Go to primary content
Oracle® Communications Diameter Signaling Router Policy and Charging Application
Release 8.4
F12292
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Exporting a network element configuration file
The network element Export button generates an installation script file used for configuration purposes. Use this procedure to export the configuration parameters of a network element:
  1. Click Configuration > Networking > Networks.
  2. Select the target network element tab.
    Network elements are presented in tabular form. If the target network element is not visible in the available screen space use the scroll right/left buttons located below the tool bar area and to the right or left of the visible tabs.
  3. Click Export.
    Open or save the configuration file from the screen. By default the name format of the output file is NE_<yyyymmdd>_<hhmmss>_<zone>.xml. You may change this as needed.
