be consumed by first few accounts with higher dues even if there are other eligible accounts for selected Customer/Business #.
Consider the following example where payment allocation is to be done to accounts based on current dues. if there are 3 accounts linked to a customer and a payment of $100 is to be allocated to eligible accounts, then system populates the accounts in the following ways:
In case the Payment Hierarchy is selected as ‘Equal Amount’, system allocates the total amount into equal portions based on filtered accounts. The payment allocation is done even though there is no due on the accounts. For information on different types of payment allocation supported, refer to Setup > Administration > Users > Payment Hierarchy section.
Customer Based Payments File Upload
Customer based payments can be processed in bulk through file upload process. To do so, the payment file need to contain required field details in the Header and Detail block as indicated below:
Header Record need to contain the following:
Company
Total
Total Amount
Company Code
Total # of 'Detail Records'
Total Amount i.e. sum of Details Records
Each field information is validated with the data maintained in the system and in case of any discrepancies, the entire payment upload batch is rejected. For example, when the specified company code is not maintained, or if ‘Total Amount’ contains a non numeric data, the entire batch is rejected from processing.
Field Name
Expected Values
Mandatory (Y/N)
Validation
Customer / Busi­ness #
Cus­tomer# / Business #
Y
Validates for mismatch in Customer# / Business #
Payment Hierarchy
Payment Hierarchy value
N
Payment Hierarchy is validated with setup. If the value is not matching the record is rejected and placed in bad file.
If Payment Hierarchy is not provided system takes default value from Customer Details tab.
If the Payment Hierarchy at customer Details is disabled, record is moved to bad file with error message ‘Provided Payment Hierarchy is disa­bled’.
If the Payment Hierarchy at customer Details is not provided, system takes the value from sys­tem parameter.
If system parameter is disabled, the default value ‘Equal Amount’ is considered.
Currency
Currency Code
Y
Validates Currency code/exchange rate in OFSLL
Pmt Date
Pmt Date
Y
Cannot be a future date. Else, added to bad records.
Pmt Amount
Payment Amount
Y
Require numeric date to be provided.
Reference
Free text
N
Reference Number
Mode
Mode Code
Y
Validates for Mode code.
Reason
Reason Code
N
Validates for 'Reason' code in OFSLL
For more details on processing, refer to ‘Bulk Upload of Payment Transactions’ section.
Customer Based Payments Web Service
Customer based payments can also be added into the system through web services. To do so, the request/response files need to be updated with above field details (Details block information) and posted. System validates the field details and either displays in Payment Maintenance screen or rejects in case of a mismatch.
For details on web service used for payment posting, refer to ‘Web Service’ documentation on OTN library.
17.3.6 Payment Posting at Master Account Level
The Payment Entry screen enables you to post payments at Master Account level and its associated accounts that belongs to the same Customer / Business.
The payment allocation is based on the payment hierarchy which contains the account selection criteria and sorting order defined in setup (Setup > Administration > User > Payment Hierarchy screen).
Payment posting in the Payment Entry screen is processed based on values selected for Customer # and Master Account # as indicated below:
17.3.7 Payments Entry Tab
Using the Payment Entry screen, you can do the following for payment transactions:
17.3.7.1 Viewing Batches
The Payment Entry screen enables you to select the batch you want to view. Based on your selection, the batches are displayed. You can select one of the following:
View Options
Descriptions
Open Batches Only
Displays batches with the status Open
All Batches
Displays all the batches regardless of status. i.e. open, reverse, hold, error, or posted.
To view open payment batches
  1. On the Oracle Financial Services Lending and Leasing Application home screen, click Servicing > Servicing > Batch Transaction > Payments > Payment Entry tab.
  2. On the Payment Entry screen’s View Options section, click Open Batch Only. In the Batch section, the system displays all batches with a status open that have not been posted.
To view all payment batches
On the Payment Entry screen’s View Options section, click All Batches.
In the Batch section, The system displays all payment batches, regardless of status. Details regarding the selected batch appear in the Payments section.
In the Batch section, click View to view batch details. If a batch contains a payment with an error status, Error Reason field under Payment Txns section displays the cause.
In the Payment Entry tab. you can further sort the view of payment transactions based on ‘All Payments’ and ‘View Last’ options. These options allow you to narrow the range of payment transactions that Oracle Financial Services Lending and Leasing displays.
In ‘All Payments’ section, you can either select ‘Payments’ to view only the posted payment transactions or ‘Reverse/NSF’ to view only the transactions which are reversed or posted with Non Sufficient Funds in the account.
In ‘View Last’ section, you can view the payment transactions based on elapsed days.
Choose:
Oracle Financial Services Lending and Leasing displays:
1 Day
All the transactions in last one day.
1 Week
All the transactions in last one week.
1 Month
All the transactions in last one month.
By Date
Specify a date range (within 3 months) in ‘Start Dt’ and ‘End Dt’ fields using the adjoining calendar and click ‘Search’.
17.3.7.2 Entering and Posting Batches
The Payment Entry screen enables you to manually post batches of payments. A batch can consist of one or more payments.
To enter and post a batch for a payment transaction
  1. On the Oracle Financial Services Lending and Leasing Application home screen, click Servicing > Servicing > Batch Transaction > Payments > Payment Entry.
Field:
Do this:
Company
Branch
Select the portfolio branch.
Batch #
View the batch number (system generated). The batch number format is PAY-YYYY-JJJ-SSSS, where YYYY is the year, JJJ is the Julian date, and SSSS is a sequential number. The system generates a new sequence for every different date, so the first batch of each day starts with SSSS = 0001.
Date
Select the batch date, usually either today’s date or the date when batch was received as a whole.
Batch Type
Select the batch type. Oracle Financial Services Lending and Leasing identifies each batch with a type signifying the type of payment batch it is; for example, mail, drop box, Western Union, walk in, and so on.
Batch Sta­tus
Total #
Enter total number of payments in the batch.
Ctrl Total #*
The total number of payments in the batch (actual).This figure must match the figure in required Total # field before a batch can be posted.
Total Amt
Enter total amount of payments in the batch.
Ctrl Total Amt*
View the total amount of payments in the batch (actual).This figure must match the figure in required Total Amt field before a batch can be posted.
Note: * These two fields update every time you save the itemized payment entries in the Payments section.
The Payments section records itemized information of the batch payment. It enables you to make one payment to one account, or more than one payment to more than one account. You can make Customer based payments to a single customer account or multiple accounts linked to same customer. For more information, refer ‘Customer Based Payments’ section.
You can post payments directly to Master Accounts and in-turn to its associated accounts based on specific conditions and parameters. Master Account consists of multiple accounts of the same Customer/Business grouped based on specific category. For more information, refer to Payment Posting at Master Account Level section.
  1. In the Payments section, perform any of the Basic Operations mentioned in Navigation chapter.
Field:
Do this:
Multi Account
Check this box when multiple entries of the same or different accounts are to be posted in a single batch. Since system also accepts ‘Cus­tomer Based Payments’, selecting this check box enables ‘Payment Hierarchy’ field and ‘Populate Accounts’ button in Payments section.
Note the following while selecting Multi Account check box:
When Multi Account is checked, you need to specify the “Account number” and “Spread” field details in the 'Payment Txns' section below. Else, the above two field details are to be specified in ‘Pay­ments’ section itself.
Every time when you select/deselect the Multi Account check box, system validates the “Account number” and “Spread” fields (as not null) and displays a confirmation message to reset either Payment or Transaction level Account Information and then proceeds.
Select the customer / Business # for which you want to allocate the payment from the drop-down list. The list is populated with Customer and Business accounts maintained in the system.
This field is enabled only when the value of system parameter UIX­_CUSTOMER_BASED_PMT_IND is set to ‘Y’. For more information, refer to ‘Customer Based Payments’ section.
Master Account #
Select the Master Account number for which you want to post the pay­ment and to its associated accounts from the drop-down list. The list is populated with Master Accounts associated with the Customer/Busi­ness selected above.
This field is enabled only if the value of system parameter UIX_MAS­TER_ACC_BASED_PMT_IND is set to ‘Y’.
Payment Hier­archy
This field is enabled only for Multi Account and system auto-populates the payment hierarchy if the same is selected in Servicing > Customer Details screen. If both Customer # and/or Master Account # is speci­fied, system populates Master Account's Payment Hierarchy. If only Customer # is specified, system populate Customer's Payment Hierar­chy.
However, you can also select the payment hierarchy from the drop-down list. This list is populated based on the hierarchy definitions maintained in Setup > Administration > User > Payment Hierarchy screen to adjusts the payment to all customer linked accounts.
Account #
Select the account number to which the payment entry is to be posted.
Title
System displays the account title upon account selection.
Account Status
System displays the account status upon account selection.
Pmt Date
Select the payment effective date. This date must be less than or equal to the date recorded in the Batch section. By default, system displays the current date.
Currency
Select the currency for the payment.
Pmt Amount
Specify the payment amount.
Spread
Upon account selection, system defaults the spread (payment alloca­tion strategy) based on the matching details defined in Spread Matrix screen (Setup > Products > Spreads > Spread Matrix). If there are no matching details found or spread matrix is not defined, system defaults the spread defined at the contract.
However you can also select the required spread for the payment from the drop-down list.
Mode
By default, system displays the mode upon account selection. How­ever, you can also select the payment mode from the drop-down list.
Reason
Select the reason for the payment.
Reference
Total Amount
View the total amount of the batch.
Status
View the status of the payment transaction.
Action
You can click on (+) icon to enter multiple accounts.
Ensure that you have selected the “Multi Account” check box for enter­ing multiple accounts.
Delete
You can remove the selected record by clicking on “Delete” button in the action block.
The system updates Ctrl Total # and Ctrl Total Amt fields in Batch section to record the contents of Payments section.
Customer Based Payments for Multi Account
To make customer based payments to multiple accounts linked to same customer, select ‘Populate Accounts’ button. System displays the eligible accounts linked to the selected Customer / Business # based on account selection criteria in Payment Hierarchy setup screen. For more information, refer ‘Customer Based Payments’ section.
Create Multiple Payments
You can use ‘Create Multiple Payments’ option to add multiple payments. Depending on the total payments specified in ‘Total #’ field, equivalent records are created with default value for manual updates.
The system derives the total number of payment rows to be displayed by calculating the difference between ‘Ctrl Total #’ and ‘Total #’ fields. However this option is not available if there is no difference in the above field values.
For each payment, use the Payments Txns section to record information about the account receiving payment. (There might be more than one entry for the same account; for example, one account may required different payment spreads).
  1. In the Payment Txns section, perform any of the Basic Operations mentioned in Navigation chapter. Ensure that the total Amount in Payments Txns section must match the contents of Total Amt in the Payments section.
  2. A brief description of the fields is given below.
    Field:
    Do this:
    Account #
    Select the account number. This field is available only if ‘Multi Account’ option is not checked in ‘Payments’ section.
    Title
    Account Status
    The current status of the account.
    Currency
    View the currency for the payment.
    Amount
    Specify payment amount.
    Spread
    Upon account selection, system defaults the spread (payment allo­cation strategy) based on the matching details defined in Spread Matrix screen (Setup > Products > Spreads > Spread Matrix). If there are no matching details found or spread matrix is not defined, sys­tem defaults the spread defined at the contract.
    However you can also select the required spread for the payment from the drop-down list. This field is available only if ‘Multi Account’ option is not checked in ‘Payments’ section.
    Status
    View the payment status.
    Error Rea­son
    View the reason for error. This field will populate after you click Post if payments aren’t reconciled.
Account Number ‘0’ is a Suspense Account to which unidentified payments and advances are posted.
When you want to post a batch transaction on Payment Entry screen, ensure that the details of the Batch section’s display only Ctrl Total # and Ctrl Total Amt fields match with details of the required Total # and Total Amt fields.
System changes the batch status from Open to Processing and submits batch to the job service. After the batch has been processed, system changes the batch status to Posted or Error.
Only a batch with a batch status of Open can be posted. The batch totals and control totals should match before you post the batch. If they do not and you click Post, the system displays the Error message as “Group control Totals not matching, Posting not allowed. The posted payments can be viewed on the Transactions screen on the Customer Service screen.
17.3.7.3 Holding a Batch of Payment Transactions
The Oracle Financial Services Lending and Leasing allows you to hold the posted batches if required. You can hold the batches only with the Open status.
  2. On the Payment Entry screen’s All Payments section, select Payments.
  3. In the View Option section, select the batches you want to view:
    • If the batch status is open, click Open Batches Only in the View Options section.
    • If the batch status is Error, click All Batches in the View Options section.
  1. Select the batch you want to hold from the Batch section.
  2. In the Action section, click Hold/Open.
The system changes the batch status from Open/Error to Hold.
17.3.7.4 Removing Hold from the Batch of Payments Transactions
The system allows you to remove hold from the batch when required. You can remove hold from the batches only with the Hold status.
To open or remove a hold on the batch of payments transactions
  1. On the Oracle Financial Services Lending and Leasing Application home screen, click the Servicing > Servicing > Batch Transaction > Payments > Payment Entry.
  2. In the View Option section, select All Batches section
  3. Select the batch you want to open from the Batch section.
17.3.7.5 Reversing the Batch of Payment Transactions
The system allows you to reverse the batch of payment transactions. You can reverse batches only with posted status.
To reverse the batch of payments transactions
  2. In the View Option section, select All Batches.
  3. Select the batch you want to reverse from the Batch section.
  4. In the Action section, click reverse.
System changes the batch status from posted to Processing and submits batch to the job service. After the batch has been processed, system changes the batch status to Reversed.
You can verify the reversal either using Transaction screen on Customer Service screen’s Transactions screen for each account in the batch, or by running payment history report (Reports master tab > Servicing drop-down link > Payment History).
17.3.7.6 Printing a Receipt
You can print receipts for walk-in payments using the Print Receipt button on the Payment Entry screen’s Action section. Receipts can be printed before actually posting the payment. This enables you to create just batch and leave it for end of the day processing, but also print receipt for customer.
To print a receipt of the payments transactions
  2. In the Batch section, click Add and specify required information regarding the payment for which you want to print a receipt. (Note: For more information, see the previous section in this chapter, Entering and Posting a Payment). Click Save.
  3. In the Payment section, click Add and specify the required information regarding payment for which you want to print a receipt. (Note: For more information, see the previous section in this chapter, Entering and Posting a Payment). Click Save.
  4. In the Payment Txns section, click Add and specify required information regarding the payment for which you want to print a receipt. (Note: For more information, see the previous section in this chapter, Entering and Posting a Payment). Click Save.
  5. In the Action section, click Print Receipt.
System sends the payment receipt directly to the printer based on the company level system parameter CMN_CMB_DEFAULT_PRINTER.
17.3.8 Payment Maintenance Tab
The Payment Maintenance screen enables you to perform the following maintenance functions on payments that have been posted:
Function:
Purpose:
Modify Payment
Enables you to change one or more of the payment attributes, such as the Account number, Spread, Payment Date, Currency, Payment Amount, and Reason.
For Single Account Payments, these details are editable in ‘Pay­ments’ section itself and for ‘Multi Account Payments’, only Pay­ment Date, Currency, Payment Amount, and Reason are editable in ‘Payments’ section and other details are editable in ‘New Pay­ment Txns’ section below.
Multi Account (check box)
Selecting the check box allows to change the payment account type from Single Account Payment to Multi Account Payment and vice versa. However, doing so will reset the Payment level Account Information and need to be selected carefully.
Notifies Oracle Financial Services Lending and Leasing that the customer did not have sufficient funds in the account and will post a NSF fee (based on setup).
Reverse
Enables you to simply reverse a payment.
Refund
Refunds payment to single account or to multiple account with a single AP requisition. For detailed information, refer to ‘Reversing Payment Transactions’ section.
In all cases, system performs a ‘true backdating’ to post the transaction based upon transaction date. Interest recalculations are automatic and all necessary transactions can be sent to the general ledger for automatic reconciliation.
Suspended Payments
In case of payments that are not posted to accounts due to issues such as incorrect account condition, the payments are posted to suspense. You can process these payments using the work queue for suspense payments. This typically involves identifying the correct amount or correcting problems with the account before attempting to re-post the payment. In this case, the payment is moved out of the suspense account and posted to the active account.
To view payments
  1. On the Oracle Financial Services Lending and Leasing Application home screen, click the Servicing > Servicing > Batch Transaction > Payments > Payment Maintenance tab.
  2. Search for required payment transaction or a batch using the following options:
  1. You can view or edit the following information in ‘Payments’ section:
    Field:
    Do this:
    Multi Account
    If the system displays this check box as selected, then you are allowed to edit the fields in ‘Payment Txns’ section below.
    Account #
    Select the required account number from the drop-down list.
    Title
    View the account holders name in this field.
    Account Status
    Spread
    Upon account selection, system defaults the spread (pay­ment allocation strategy) based on the matching details defined in Spread Matrix screen (Setup > Products > Spreads > Spread Matrix). If there are no matching details found or spread matrix is not defined, system defaults the spread defined at the contract.
    However you can also select the required spread for the pay­ment from the drop-down list.
    Pmt Dt
    Specify the payment date.
    Currency
    Select the currency from the drop-down list.
    Pmt Amt
    Reference
    View the payment reference.
    Reason
    Select the payment reason from the drop-down list.
    Mode
    View the payment mode.
    Company
    View the portfolio company.
    Branch
    View the portfolio branch.
    Batch #
    View the batch number.
    Batch Type
    View the batch type.
    Date
    View the batch date.
  2. View the following information for the selected payment in Payment Txns section:
    Field:
    View this:
    Account #
    The account number.
    Title
    The account title.
    Account Status
    Currency
    The currency in which payment is done.
    Amount
    The payment amount.
    Status
    The status of payment.
    Spread
    The spread (payment allocation strategy).
    Reason
    The payment reason.
    Error Reason
    The error reason for payment, if any.
The Payment Allocation section details how the selected payment was applied against the account. This is useful in determining whether the payment was posted correctly or whether the spread or transaction date needs to be modified.
17.3.8.1 Modifying/Correcting Payment Transactions
In some cases, a payment may be valid, but how it was posted was incorrect; for example, payment was posted to the wrong account, with the wrong date, or with incorrect spread data. The Payment Maintenance screen enables you to correct such errors.
Consider the following scenarios during payment maintenance:
To modify/correct an individual payment transaction
  2. In the View Options section, select the type of payments you want to view: Posted, Suspense, or All.
  3. In the Search Parameters section, use Account number, Payment Date, Payment Amount, or Reference number fields and Search button to locate the account you want to work with. The system displays payments matching your search criteria in the Payments section.
  4. In the Payments section, select the payment that you want to modify and click Modify Payment.
  5. In the Payments section, you can modify/correct the following details:
    Field:
    Do this:
    Pmt Dt
    Select the payment date from the adjoining calendar.
    Currency
    Pmt Amt
    Reason
    (Optional) Select any of the relevant reason for the payment from the drop-down list.
  6. In the New Payment Txns section, update the fields with information about payment you want to modify to reconcile the payment changes.
    Field:
    Do this:
    Account #
    Select account number from the drop-down list.
    Amount
    Specify the transaction amount.
    Spread
    Upon account selection, system defaults the spread (payment allo­cation strategy) based on the matching details defined in Spread Matrix screen (Setup > Products > Spreads > Spread Matrix). If there are no matching details found or spread matrix is not defined, system defaults the spread defined at the contract.
    Reason
    (Optional) Select any of the relevant reason for the payment trans­action from the drop-down list.
  7. In the New Payment Txns section, you can also do the following:
    • Click to add additional payment transactions. System inserts a new record and allows you to specify the above details. When new records are added for single account in payment Txns section, system automatically changes the record to 'Multi Account' and displays in 'Payments' section.
    • Click Delete to remove the selected payment record which in-turn posts a ‘Payment reversal’ transaction on to the account. When records are removed from multi-account in payment Txns section either by deleting or posting with zero amount, system automatically changes the record to single payment account and displays in 'Payments' section with the account number.
    • Click Reset to revert to previously saved payment transaction data.
  1. Click Post and Stay/Return or any of the Basic Actions mentioned in Navigation chapter.
The system modifies the original payment and posts new payment. The modified payment can be viewed on the Customer Service screen’s Transaction screen.
17.3.8.2 Reversing Payment Transactions
To reverse an individual payment transaction
  4. In the Payments section, select the payment that you want to reverse.
  5. Click Reverse, and click ‘Yes’ in Reverse Transaction confirmation dialog.
  6. Click Post and Stay/Return or any of the Basic Actions mentioned in Navigation chapter.
The system reverses the original payment. The modified payment can be viewed on the Customer Service screen’s Transaction screen.
Access to the Reverse button can be restricted by user responsibility and the account’s product type using the PAYMENT_REV transaction code (Super Group: ACCOUNT MONETARY TXN) on the Administration screen. (For more information, see the Txn Codes screen section in the Oracle Financial Services Lending and Leasing Setup Guide).
17.3.8.3 Reversing Payment Transaction and Assessing NSF Fee
To reverse an individual payment transaction and assess NSF fee
  4. In the Payments section, select the payment that you want to reverse with an NSF fee.
  5. Cick NSF and click ‘Yes’ in Reverse Transaction confirmation dialog.
The system reverses the original payment and assesses the NSF fee. The modified payment can be viewed on the Customer Service screen’s Transaction screen.
17.3.8.4 Refund Payment Transaction
The Refund option in Payment Maintenance screen helps you to refund the payment received from the customer during the servicing stage of Loan.
Payment refund facility is available for both Single Account and Multi-Account. In case of Multi-account, payments appropriated to different customer accounts can be refunded in a single AP requisition.
Payment refund can be processed either in source currency in which the initial payment was posted on account or in account currency in which the account is operated. The same can be defined in the system parameter TPE_PMT_REFUND_CURRENCY_SRC_CD as either ‘Payment Currency’ or ‘Account Currency’. However, there is NO exchange rate applicable.
if it is Payment Currency then system considers payment amount and if it is Account Currency then system creates the requisition with the total transaction amount of one or multiple accounts where payment was allocated.
Note the following before posting payment refund transaction:
Scenarios to be considered during Multiple & Master Accounts Refunds
Scenario
Payment Requisition Type
If multiple payments are associated to a payment
System generates requisition with Account Currency.
If the payment was posted using ‘Customer ID’ or if there is a common customer in all accounts involved in current payment
System creates only one payment requisi­tion of entire payment amount using the customer details.
Note
You can also post ‘Payment Refund Transaction’ to refund payment at account level from Customer Service > Maintenance screen.
To refund payment transaction
  4. In the Payments section, select the payment that you want to refund.
  5. Select appropriate reason code from ‘Reason’ drop-down list. This list is populated with applicable reason codes based on lookup type TXN_REASON_CD and sub type ‘REFUND’.
  6. Click Refund, and click ‘Yes’ in Refund Transaction confirmation dialog to validate and the post the refund transaction.
Following are the transaction parameters used during refund:
On posting the transaction:
17.3.9 Outbound Customer Extracts To Payment Agencies Batch
An outbound customer extract file can be generated and sent to multiple payment vendors like Money gram, Quick Collect, Speed Pay from Western Union, Lockbox etc. Sharing this extract enables various outlets of these payment agencies to verify account’s existence in FI and proceed with payment processing.
After receiving the payment extract file, the vendor validates customer details and sends a notification confirmation of Payment in NACHA format.
In case of Master and its associated accounts, the Output File Definition for Customer Payment File Extract (CUST_PAYMENT_EXTRACT) has a consolidation of all account dues at Master account level based on system parameter OCP_CUST_PMT_PREF (MASTER ACCOUNT ROLLUP FOR PMT EXTRACT FILE).
The Column Definitions for Customer Payment File Extract has predefined columns to populate individual account dues and consolidated master account dues. However, for accounts having no Master account, consolidation is not done and system does not display rolled-up dues in Master column fields.
The basis of dues consolidation at Master account level is controlled based on the following:
Processing
The system generates customer extract of customers from which payment is expected, everyday. This process is configured as ‘Outbound Customer Extracts To Payment Agencies Batch’ batch job OCPPRC_BJ_100_01 defined in SET-ODD2 Batch Job Set which is run daily. The batch generated an extract in text format containing all Accounts relevant details.
Accounts with payment mode ACH or Lockbox can be excluded. The system facilitates setting-up options to pick up payment modes that needs to be included in extract generation.
This file is stored in a configurable shared path from which it is shared to required outlets as discussed earlier.
17.3.10 Search Tab
A Search tab is available on the Payments screen to help locate information of an account or specific payment(s) posted on the account. This is information that is used on the Payment Maintenance tab.
To search for an Account or Payment
  1. On the Oracle Financial Services Lending and Leasing Application home screen, click the Servicing > Servicing > Batch Transaction > Payments > Search tab.
  2. In the ‘Search Options’, select Account (default) or Payment radio button. The screen arrangement differs for Account / Payment search.
Note
The list of parameters available for Account / Payment Search criteria is ‘user defined’ and is configurable in Setup > Administration > System > User Defined Tables screen. For Ac­count Search, the parameters can be added/removed in SEARCH : ACCOUNT ON BATCH ENTRY SCREEN User Table Type and for payment search, it is SEARCH : PAY­MENT MAINTENANCE SEARCH.
  1. Based on the selection, the following options are available to define the search criteria:
    Account Search
    Payment Search
    ACCOUNT #
    ACCOUNT STATUS
    CUSTOMER SSN
    CUSTOMER LAST NAME
    CUSTOMER FIRST NAME
    CUSTOMER ID
    ACCOUNT CONDITIN
    PAYMENT STATUS
    MULTI ACCOUNT
    ACCOUNT NUMBER
    PAYMENT AMOUNT
    PAYMENT START DATE
    PAYMENT END DATE
    PAYMENT REFERENCE NUMBER
    BATCH #
  2. In the Search Criteria section, use the Comparison Operator and Value columns to select/enter the details for each search criteria. However, you need to specify a minimum of one criteria for search to retrieve the details. Else system displays an error message.
    • While using PAYMENT AMOUNT parameter to search for payment record, ensure that you specify atleast one more additional parameter for search to retrieve the details. Else system displays an error message.
  1. Click Search. System displays the result in Search Results section.
    Account Search Results
    Payment Search Results
    Account #
    Date
    Title
    Product
    Producer
    Status
    Branch
    Product
    Company
    Secured
    Multi Account
    Account #
    Title
    Account Status
    Pmt Dt
    Currency
    Pmt Amt
    Txn Amt
    Spread
    Mode
    Reason
    Reference
    Batch #
    Status
  2. You can either click ‘Open’ or double-click on the required record to view the details in ‘Payment Maintenance’ screen.
You can click ‘Reset Criteria’ at any time to clear the Comparison Operator and Value columns on the Search Criteria section.
17.4 Fees
Oracle Financial Services Lending and Leasing enables you to process batch fee and expense assessments for many accounts in one screen outside the preview of automated processing.
This chapter explains how to use the Fees screen to complete the following tasks:
17.4.1 Fees Tab
Using the Fees screen, you can enter and view a batch of fee processing. You can then post a batch, place a batch on hold, open a batch on hold, or reverse a batch.
17.4.1.1 Viewing Batches
The Fees screen enables you to view either all batches or only open batches. You can choose which batch you want to view using the View Options section. Viewing all batches enables you to locate batches with a status of open, reverse, hold, error, or posted.
To view open fee batches
  1. On the Oracle Financial Services Lending and Leasing Application home screen, click the Servicing > Servicing > Batch Transaction > Fees > Fee Entry tab.
  2. On the Fee Entry screen’s View Options section, click Open Batch Only.
Details regarding the selected batch appear in the Fees section.
To view all Fees batches
  1. On the Oracle Financial Services Lending and Leasing Application home screen, click the Servicing > Servicing > Batch Transaction > Fees > Fee Entry.
  2. On the Fee Entry screen’s View Options section, click All Batches.
In the Batch section, the system displays all fee batches, regardless of status.
If a batch contains a fees with an error status, the Error Reason field displays the cause.
17.4.1.2 Entering and Posting Batches
The Fee Entry screen enables you to manually post batches of fees. A batch can consist of one or more accounts.
To enter and post a batch for a fees processing
  2. In the Fee Entry screen’s Batch section, click Add.
  3. In the Batch section, perform any of the Basic Operations mentioned in Navigation chapter.
Field:
Do this:
Company
Branch
Select the branch.
Batch #
The batch number (system generated). The batch number format is Fee-YYYY-JJJ-SSSS, where YYYY is the year, JJJ is the Julian date, and SSSS is a sequential number. The system generates a new sequence for every different date, so the first batch of each day starts with SSSS = 0001.
Date
Select the batch date, usually either today’s date or the date the batch was received as a whole.
Batch Type
Select the batch type. The system identifies each batch with a type signifying the type of payment batch it is; for example, mail, drop box, Western Union, walk in, and so on.
Batch Status
The status of Batch.
Total #
Specify total number of payments in the batch.
Ctrl Total #*
The total number of payments in the batch (actual).This fig­ure must match the figure in the required Total # field before a batch can be posted.
Total Amt
Specify total amount of payments in the batch.
Ctrl Total Amt*
View the total amount of payments in the batch (actual). This figure must match the figure in the required Total Amt field before a batch can be posted.
These two fields update every time you save the itemized payment entries in the Fees section.
The Fees section records itemized information of the fees batch processing. It enables you to make one payment to one account, or more than one payment to more than one account.
  1. In the Fees section, perform any of the Basic Operations mentioned in Navigation chapter.
Field:
Do this:
Fee Date
Select the fee effective date. This date must be less than or equal to the date recorded in the Batch section.
Fee Amount
Specify the fee amount.
Status
Txn Codes
Select the transaction code.
Reason
Reference
Specify any reference information (such as check num­ber).
Total Amount
Account #
Select the account number to which this payment applies.
System updates Ctrl Total # and Ctrl Total Amt fields in Batch section to record the contents of the Fees section.
  1. For each fee, use the Fee Txns section to record information about the fee received. (There might be more than one entry for the same account).
  2. In the Fee Txns section, perform any of the Basic Operations mentioned in Navigation chapter. Ensure that the total Amount in Fee Txns section must match the contents of Total Amt in the Fees section.
A brief description of the fields is given below:.
Field:
Do this:
Account #
Title
Amount
Status
Txn Codes
View the Transaction codes.
Error Reason
When you want to post a fee transaction on Fees Entry screen, ensure that contents of the Batch section’s display only Ctrl Total # and Ctrl Total Amt fields matches with contents of the required Total # and Total Amt fields. In the following example, batch is ready to post, as these figures match.
System changes the batch status from Open to Processing and submits batch to the job service. After the batch has been processed, The system changes the batch status to Posted or Error.
You can post only those batch with a batch status as OPEN. Also the batch totals and control totals should match before you post the batch. Else, an error message is displayed.
Note
You can post only those batch with a batch status as OPEN. Also the batch totals and con­trol totals should match before you post the batch. Else, an error message is displayed.
17.4.1.3 Holding a Batch of Fee Processing
To hold the batch of fee processing
  2. On the Fee Entry screen’s View Option section, select the batches you want to view.
  1. In the Action section, click Hold/Open.
17.4.1.4 Removing a Hold on the Batch of Fee Processing
The status HOLD can be removed for the batch with status Hold.
To open (or remove hold) on the batch of fee processing
  2. On the Fee Entry screen’s View Option section, select the fees you want to view.
  3. Use the Fees section to select the batch you want to open.
17.4.1.5 Reversing the batch of Fee Processing
Only the batches with a status of posted can be reversed.
To reverse the batch of fee processing
  3. Use the Fees section to select the batch you want to reverse.
System changes batch status from posted to Processing and submits batch to the job service. After the batch has been processed, system changes the batch status to Reversed.
17.5 Search screen
A Search screen is available on the Fees screen to help locate information such as an account’s number, customer name and company. This is information that is used on the Fees Entry screen.
  1. On the Oracle Financial Services Lending and Leasing Application home screen, click the Servicing > Servicing > Batch Transaction > Fees > Search. The Fees screen’s Search screen appears.
  3. Click Search. System displays result of the search in Results section at the bottom of the screen. You can click Reset Criteria at any time to clear the Comparison Operator and Values columns on the Search Criteria section.
