A class is a specific type of component that you can build with certain attributes. You can build a fee class, for instance, with the attributes of a specific type of fee, such as Loan processing fees, Amendment Fees.
When building a fee class, you define certain attributes such as:
You can define the attributes of a fee class in the ‘Fee Class Maintenance’ screen, You can invoke the ‘Fee Class Maintenance’ screen by typing ‘LFDFEECL’ in the field at the top right corner of the Application tool bar and clicking the adjoining arrow button.
Before defining the attributes of a fee class, you should assign the class a unique identifier, called the Class Code and briefly describe the class. A description would help you easily identify the class.
Module
A fee class is built for use in a specific module. As a fee component would be applied on different basis amounts, in different modules.
Note
The Basis Amount Tags available would depend on the module for which you build the class.
Fee Type
The Rule Type identifies the type of component you are defining. The attributes applicable for a component depend on the Rule Type. Select the fee rule type as 'ICCF Rule' or 'Margin Rule'.
Fee Rule
If fee type is ‘ICCF Rule’, then you can get the fee rule details from 'Rule Master Definition’' Screen. If type is ‘Margin Rule’ then you can get fee rule details from 'Fee Rule Maintenance' screen.
Allowing Rule Amendments
If you would like to allow the amendment of a rule for a fee component, indicate this by selecting the ‘Allow Rule Amendment’ option.
Consider as Discount
While defining a fee class for either the loans or the bills module, you can indicate whether the fee component is to be considered for discount accrual on a constant yield basis.
If you select this option the fee received for the component is used in the computation of the constant yield and subsequently amortized over the tenor of the associated contract.
Payment Delay Days
The free period between 'Schedule Date' and 'Pay by Date'. Based on ‘Payment Delay Days’, the extended buffer period is provided for the fee payment. Hence, instead of the due date, fee payment is done at ‘Pay by Date’. ‘Payment Delay Days’ can be overwritten while creating a new product even if same is defined at Fee maintenance level. This field is optional.
Note
This is applicable for ICCF fee components. This functionality is NOT applicable to adhoc fees and adhoc expenses.
Accrual Required
If you select this option, the fee received for the component is accrued based the constant yield and subsequently amortized over the tenor of the associated contract.
Propagation Required
Select this option to indicate that the fee collected from the borrower must be passed on to the participants of the contract.
Fee Mode
The fee mode can be any one of the following:
Note
Advance fee is supported only if Basis Amount Tag is 'User Input'.
You can specify the fee components applicable to a product, in the fee Definition sub- screen of ‘Loans and Commitment Product Definition’ (OLDPRMNT) screen. Click ‘Fee’ from ‘Loans and Commitment Product Definition’ screen to invoke the ‘Fee Details’ sub-screen.
You should necessarily use a fee class to indicate the fee components applicable to a product. A fee class is a specific type of component that you can build with certain attributes.
To associate a fee class with a product, select the appropriate fee class from the list of classes defined specifically for the particular module of Oracle Lending. Click ‘Default From Class’ from the ‘Fee Details’ screen.
The attributes defined for the fee class are displayed. You have the option to change the attributes defined for the fee class to suit the requirement of the product you are creating.
You can associate several fee classes with a product. To add to the list of classes associated with the product click the ‘Add row’ button. Thereafter, select a class from the option list that is displayed and then click ‘Default From Class’.
To navigate between the fee classes associated with a product, you can use the icons provided for the same.
To disassociate a fee from the product, navigate to the class, and click the ‘Delete row’ button.
The fee component displayed in the Component field is not associated with the portfolios maintained under the product that you are defining.
Note
During fee accrual calculation, you can choose fee period basis to compute number of days for the fee schedule based on the option chosen during contract life cycle.
You can select the tenor basis upon which fee is computed over a schedule or fee period for a contract. You can select an option in while defining fee components for a product and the same is inherited to the contract. If required, you can change the default option.
You can select any of the following options:
Including the From Date
For all schedules, the period considered for fee calculation includes the start date and exclude the end date. Therefore, the value date of the loan is considered for fee calculation and the maturity date is excluded.
Including the To Date
For all schedules, the period considered for fee calculation excludes the start date and include the end date. Therefore, the value date of the loan is excluded, but the maturity date is included for fee calculation.
Including both From and To Dates
The period considered for fee calculation includes both the value date and the maturity date. This means the following:
Excluding both From and To Dates
The period considered for fee calculation excludes both the value date and the maturity date. This would mean:
A loan with a value of USD 400,000 is value dated 1st January 2019 and matures on 1st May 2019. The intermediate fee payment schedules are on 1st February 2019, 1st March 2019 and 1st April 2019.
Schedule |
Start Date |
End Date |
1 |
1st January 2019 (Value Date) |
1st February 2019 |
2 |
1st February 2019 |
1st March 2019 |
3 |
1st March 2019 |
1st April 2019 |
4 |
1st April 2019 |
1st May 2019 (Maturity) |
The periods considered for fee calculation for each schedule, for each of the four options, are arrived at as given below:
Include From Date
Schedule |
Days from |
Days To |
Days for Fee Calculation |
1 |
1st January 2019 |
1st February 2019 |
31 |
2 |
1st February 2019 |
1st March 2019 |
28 |
3 |
1st March 2019 |
1st April 2019 |
31 |
4 |
1st April 2019 |
1st May 2019 |
30 |
Include To Date
Schedule |
Days from |
Days To |
1 |
1st January 2019 |
1st February 2019 |
31 |
2 |
1st February 2019 |
1st March 2019 |
28 |
3 |
1st March 2019 |
1st April 2019 |
31 |
4 |
1st April 2019 |
1st May 2019 |
31 |
Include both From and To Dates
Schedule |
Days from |
Days To |
1 |
1st January 2019 |
1st February 2019 |
31 |
2 |
1st February 2019 |
1st March 2019 |
28 |
3 |
1st March 2019 |
1st April 2019 |
31 |
4 |
1st April 2019 |
1st May 2019 |
31 |
You would notice that consequent to the first schedule, this option would work in the same manner as the Include To Date option.
Exclude From and To Dates
Schedule |
Days from |
Days To |
1 |
1st January 2019 |
1st February 2019 |
30 |
2 |
1st February 2019 |
1st March 2019 |
28 |
3 |
1st March 2019 |
1st April 2019 |
31 |
4 |
1st April 2019 |
1st May 2019 |
30 |
You would notice that consequent to the first schedule, this option would work in the same manner as the Include From Date option.
A new fee basis methods are introduced to support fee calculations based on working days and 365.25 as denominator for leap and non-leap year.
Different values for the numerator basis are as explained below:
Different values for the denominator of the fee basis are as explained below.
Note
In case an ad hoc holiday is declared, then the system does not recalculate the fee as part of ad hoc holiday processing. Accrual adjustment for the unaccrued portion happens on the schedule end date.
This value is defaulted from 'Fee Class Maintenance' screen. If required, you can edit during product creation or modification.
From the Loan and Commitment - Contract Input (‘OLDTRONL’) screen, click ‘Fee’ to invoke the ’Fee Details’ sub-screen.
When the details of a contract are captured, the fee components defined for the product is automatically applied. However, while processing a contract, you can change certain attributes of the fee component.
The contract reference number of the contract you are processing is displayed on this screen.
The fee components specified for the product to which you have linked the contract is displayed in tabular columns.
Component
The name given to the fee component is displayed here. The attributes defined for this component is displayed in the subsequent fields.
For a fee component the following details are displayed:
It is applicable for only Advance Fee type and for IRR computation.
Accrual Fee
In the Accrual Fee Class maintenance screen (LFDACFCL), you maintain accrual fee related details.
In the Product Definition screen, you can get these details and link it to the 'Accrual fee’.
The accrual fee will not be defaulted to the contract. You need to go to 'Amortization Fees' screen (LFDACFIN).
Note
If both the options ‘Consider as Discount’ and ‘Accrual Required’ are selected, the fee amount is considered for Internal Rate of Return calculation.
Fee Period Basis
During periodic accruals for a contract, fee accruals also depend on the fee period basis defined for the contract.The fee period basis determines whether the fee calculation for schedules takes into account the schedule start dates or the end dates, or both, or whether it excludes both.
Note
For contracts booked with the fee period basis as ‘Include To Date’ and ‘Include To and From Date’, the maturity date is considered for fee calculations. However, accrual is posted in previous working day prior to maturity date and there is no accrual on maturity date.
After providing the fee schedule details, ‘Payment Schedule Summary’ displays the ‘Pay By date’ based on the parameter ‘Payment Delay Days’.
Type |
Component |
Start Date |
Amount |
Payment |
Fee_Comp1 |
15 Jun 2018 |
1000 |
Payment |
Fee_Comp2 |
15 Jun 2018 |
1000 |
For advance and arrear fee components, fee liquidation takes place on 20th June 2018 instead of 15th June 2018 as a result of payment delay days.
Due Date |
Component |
Total Amount Due |
Pay By Date |
15 Jun 2018 |
Fee_Comp1 |
1000 |
20 Jun 2018 |
15 Jun 2018 |
Fee_Comp2 |
1000 |
20 Jun 2018 |
You can manually liquidate the fee schedules defined for fee components in the ‘Fee Liquidation’ screen. You can liquidate even future dated schedules through this screen.
You can view manual and auto liquidation fee details here. You can query and view the fees that are reversed either by manual or auto fee liquidation method.
You can invoke the ‘Fee Liquidation’ screen by typing ‘OLDFEELQ’ in the field at the top right corner of the Application tool bar and clicking the adjoining arrow button.
To liquidate a fee component schedule, do the following:
After capturing the ‘Amount Paid’, click the ‘Allocate’ button. The system allocates the amount against each schedule and update the ‘Amount Paid’ against each schedule in the ‘Payment Breakup For – (Component Name)’ section of the screen.
You can perform selective liquidation of the fee components as the payment happens, if required. For this, you need to specify the amount in the Amount Paid field for the fee component which needs to be liquidated. The System liquidates only those components for which Amount Paid value is the same as Amount Due. You cannot perform partial payments here.
For those components which are not part of the current fee liquidation, you need to specify the Amount Paid as zero.
