Simple Account Creation is an enhanced interface provided in OFSLL using the Oracle JavaScript Extension Toolkit (Oracle JET) frame work. This is an additional interface supported from OFSLL to the existing Customer Servicing Account creation screen and both intended to coexist in the system till further updates.
The Oracle JET frame work is a complete yet modular JavaScript development toolkit for building and providing a powerful, state-of-the-art capable user interfaces. For more information on deploying this framework, refer to Installation Manuals.
The Account Creation gives a smooth workflow and a simplified way of creating an account with less number of steps and much improved user interface. However note that, this screen only supports the Auto-Loan in this release and does not have capability to handles other types of Loans, Lines and Lease.
In order to access the Simple Account create screen from the User Interface Servicing menu link:
For more information, refer to system parameters section in setup guides.
Simple Account Create menu link is available in LHS menu for account creation. Following are the different components available in the screen:
The Account Search screen has following search parameters.
Field Name |
Description |
Type |
Comments |
App # |
Application Number |
Text |
Application Date |
Application creation date |
Date |
Date picker is available to pick a date |
Product |
Product Code for which the application was created |
Text |
Producer Number |
Producer Number |
Text |
Field Name |
Description |
Type |
Comments |
App # |
Number |
Date |
Date |
Title |
Application name given |
Text |
Status |
Application status |
Text |
Branch |
Branch where the application was created |
Text |
Product |
Text |
Producer |
Producer Id of the applications to be searched |
Text |
Provided the first screen in the process train ‘Application Entry’ with the following details.
Field Name |
Description |
Mandatory |
Type |
Comments |
Date |
Select the date |
Yes |
Date |
Date picker is available |
Product Type |
Select the product from the drop down |
Yes |
Text |
Shows all the enabled product codes |
Channel |
Select the channel from the drop down |
Yes |
Text |
Refers the lookup APP_SOURCE_CD |
Priority |
Select the priority from the drop down |
Yes |
Text |
Refers the lookup APP_PRIORITY_CD |
Company |
Select the company from the drop down |
Yes |
Text |
Shows all the enabled companies |
Branch |
Select the Branch from the drop down |
Yes |
Text |
Shows the enabled branches of the selected companies |
Producer |
Select the producer from the drop down |
Yes |
Text |
Refers the lookup PRO_TYPE_CD |
Producer Name |
Select the Producer name from the drop down |
Yes |
Text |
Shows the enabled producer of selected producer type, company and branch |
Status |
Select the Status from the drop down |
Yes |
Text |
Class |
Select the company |
Yes |
Text |
Refers the lookup APP_CLASS_TYPE_CD |
Xref |
Enter the Xref from the drop down |
Yes |
Text |
Promotion |
Select the promotion from the drop down |
Yes |
Text |
Shows the enabled promotion for the selected company, branch, product type |
Field Name |
Description |
Mandatory |
Type |
Comments |
Requested Amount |
Enter the requested amount |
Yes |
Integer |
Increment and decrement buttons are available to increase and decrease the amount by 1 |
Down Payment |
Enter the down payment amount |
Yes |
Integer |
Term |
Enter the term |
Yes |
Number |
Rate |
Enter the Rate |
Yes |
Integer |
Field Name |
Description |
Mandatory |
Type |
Comments |
+ or - sign |
Yes |
Text |
Itemization |
Itemization |
Yes |
Text |
Itemization associated with product is loaded |
Approved Amount |
Enter the itemization amount |
No |
Integer |
Comment |
Enter the comment |
No |
Text |
Provided the 2nd screen in the process train ‘Customer’ with the following details
Provided 3 options in the customer section
Provided ‘+’ button opens a new screen with 5 collapsible panes with header as Create Customer
Provided ‘Customer Details’ screen with the following details
Field Name |
Description |
Mandatory |
Type |
Comments |
Relation Type |
Select the Relation type |
Yes |
Text |
Refers the lookup RELATION_TYPE_CD |
First Name |
Enter the first name |
Yes |
Text |
MI |
Enter the middle name |
No |
Text |
Last Name |
Enter the last name |
Yes |
Text |
Family Name |
Enter the Family name |
No |
Text |
Suffix |
Enter the suffix |
No |
Text |
Refers the lookup |
Date of Birth |
Enter the date of birth |
Yes |
Date |
SSN |
Enter the SSN |
Yes |
Number |
Class |
Select the class |
Yes |
Text |
Enter the email |
No |
Text |
Time Zone |
Select the time-zone |
No |
Text |
Refers the lookup TIME_ZONE_CD |
Provided ‘Identity Information’ screen with the following details
Field Name |
Description |
Mandatory |
Type |
Comments |
Nationality |
Select the nationality |
Yes |
Text |
Refers the lookup NATIONALITY_CD |
National Id |
Enter the national Id |
No |
Number |
Passport# |
Enter the passport # |
No |
Number |
Passport Issue Date |
Enter the passport issue date |
No |
Date |
Passport Expiry Date |
Enter the passport expiry date |
No |
Date |
Visa# |
Enter the Visa# |
Yes |
Text |
License# |
Enter the License# |
No |
Text |
License State |
Select the License State |
No |
Text |
Refers the lookup STATE_CD |
Provided ‘Other Details’ screen with the following details
Field Name |
Description |
Mandatory |
Type |
Comments |
Name in Local Language |
Enter the name |
No |
Text |
Gender |
Select the Gender |
No |
Text |
Refers the lookup GENDER_CD |
Mother’s Maiden Name |
Enter mother’s maiden name |
No |
Text |
Education |
Select the Education |
No |
Text |
Refers the lookup EDUCATION_LEVEL_CD |
Language |
Select the Language |
Yes |
Text |
Refers the lookup LANGUAGE_CD |
Marital Status |
Select the marital status |
No |
Text |
Refers the lookup MARITAL_STATUS_CD |
ECOA |
Select the ECOA code |
No |
Text |
Refers the lookup CRB_ECOA_CD |
Race |
Select the race |
No |
Text |
Refers the lookup RACE_NATIONAL_ORIGIN_CD |
Ethnicity |
Select the ethnicity |
No |
Text |
Refers the lookup APL_ETHNIC_CD |
Disability |
Select the disability indicator |
No |
Text |
Privacy opt Out |
Select the Privacy opt Out indicator |
No |
Text |
Insurance Opt Out |
Select the Insurance Opt Out indicator |
No |
Text |
Marketing opt out |
Select the Marketing opt out indicator |
No |
Text |
Share credit opt out |
Select the Share credit opt out |
No |
Text |
Prior bankruptcy |
Select the Prior bankruptcy indicator |
No |
Text |
Bankruptcy Discharge Dt |
Select the Bankruptcy Discharge date |
No |
Date |
Provided ‘Power of Attorney’ screen with the following details
Field Name |
Description |
Mandatory |
Type |
Comments |
Power of Attorney |
Select the POA indicator |
No |
Text |
Holder Name |
Enter the holder’s name |
No |
Text |
Address |
Enter the address |
No |
Text |
Country |
Select the country |
No |
Text |
Refers the lookup COUNTRY_CD |
Nationality |
Yes |
Text |
Phone |
Enter the Phone |
No |
Number |
Provided ‘Military Details’ screen with the following details
Field Name |
Description |
Mandatory |
Type |
Comments |
Active Military Duty |
Select the indicator |
No |
Text |
Effective Dt |
Enter the effective Date |
No |
Date |
Order Ref# |
Enter the Order ref# |
No |
Text |
Release Dt |
Enter the release Dt |
No |
Date |
Provided ‘Address information’ pane shows the following details
Provided ‘Address Details’ screen with the following details
Field Name |
Description |
Mandatory |
Type |
Comments |
Address Type |
Select the address type |
Yes |
Text |
Refers the lookup ADDRESS_TYPE_CD |
Current |
Select the current indicator |
No |
Text |
Confirmed |
Select the confirmed indicator |
No |
Text |
Mailing |
Select the mailing indicator |
No |
Text |
Permission to call |
Select if permission to call is Yes or No |
No |
Text |
Permission to Text |
No |
Text |
Country |
Yes |
Text |
Provided ‘Address Information’ screen with the following details
Field Name |
Description |
Mandatory |
Type |
Comments |
Postal Type |
Select the Postal Type |
Yes |
Text |
Refers the lookup POSTAL_ADDRESS_TYPE_CD |
Address# |
Enter the address# |
Yes |
Text |
Street Pre |
Select the Street Pre |
No |
Text |
Refers the lookup STREET_PRE_TYPE_CD |
Street name |
Enter the Street Name |
Yes |
Text |
Street Type |
Select the street Type |
No |
Text |
Refers the lookup STREET_TYPE_CD |
Street Post |
Select the Street Post |
No |
Text |
Refers the lookup STREET_POST_TYPE_CD |
Apt# |
Enter the Apt# |
No |
Text |
Address Line 1 |
Enter the address line 1 |
No |
Text |
Address Line 2 |
Enter the address line 2 |
No |
Text |
Address Line 3 |
Enter the Address line 3 |
No |
Text |
Zip |
Select the Zip |
Yes |
Text |
Refers the lookup ZIP_CD |
Zip Extn |
Enter the zip extn |
No |
Text |
City |
Enter the City |
Yes |
Text |
City is filled based on the zip |
State |
Select the State |
Yes |
Text |
State is filled based on the zip |
Phone |
Enter the Phone number |
No |
Text |
Provided ‘Additional Information’ screen with the following details
Field Name |
Description |
Mandatory |
Type |
Comments |
Own/Rent |
Select the Own/Rent |
Yes |
Text |
Refers the lookup OWNERSHIP_CD |
Cenus Tract/BNA code |
Enter the code |
No |
Text |
MSA Code |
Enter the code |
No |
Text |
Comments |
Enter comments |
No |
Text |
Provided ‘Address Rent Mortgage Details’ screen with the following details
Field Name |
Description |
Mandatory |
Type |
Comments |
Stated |
Currency |
Select stated currency from drop-down list. |
Yes |
Text |
Frequency |
Select stated frequency from the drop-down list. |
Yes |
Text |
Actual |
Frequency |
Select actual frequency from the drop-down list. |
Yes |
Text |
Provided ‘Telecom information’ pane shows the following details
Provided ‘Telecom Information’ screen with the following details
Field Name |
Description |
Mandatory |
Type |
Comments |
Type |
Select the Telecom Type |
Yes |
Text |
Phone |
Enter the Phone Number |
Yes |
Number |
Extn |
Enter the Extension |
No |
Number |
Current |
Select the Current Indicator |
No |
Text |
Permission to Call |
Text |
Text |
Time Zone |
Select the Time zone |
Text |
Best Day to Call |
Select the best day to call |
Text |
Start Time |
Enter the start Time |
Yes |
Number |
Increment and decrement buttons are available to increase and decrease the value by 1 |
Period |
Select the period |
Yes |
Text |
End Time Period |
Enter the End time |
Yes |
Number |
Period |
Select the period |
Yes |
Text |
Provided Telecom card shows the below details
Provided ‘Cancel’ button to close the view screen
Provided ‘Employment information’ pane shows the following details
Provided ‘Employment Information’ screen with the following details.
Field Name |
Description |
Mandatory |
Type |
Comments |
Type |
Yes |
Text |
Refers the lookup EMPLOYMENT_TYPE_CD |
Current |
No |
Text |
No |
Text |
No |
Text |
Employer |
Enter the Employer |
Yes |
Text |
Occupation |
Text |
Refers the lookup OCCUPATION_CD |
Title |
Enter the Title |
No |
Text |
Department |
Enter the Department |
No |
Text |
Employee ID |
Enter the Employee ID |
No |
Number |
Additional Info |
Phone |
No |
Number |
Extn |
No |
Number |
Comment |
Enter the Comment |
No |
Text |
Provided ‘Employment Address’ screen with the following details.
Field Name |
Description |
Mandatory |
Type |
Comments |
Country |
Yes |
Text |
Address# |
Enter the address # |
No |
Number |
Address Line 1 |
Enter address line 1 |
No |
Text |
Address Line 2 |
Enter address line 2 |
No |
Text |
Zip |
Select the Zip |
No |
Number |
Refers the ZIP setup for selected country |
Zip Extn |
Enter the Zip extn |
No |
Number |
City |
Enter the city |
No |
Text |
Populated based on the ZIP |
State |
Enter the City |
No |
Text |
Provided ‘Employment Details’ screen with the following details.
Field Name |
Description |
Mandatory |
Type |
Comments |
STATED |
Pay Day |
Select the date |
Yes |
Date |
Frequency |
Select the Frequency |
Yes |
Text |
Refers lookup FREQ_CD |
Currency |
Select the Currency |
Yes |
Text |
Refers lookup CURRENCY_CD |
Salary |
Enter the salary |
No |
Number |
Increment and Decrement buttons are available to increase and decrease the amount by 1 |
ACTUAL |
Pay Day |
Select the date |
Yes |
Date |
Frequency |
Yes |
Text |
Salary |
Enter the salary |
No |
Number |
VERIFICATION DETAILS |
Verified By |
Text |
System stamps the user |
Verified Dt |
Date |
System stamps the date |
Provided the 3rd screen in the process train ‘Collateral’ with the following details
3 sections with collapsible panes
Panes expand and contract on click of each pane header
Provided ‘Customer Details’ screen with the following details.
Field Name |
Description |
Mandatory |
Type |
Comments |
Asset Number |
No |
Text |
Asset Class |
Select the Asset Class |
Yes |
Text |
Asset Type |
Yes |
Text |
Refers the asset type setup |
Sub Type |
Yes |
Text |
Status |
Yes |
Text |
Primary |
Select the Primary Indicator |
No |
Text |
Provided ‘Type and Description’ screen with the following details.
Field Name |
Description |
Mandatory |
Type |
Comments |
Select Make and Model |
Select the make and model |
No |
Text |
Refers the setup |
Year |
Enter the year |
Yes |
Number |
Estimated life |
Enter the life estimated |
No |
Number |
Make |
Enter the make |
No |
Text |
Make is populated based on the record selected from the select make model drop-down |
Model |
Enter the model |
No |
Text |
Identification# |
Enter the Identification # |
Yes |
Text |
Body |
Enter the Body |
No |
Text |
Registration# |
Enter the registration # |
Yes |
Text |
Description |
Enter the description |
No |
Text |
Condition |
Select the condition |
No |
Text |
VIN Validation |
Provided ‘Address’ screen with the following details.
Field Name |
Description |
Mandatory |
Type |
Comments |
Country |
Yes |
Text |
Address# |
Enter Address # |
No |
Text |
Address Line 1 |
Enter Address Line 1 |
No |
Text |
Address Line 2 |
Enter Address Line 2 |
No |
Text |
Zip |
Select the Zip |
Yes |
Number |
Zip Extn |
Enter the ZIP extn |
No |
Number |
City |
Enter the city |
No |
Text |
State |
Select the State |
No |
Text |
County |
Select the County |
No |
Text |
Provided ‘Usage Details (Life)’ screen with the following details.
Field Name |
Description |
Mandatory |
Type |
Comments |
Start |
Enter the Start |
Yes |
Number |
Base |
Enter the base |
Yes |
Number |
Extra |
Enter the Extra |
Yes |
Number |
Total |
Enter the Total |
Yes |
Number |
Charge Amt |
Enter the charge amt |
Yes |
Number |
Provided ‘valuation’ pane shows the following details
Provided ‘Valuation Details’ screen with the following details
Field Name |
Description |
Mandatory |
Type |
Comments |
Current |
No |
Text |
Valuation Dt |
Enter the valuation Dt |
Yes |
Date |
Date Picker is available |
Source |
Select the source |
Yes |
Text |
Refers the lookup VALUATION_SOURCE_CD |
Edition |
Enter the Edition |
No |
Text |
Supplement |
Enter the supplement |
No |
Text |
Provided ‘Wholesale’ screen with the following details:
Field Name |
Description |
Mandatory |
Type |
Comments |
LC Wholesale base Amt |
Enter the amount |
Yes |
Number |
Enter the amount |
Yes |
Number |
Usage |
Enter Usage |
Yes |
Number |
Provided ‘Retail’ screen with the following details:
Field Name |
Description |
Mandatory |
Type |
Comments |
Retail Base Amt |
Enter the amount |
Yes |
Integer |
Addons Amt(+) |
Enter the amount |
Yes |
Integer |
Usage value Amt(+) |
Enter the amount |
Yes |
Integer |
Total Value Amt(=) |
Enter the amount |
Yes |
Integer |
LC Retail Base Amt(+) |
Enter the amount |
Yes |
Integer |
LC addons Amt(+) |
Enter the amount |
Yes |
Integer |
LC usage Value Amt(+) |
Enter the amount |
Yes |
Integer |
LC Total Value Amt(=) |
Enter the amount |
Yes |
Integer |
Provided ‘Addons pane shows the following details:
Provided ‘Addons Details’ screen with the following details:
Field Name |
Description |
Mandatory |
Type |
Comments |
Description |
Select the Addon |
Yes |
Text |
Refers the setup |
Value |
Enter the value |
No |
Text |
Amount |
Enter the amount |
No |
Text |
Loan currency Amount |
Enter the amount |
No |
Text |
The Contract section captures the application contract details.
Contract section has following two collapsible sub sections.
Contract Information is has the following fields.
Field Name |
Mandatory |
Type |
Comments |
Contract Details |
Contract Rcvd Dt |
NA |
Read only |
Contract Dt |
NA |
Read only |
Instrument |
NA |
Read only |
Amount Financed |
NA |
Read only |
Loan Term |
NA |
Read only |
Index |
NA |
Read only |
Index Rate |
NA |
Read only |
Contract Margin Rate |
NA |
Read only |
Contract Rate |
NA |
Read only |
Balloon Method |
NA |
Read only |
Balloon Amt |
NA |
Read only |
Due Day |
NA |
Read only |
1st Pmt Dt |
NA |
Read only |
Maturity Dt |
NA |
Read only |
Finance Charge Amt |
NA |
Read only |
Total of Pmts |
NA |
Read only |
Down Pmt Amt |
NA |
Read only |
Total Sale Price |
NA |
Read only |
Payment Amount |
NA |
Read only |
Final Pmt Amt |
NA |
Read only |
Repmt Currency |
NA |
Read only |
Principal Balance |
NA |
Read only |
APR |
NA |
Read only |
Verified Dt |
NA |
Read only |
Verified By |
NA |
Read only |
Signing Dt |
NA |
Read only |
Instrument Details |
Accrual Method |
NA |
Read only |
Start Dt Basis |
NA |
Read only |
Base Method |
NA |
Read only |
Bill Method |
NA |
Read only |
Bill Type |
NA |
Read only |
Time Counting Method |
NA |
Read only |
Calendar Method |
NA |
Read only |
Start Days |
NA |
Read only |
Stop Accrual Days |
NA |
Read only |
ACH Fee Ind |
NA |
Read only |
Promotion Details |
Promotion |
NA |
Read only |
Type |
NA |
Read only |
Delq Days |
NA |
Read only |
Period Type |
NA |
Read only |
Period |
NA |
Read only |
Tolerance Amount |
NA |
Read only |
Index |
NA |
Read only |
Index Rate |
NA |
Read only |
Promotion Margin Rate |
NA |
Read only |
Contract Detailed view has the following fields.
Field Name |
Mandatory |
Type |
Comments |
Other Details |
Servicing Branch Collector |
NA |
Read only |
Misc |
Link To Existing Customer |
NA |
Read only |
Anniversary Period |
NA |
Read only |
Default Pmt Spread |
NA |
Read only |
HDMA |
Lien Status |
NA |
Read only |
HOEPA |
NA |
Read only |
Rate Spread |
NA |
Read only |
Others |
1st Pmt Deduction Days |
NA |
Read only |
1st Pmt Refund Days |
NA |
Read only |
PrePmt Penalty |
NA |
Read only |
% Of Term For Penatly |
NA |
Read only |
Rebate |
Rebate Method |
NA |
Read only |
Rebate Term Method |
NA |
Read only |
Rebate Min Fin Chg Method |
NA |
Read only |
Contract Section consist of a ‘Suggest’ button which will provide best match contract and calculated contract parameters like Payment Amount, APR etc. by calling “Auto Contract” web service.
Expandable icon is enabled for user to expand the contract information and “OK” button is provided to collapse to normal view.
Field Name |
Mandatory |
Type |
Comments |
Edit Type |
NA |
Read only |
Result |
NA |
Read only |
Expected Value |
NA |
Read only |
Actual Value |
NA |
Read only |
Identity information |
NA |
Read only |
An ‘Account Summary’ section is provided to show the summary of application details provided in various section before creating an account.
This section consists of following sub sections:
Following are the fields displayed in Request sub sections.
Field Name |
Mandatory |
Type |
Comments |
Application Details |
Date |
NA |
Read only |
Product Type |
NA |
Read only |
Channel |
NA |
Read only |
Company |
NA |
Read only |
Branch |
NA |
Read only |
Producer |
NA |
Read only |
Promotion |
NA |
Read only |
Request |
Requested Amount |
NA |
Read only |
Down Payment |
NA |
Read only |
Term |
NA |
Read only |
Rate |
NA |
Read only |
Itemizations |
Itemization Type |
NA |
Read only |
Following are the fields displayed in Customer sub sections.
Field Name |
Mandatory |
Type |
Comments |
Customer Information |
Full Name |
NA |
Read only |
Family Name |
NA |
Read only |
Relation Type |
NA |
Read only |
Birth Dt |
NA |
Read only |
SSN |
NA |
Read only |
Class |
NA |
Read only |
NA |
Read only |
Identity Information |
Nationality |
NA |
Read only |
National ID |
NA |
Read only |
Visa# |
NA |
Read only |
Passport No |
NA |
Read only |
Existing Customer# |
NA |
Read only |
Update Customer Info |
NA |
Read only |
Other Details |
Gender |
NA |
Read only |
NA |
Read only |
Education |
NA |
Read only |
Language |
NA |
Read only |
Marital Status |
NA |
Read only |
ECOA |
NA |
Read only |
Power of Attorney |
Power of Attorney Holder Name |
NA |
Read only |
Address |
NA |
Read only |
Country |
NA |
Read only |
Nationality |
NA |
Read only |
Telephone Number |
NA |
Read only |
Military Service |
NA |
Read only |
Effective Dt |
NA |
Read only |
Order Ref# |
NA |
Read only |
Release Dt |
NA |
Read only |
Following are the fields displayed in Collateral sub sections.
Field Name |
Mandatory |
Type |
Comments |
Vehicle Details |
Primary |
NA |
Read only |
Asset Class |
NA |
Read only |
Sub Type |
NA |
Read only |
Asset class |
NA |
Read only |
Status |
NA |
Read only |
Type & Description |
Year |
NA |
Read only |
Make and Model |
NA |
Read only |
Body |
NA |
Read only |
Identification# |
NA |
Read only |
Registration# |
NA |
Read only |
Estimated Life |
NA |
Read only |
Address |
Address Number |
NA |
Read only |
City |
NA |
Read only |
State |
NA |
Read only |
Zip |
NA |
Read only |
Country |
NA |
Read only |
County |
NA |
Read only |
Usage Details (Life) |
Start |
NA |
Read only |
Base |
NA |
Read only |
Extra |
NA |
Read only |
Total |
NA |
Read only |
Charge Amt |
NA |
Read only |
Following are the fields displayed in Contract sub sections.
Field Name |
Mandatory |
Type |
Comments |
Contract Dt |
NA |
Read only |
Instrument |
NA |
Read only |
Due Day |
NA |
Read only |
1st Pmt Dt |
NA |
Read only |
Maturity Dt |
NA |
Read only |
Index |
NA |
Read only |
Index rate |
NA |
Read only |
Contract Margin rate |
NA |
Read only |
Contract Rate |
NA |
Read only |
Balloon Method |
NA |
Read only |
Balloon Amount |
NA |
Read only |
Loan Term |
NA |
Read only |
NA |
Read only |
Total Sale Price |
NA |
Read only |
Payment Amount |
NA |
Read only |
Final Pmt Amt |
NA |
Read only |
