2. OBCL Integration
2.1 Common Core Maintenances
The following are the common core maintenance that needs to be completed for FCUBS, Payments, and ELCM systems integration.
2.1.1 Configuring Accounting System for Host Code
You can configure the accounting system using host code in the ‘Host Parameter’ screen.
To invoke this screen, type ‘PIDHSTMT’ in the field at the top right corner of the application toolbar and click the adjoining arrow button.
Specify the following details
Host Code
Specify the host code.
Host Description
Specify the brief description for the host.
Accounting System Code
Specify the accounting system code.
Payment System
Specify the payment system.
ELCM System
Specify the ELCM system.
OBCL Integration System
Specify the external system. For example, OLINTSYS
2.1.2 Maintaining Integration Parameters
You have to maintain integration parameters for ‘External LOV’ and ‘ELCM/Payment/OL Utilization’. This maintenance must be done for all branches. This maintenance is done through ‘Integration Parameters Maintenance’ screen.
To invoke this screen, type ‘IFDINPRM’ in the field at the top right corner of the application toolbar and click the adjoining arrow button.
Example of Integration Parameter Maintenance screen for Payments
Example of Integration Parameter Maintenance screen for ELCM
Example of Integration Parameter Maintenance screen for OBCL
You can specify the following fields in this screen:
Branch Code
Select the branch code for which the parameters are to be maintained from the adjoining option list.
Description
A brief description of the branch code is displayed.
External System
Select the external system for which the parameters are to be maintained, from the adjoining option list.
Description
A brief description of the external system is displayed.
Offset Transaction Code
Select a transaction code for the offset entry from the adjoining option list. The adjoining option list displays all valid transaction codes available in the system. You can select the appropriate one
Offset Amount Tag
Select an amount tag for the offset entry from the adjoining option list. The adjoining option list displays all valid amount tag available in the system. You can select the appropriate one
Amount Block Validation
Select this check box to validate the amount block. If the amount block reference number is sent with the transaction details then the accounting will be invoked after the release of amount block.
Offset Required
Select this check box if an offset entry is required. If this check box is selected, then ISB GL will be resolved based on branch, currency, function id and external system. If the check box is not selected, then it is expected that external system sends the balanced entry
Offset Netting Required
Select this check box if offset netting entry is required. If this check box is selected, then the consolidated entries will be built. Offset amount tag is picked from the maintenances. If this check box is not selected, then individual entries are built.
Allow Force Post
Select this check box to suppress all the overrides after posting transactions.
You need to maintain the integration parameters for the following:
External Lov
Note
Rest Service need not be maintained for OBCL.
ELCM Utilization/Payment/OBCL
2.2 Oracle Lending and Loan Syndication module integra­tion with CASA
The integration of OLand LS module with CASA enables banks to do the following:
2.2.1 Scope
This section describes the activities that take place in each system and its impact on the other.
2.2.2 Integration Scope with FCUBS Co-deployed with OL and LS module
If FCUBS is co-deployed with OL and LS module, then web service call is used to check the available balance.
2.2.3 Integration Scope without FCUBS Co-deployed with OL and LS module
The following are the integration activities that take place in Oracle Corporate Lending.
ECA Request for Auto Liquidation
ECA Handling during Auto Rollover
ECA Handling for Manual liquidation
ECA Handling for Manual Rollover
Account Interface and Handoff
Force debit Components
Tax, Fee and charge which are associated with liquidation/rollover event is debited from the account without ECA.
Forward Liquidation
2.2.4 ECA handling scenarios for Corporate Loan Liquidation
2.2.4.1 Single CASA Account with Full liquidation
Component
Amount Due
Account
ECA Approved Amount
Principal
50000
CASA1
50000
Interest
10000
CASA1
10000
2.2.4.2 Different CASA Account with Full Liquidation
In this case OL and LS module generates a single ECA request that contain details amount due from two accounts.
Component
Amount Due
Account
ECA Approved Amount
Principal
50000
CASA1
50000
Interest
10000
CASA2
10000
2.2.4.3 GL Account used for Liquidation
In this case request is not sent to ECA system, however it is marked as approved by OL and LS module in ECA tables and it proceeds with liquidation processing.
Component
Amount Due
Account
ECA Approved Amount
Principal
50000
GL1
50000
Interest
10000
GL2
10000
2.2.4.4 One CASA and GL Account used for Liquidation
In this ECA request is sent only for CASA account and the GL it is marked as approved automatically. Liquidation processing happens irrespective of whether the ECA request is successful for the CASA account.
Component
Amount Due
Account
ECA Approved Amount
Principal
50000
CASA
50000
Interest
10000
GL1
10000
2.2.4.5 Single CASA Account with Partial Liquidation
In this case, the system proceeds with allocating the approved amount based on liquidation order specified at the product level.
Component
Amount Due
Account
ECA Approved Amount
Principal
50000
CASA1
50000
Interest
10000
CASA1
10000
2.2.4.6 Manual Liquidation with Single CASA or Multiple CASA Account
In this case ECA request is sent with Partial allowed as ‘N’, hence the request is marked as failure if the full amount requested is not available.
Component
Amount Due
Account
ECA Approved Amount
Principal
50000
CASA1
50000
Interest
10000
CASA1
10000
2.2.5 Prerequisites
2.2.6 Prerequisites in Oracle Lending and Loan Syndication
The prerequisites for this integration are as follows.
2.2.6.1 Parameter Setup
2.2.6.2 Maintenances
Complete the following maintenances in Oracle Banking Corporate Lending to enable the integration.
Queue Name
Purpose
ECA_REQ_OUT
Request to external system
ECA_RES_IN
Response from external system
Table Name
Purpose
COTB_ECA_QUEUE
ECA request details
COTB_ECA_QUEUE_DETAIL
ECA request components details
Note
The following data in OL and LS module must be in sync with those maintained in external system.
2.3 Integration Process of OL and LS module CASA
2.3.1 Viewing ECA Queue Summary Details
ECA Queue Summary screen contains details on the transactions between OL/LS and external system.
To invoke this screen, type PISECAQU’ in the field at the top right corner of the application toolbar and click the adjoining arrow button.
You can search records based on the following parameters:
Click ‘Search’ button with or without entering any of the above search parameters. All records matching the search criteria are displayed. To view a particular record double-click on the desired record displayed in the list of records. The details pertaining to each record is displayed.
2.3.2 Viewing External Accounting Log
'External Accounting Log' screen contains OL/LS transaction details with External Accounting System linkage.
To invoke this screen, type ‘OLSEACLG’ in the field at the top right corner of the application toolbar and click the adjoining arrow button.
In this screen, you can view the request sent from OL and LS module and view the response (received for the request sent) from the External Accounting System.
2.4 Integration with FCUBS for 360 Degree Customer View
Using 360 Degree Customer View, you can query customer limits, account statements, view settlement balances contracts, view assets and liability balances, view loans, commitments and syndication contract details of the customer. You can also view summary of loans, commitments and syndication contract details of the customer. The 360 degree customer view facilitates easy and total view of the customer details and reduces customer service complexities.
FCUBS pulls the required data from OBCL by using the below operation code.
2.4.1 Summary Tab
The ‘Summary’ tab displays the OBCL loan contracts of the selected customers along with the details.
2.4.2 Loans Tab
In an FCUBS – OBCL integrated environment, click ‘Loans’ tab in ‘360 degree customer view’ screen to view the details for OBCL contracts in Loan details/Commitment and Syndicate Loan Details block for the selected customer.
The loans details are classified as follows:
Under each of the loan details, the system displays the following:
2.4.3 Component Details Button
You can view details about the components linked to an account in the ‘Component Details’ screen. You can invoke this screen by clicking the ‘Component Details’ button in the ‘360 Degree Retail Customer View’ screen.
You can view the following component details:
Here you can view the following:
2.5 OBCL Integration with Payments for SWIFT messages
The integration between Oracle Banking Corporate Lending and Oracle Banking Payments enables you to generate SWIFT messages (MT103 and MT202) for Corporate Lending through Payments module.
2.5.1 Scope
SWIFT payment message MT103 and MT202 are supported. If transfer type is ‘Customer Transfer’, then MT103 payment message is generated. If transfer type is Bank Transfer, then MT202 payment message is generated.
2.5.2 Integration Process of OBCL and Payments
For OL/LS with Payments integration, you need to perform the following:
In Loan Syndication, SWIFT messages are triggered based on the components like PRINCIPAL, INT_LIQD, and FEE_LIQD.
For Loans - Payments integration, beneficiary charges on payment is sent as part of Single Payout Service (SPS OUT) and also accounting entries are displayed that are handed off from OBPM in Contract Online Screen (Events > Accounting Entries tab).
2.5.2.1 Processing of Outgoing SWIFT Messages
Steps involved in processing of outgoing SWIFT messages.
2.5.2.2 Viewing Payment Integration Request/Response Messages
You can view Oracle Lending and Loan Syndication contracts with payment integration in ‘Payment Outgoing Browser’ screen.
To invoke this screen, type ‘OLSPMTBR’ in the field at the top right corner of the application toolbar and click the adjoining arrow button.
In this screen, you can view the request sent from Oracle Lending/Loan Syndication module and view the response (received for the request sent) from the Payments module.
Note
To search outgoing payment details, for LB side use DD Contract Reference Number and for LP side use Contract Reference Number
2.5.2.3 Maintaining ISB GL
You can invoke the ‘ISB GL Maintenance’ screen by typing ‘OLDISBGL’ in the field at the top right corner of the application tool bar and by clicking the adjoining arrow button.
You can specify the following field information in this screen. A brief description of each value updated in the fields appearing in this screen, is displayed by the system.
External System
Select the external system from the adjoining option list.
Module ID
Select a valid module code from the adjoining option list.
Transaction Currency
Select a valid currency code from the adjoining option list.
Transaction Branch
Select a valid transaction branch code from the adjoining option list
Product Code
Select a valid product code from the adjoining option list.
Function ID
Select a valid function ID from the adjoining option list.
ISB GL
Select a leaf General Ledger from the adjoining option list.
2.6 OBCL - ELCM Integration
The integration between OBCL and ELCM enables you to view the Oracle Lending and Loan Syndication contracts with ELCM linkage in a sync or async mode.
2.6.1 Scope
If you are booking a Oracle Lending and Loan Syndication contracts with ELCM linkage in a sync or async mode, the OLTB_REQ_MASTER table is updated with records. You can view these records in the External Limit Summary screen.
2.6.2 Prerequisites
OLTB_REQ_MASTER table must have value.
2.6.3 Integration Process of OL and ELCM
Forward Init
As part of loan batch process for contract marked for initiation on processing date, the system picks and processes the 'FWDINIT' on processing date.After processing ‘FWDINIT’, the system sends a request to ELCM system (if any limits are linked to contract) for Utilization of contract amount.
After success response from the ELCM system, the system authorizes the ‘FWDINIT’ process.For failure response from ELCM system, the system roll backs the ‘FWDINIT’ process (after roll back contract details are logged into exception table)
Forward VAMI
As part of loan batch process for contract marked for VAMI on processing date, the system picks and processes the ‘FWDVAMI’ on processing date. After processing FWDVAMI, the system sends a request to ELCM system (If any limits are linked to contract) for Utilization/De-Utilization of contract amount.
After success response from the ELCM system, the system authorizes the VAMI process. For failure response from ELCM system, the system roll backs the FWDVAMI process (after roll back contract details are logged into exception table)
Auto Liquidation and Forward Liquidation
As part of loan batch process for contract marked for Liqudation on processing date, the system picks and processes the liquidation on processing date. After processing the system sends a request to ELCM system (If any limits are linked to contract) for Utilization/De-Utilization of contract amount.
After success response from the ELCM system, the system completes the liquidation process. For failure response from ELCM system, the system roll backs the liquidation process (after roll back contract details are logged into exception table)
ACCRUAL
As part of loan batch process for contract marked for ‘ACCRUAL’ on processing date, the system picks and processes the ‘ACCRUAL’ process on processing date. After processing accrual process, the system sends a request to ELCM system (If any limits are linked to contract) for Utilization/De-Utilization of contract amount.
After success response from the ELCM system, the system authorizes the accrual process. For failure response from ELCM system, the system roll backs the ‘ACCRUAL’ process (after roll back contract details are logged into exception table).
2.6.3.1 Viewing External Limit Summary Details
External Limit Summary screen contains details of the Oracle Lending and Loan Syndication transactions with ELCM linkage.
You can approve, resend, reject, and authorize the Oracle Lending and Loan Syndication transactions using this screen.
To invoke this screen, type OLSEXLMT’ in the field at the top right corner of the application toolbar and click the adjoining arrow button.
2.6.3.2 Viewing Action Log of External Limit Queue
The action log screen displays the details of actions performed in the External Limit Queue screen.
To invoke this screen, type ‘OLDQAHIS’ in the field at the top right corner of the application toolbar and click the adjoining arrow button.
This screen displays the action log of the following fields along with ‘Message Id’ and ‘Process Sequence Number’.
2.6.4 Viewing Service Log Details
You can view service log using ‘View Service Log’ screen. To invoke this screen, type ‘OLDSRLOG’ in the field at the top right corner of the application toolbar and click the adjoining arrow button.
2.7 Common Integration Details Summary screen
You can view the contract integration status of various modules (OL, LB, LP, FC, TL) of OBCL and also connect to integration screen of different product processors.
You can invoke the ‘OL Interface Summary’ screen by typing ‘OLSCNSTS’ in the field at the top right corner of the Application tool bar and clicking the adjoining arrow button.
To view the details, query using any of the following fields.
You can select the specific contracts and then click their respective product processor sub-system.
After going to the integration screen, you can re-process and verify the logs of various contracts.
For more information on CD Details - Transaction Log (OLSIFCD), refer to FCUBS Corporate Deposit -OBCL Integration User Guide.
2.8 OBCL Integration with FCUBS for EAC
The integration between OBCL and UBS enables to handle the External Account Check (EAC) and customer status for the counterparty of the contract in synchronous mode.
2.8.1 Scope
The customer accounts are validated as part of EAC process during contract booking, VAMI, payment, rollover, and so on. The following are the list of operations supported.
Operation
Online/Batch
Customer Status
EAC Process
Contract Booking
Online
Yes
Yes
Contract Amendment
Online
Yes
Yes
Value Date Amendment
Online
Yes
Yes
Rollover
Online
Yes
Yes
Payment
Online
No
Yes
Manual Disbursement
Online
Yes
Yes
Linkage Amendment
Online
Yes
No
Fee Liquidation
Online
Yes
Yes
Split Reprice
Online
Yes
Yes
Consolidate Reprice
Online
Yes
Yes
Consolidate Rollover
Online
Yes
Yes
FWD INIT
Batch
Yes
Yes
FWD VAMI
Batch
Yes
Yes
Auto Disbursement
Batch
Yes
Yes
Auto Rollover
Batch
Yes
Yes
Auto LIQD
Batch
No
Yes
2.8.2 Prerequisites
  1. For EAC, OBCL uses ‘CreateEACAccVal’ service available in UBS. This service validates the customer and customer account provided in the request.
  2. To validate the customer status of the counterparty, OBCL uses the ‘QueryCustomer’ service in UBS and validate the frozen/deceased/where about unknown status.
  3. A parameter ‘OBCL_EXTERNAL_ACC_CHK_REQ’ is introduced in CSTB_PARAM table. By default this flag is set to ‘Y’. If this flag is enabled, then the system verifies EAC check and customer status during transaction online/batch.
  4. Static INC to support EAC in OLTM_SERVICE_PARAMS and OLTM_SERVICE_REQ_FORMAT tables
  5. Integration maintenance for EAC in OLDINPRM
2.8.3 Integration Process of EAC and Customer Status
EAC process
Customer Status
Inactive Customer Status
If a customer does not have any single contract active, then an update is sent to FCUBS using "QueryCustSts" service. "QueryCustSts" service is consumed by OBCL to handoff the customer status (Active/Inactive) to FCUBS system.
