Table of Contents
1. Preface
1.1 Prerequisites
1.2 Audience
1.3 Conventions Used
2. Installing WebServices Database Objects
3. Deploying Application Interface WebServices
3.1 Creating Data Sources for WebServices
3.2 Working with SSL
3.2.1 Steps to Import Certificates to keystore
3.2.2 Enable SSL Debugging
3.2.3 Connecting to service supporting only TLS protocol
3.3 Create RouteOne Credentials and System Policies
3.4 Deploying Webservices
3.4.1 Deployment of WebServices in Enterprise Manager
4. Configuring Weblogic Policy on WebServices
5. Verifying Successful Installation
5.1 Steps to Verify Successful Webservices deployment:
5.2 Steps to Verify Successful Interface (Route One) deployment:
6. Enable Logging
6.1 Enabling WebService Log
6.2 Enabling SQL Log for WebServices Component
7. Configuring RESTful WebService
7.1 Create Data Sources for RESTful WebService
7.2 Statement Timeout Configuration
7.3 OAuth Implementation
7.4 Deploy RESTful WebService
7.5 Deploy RESTful Credit Bureau WebService
7.5.1 Create Credentials and System Policies for Credit Bureau Interface
Appendix A: Configuration parameters
