Cycle Web Properties
| Properties | Mandatory | Data Type | Format | Size | Default | Allowed Values | Description |
application.buildversion |
NUMBER | nn.nn.nn.nn | 11 |
Defines the build version of the application on the login screen |
application.databaseType |
YES | Alphabetic | Fixed List | <=10 |
Value: SqlServer, Oracle, DB2 |
The system-wide default database type. Used for multiple query support functionality and JDBC interaction. |
application.default.buildversion |
Only used if the property, application build version, is set and begins with ${. Defines the build version of the application on the login screen. |
application.defaultCurrencyCode |
YES |
Value : |
The default currency should be added as a CurrencyCode in the AsCurrency table. |
application.enablePlanGroup |
Boolean | 2 | No |
Value: No |
If included, should be set to No. |
application.enablePostAssignmentValidation |
Boolean | <=3 | No |
Value: Yes, No |
Determines whether or not to execute the PostAssignmentValidateExpressions business rule during activity processing. |
application.enableProduct |
Optional Value: Yes, No |
Allows application to use the Products hierarchy in configuration. System default is No. |
application.mathApplicationCallbackBll |
YES | AlphaNumeric | Java Class FQN | <=255 |
Value: com.adminserver.pas.bll.PasCallBackBll |
Warning: Internal PAS property. Class used to carry DataRetriever and RateRetriever to be used by the Math engine. |
application.mode |
YES | Alphabetic | Fixed List | <=15 |
Value: DEVELOPMENT, PRODUCTION |
Development mode is where configuration changes are allowed. Configuration data is not cached. Production mode is where configuration change is a new release and JVM is restarted when it is changed. Configuration data is cached. |
application.refreshMasks |
Positive Integer | nnnnnn | <=6 | 0 |
Note: For use in application.mode = DEVELOPMENT Time in milliseconds to refresh mask configuration Value <= 0 will never refresh. |
application.resourceCacheTimeout |
Integer | +/-nnnnn | <=6 | -1 |
Time to cache translations, in minutes, before checking data source for updates. For value < 0, never check for updates. For value = 0, always check for updates. For value > 0, check for updates after specified minutes have passed. Warning: Should be set to -1 in a Production environment. |
database.nlscomp |
Alphabetic | Fixed List | <=15 | LINGUISTIC |
Info: Refer to https://docs.oracle.com for the version of Oracle used for a current listing of values you can specify for this parameter.
It applies when the system is using the Oracle database. It provides the NLS_COMP setting that the system should use in the database session in order to perform Case/Accent insensitive search. Default value if not specified is LINGUISTIC. The DBA should setup appropriate indexes for this property and suggest the setting value to use based on the client installation's language preference. |
database.nlssort |
Alphabetic | Fixed List | <=25 | BINARY_CI |
Info: Refer to Database Globalization Support Guide and other related documents at https://docs.oracle.com or a current listing of values you can specify for this parameter |
It applies when the system is using the Oracle database. It provides the NLS_SORT setting that the system should use in the database session in order to perform Case/Accent insensitive search. Default value if not specified is BINARY_CI. The DBA should setup appropriate indexes for these properties and suggest the setting value to use based on the client installation's language preference. |
dataIntake.enabled |
YES | Boolean | <=5 |
Value: true or false |
Determines whether or not data intake background process for processing data intake files should be created. |
dataIntake.gridCapacity |
Positive Integer | nnnn | <=4 | 500 |
Maximum number of record groups that can be processing simultaneously in the grid for DataIntake processing. Note: Currently this property value is not used by the system. |
dataIntake.recordGroupSize |
Positive Integer | nnnnn | <=5 | 10 |
The number of individual intake records to bundle together for processing as a single task in the grid for DataIntake processing. |
dataIntake.userName |
YES | AlphaNumeric | <=255 |
The primary company used for processing data intake related rules and transactions is the primary company of this user. |
datasource.type |
YES | Alphabetic | 4 |
Value: jndi |
The data source type. jndi relies on jndi names ADMINSERVERDS, ADMINSERVERRESOURCEDS ADMINSERVERSEARCHDS and ADMINSERVERREADONLYDS in the application server for a datasource connection.. |
debug.identifyTranslator |
Value: Yes, No |
Writes comments for every line identifying the translator (line number) that generated that part of code. debug.SaveGeneratedClass needs to be set to Yes. Note: Only use in a Non-Production environment. |
debug.SaveGeneratedClass |
Value: Yes, No |
Generated source code while processing will be saved in the directory specified. Note: Only use in a Non-Production environment. |
debug.SaveGeneratedClassDirectory |
AlphaNumeric | File Path | <=255 |
Directory where the generated source code should be saved.debug.SaveGeneratedClass needs to be set to Yes. Note: Only use in a Non-Production environment. |
document.crystalConnectionCount |
Only valid for generating Crystal documents. Sets allowable connections. Should be set to a number not greater than the number of CR licenses. |
document.documentGeneratorUrl |
AlphaNumeric | URL | <=255 |
The url for the DocumentGenerator webservice url for generating documents. |
document.documentPath |
Directory where report templates are stored. |
document.generatedDocumentRootPath |
Directory where generated documents are saved. |
entityLock.enabled |
Value: Yes, No |
Determines whether or not business entities should be locked while processing activities in sequence during DataIntake. System Default is No |
entityLock.timeout |
Positive Integer | nnnnnnnn | <=8 | 500 |
Time in milliseconds to wait before trying to reacquire lock on a business entity. |
entityLock.tryCount |
Positive Integer | nn | <=2 | 5 |
Number of attempts made to acquire a lock |
extensions.config |
Directory where extensions.xml for extension configuration is stored. |
grid.taskSubmissionThreadPoolSize |
YES | Positive Integer | nnnnn | <=5 |
The number of threads dedicated to submit tasks to the grid for processing. Increasing this number can speed up how quickly tasks are distributed to the grid. See cycle documentation for additional details. |
jndi.connectionFactoryName |
YES | AlphaNumeric | <=50 |
ConnectionFactory JNDI name to connect JMS server. Recommended Value: IntakeConnectionFactory. See Data Intake document for additional details. |
jndi.queueName |
Queue JNDI name to send message to JMS server destination. Recommended Value: DIQueue. See Data Intake document for additional details. |
jpa.databasePlatform |
YES | Alphabetic | Fixed List | <=255 |
Value: org.eclipse.persistence.platform.database.SQLServerPlatform org.eclipse.persistence.platform.database.OraclePlatform org.eclipse.persistence.platform.database.DB2Platform |
Property that determines which JPA DatabasePlatform to use with EclipseLink. |
jpa.showSql |
Boolean | <=5 | False |
Optional Value: True, False |
Shows information in the application's log/console for all SQLs executed using JPA. Warning: Only use in a Non-Production environment. |
NamedStoredProceduresRateBll.config.filePath |
XML file that specifies the stored procedure to be execute for specific rate groups. If using this, leave rateRetriever.className blank. |
rateRetriever.className |
Fully qualified extension class name to retrieve rates for all rate groups. If using this, leave NamedStoredProceduresRateBll.config.filePath blank. |
scheduledValuation.batchSize |
YES | Positive Integer | nnnnnn | <=6 |
This is the batch size for processing scheduled valuation. See cycle documentation for additional details. |
scheduledValuation.period |
This is the number of seconds that the scheduled valuation monitor task will sleep before waking up and checking on the status of queued tasks. See cycle documentation for additional details. |
scheduledValuation.groupSize |
Determines the number of Scheduled valuation items to group together and execute on a single thread in the cluster. |
search.field.text.caseInsensitive |
Info: For use when the system is running on the DB2 database platform. Search screens have the ability to perform their search in a case insensitive manner. A value of True makes the system use case insensitive searches. . |
transaction.manager |
YES | Alphabetic | Fixed | 3 |
Value: jpa |
Data source transaction manager. |
webservice.allowHashedPassword |
Value: Yes, No. |
Determines if web services can be invoked with hashed passwords. System Default is No. |
workManagerName |
YES | AlphNumeric | <=50 |
A Work Manager defines a set of request classes and thread constraints that manage work performed by Server instances Recommended Value: wm/default. See Data Intake document for additional details. |
WriteValuationXML |
Boolean | <=3 | Yes |
Value: Yes, No |
Determines whether or not to write valuation XML to the AsValuationXml table for activities that run valuation. System Default is Yes. |
Value: Yes, No |
application.configurationCacheTimeout |
Time to cache business rules, in minutes, before checking data source for updates. For value = 0, never check for updates. For value > 0, check for updates after specified minutes have passed. |
application.encryptDecryptFilePath |
YES | AlphaNumeric | File Path | <=255 |
Required Value: Text (AbsolutePath With File Name) |
Value of this property should be absolute path with file name, where EDKeyValue.dat exists. This .dat file holds the partial Encrypt/Decrypt Key for encryption/decryption of the data. This file comes as part of distribution zip. File should have read permissions. |
| cycle.cleanup | YES | Boolean | true |
Cycle Clean UP - Clean the preexisting cycle information for the OIPA Schema. |
| cycleworkflow.enabled | Boolean | No |
Value: Yes or No |
This property derives the workflow feature. This must be set to Yes if one wants to enable the workflow. |
| errorReporting.verbose | Boolean |
verbose reporting This property allows verbose reporting. |
| metrics.timing | Boolean | Yes |
Value: Yes, No |
This property will track high lever timing for activity processing. |
| dataIntake.period | Positive Integer | nnnnn | The number of seconds to delay between polling the database for records that require processing. | ||||
| dataIntake.reProcessingLimit | Positive Integer | nnnnn | 50 |
Defines reprocessing limit - Used by addRecord, completeLoading and processMessage, to check whether beginLoading for the given fileID is processed or saved to the database. - Used by completeLoading, to wait and check if addRecords are actively being processed. |
| dataIntake.yieldTimePeriod | Positive Integer | <=4 | 1000 |
Defines DI Task thread yield time limit - Used by addRecord, completeLoading and processMessage to check whether beginLoading for the given fileID is processed or saved to the database. - Used by completeLoading to wait and check if addRecords are actively being processed. |
| dataIntake.addRecordCorePoolSize | YES | Positive Integer | nnnn | 50 | This property defines the number of threads created by the pool to save add records. | ||
| rateCriteriaConfiguration.enabled | Boolean | No |
Value: Yes, No |
This property allows Rate Criteria Columns Configuration. | |||
| requirement.service.corePoolSize | YES | Integer | Thread pool size to perform a task in parallel. Don't remove this even if your not using this property. | ||||
| cycle.batchSize | YES | Positive Integer | nnnnn | <=5 | 50 | The maximum number of Cycle tasks that are processed in the Cycle Grid. | |
| cycle.period | YES | Positive Integer | nnnnn | <=5 | 5 | The number of seconds that the Cycle web will wait before checking for additional work. | |
| cycle.groupSize | YES | Positive Integer | nnnnn | <=5 | 10 | Determines the number of Cycle work items to be grouped together and run on a single thread in the cluster. | |
| cycle.updateStatsRun | Boolean | No |
Value: Yes, No |
Specifies whether statistics should be updated. | |||
| cycle.updateStatsDegree | Positive Integer | nnnnn | nnnnn | 0 | >=1 | Specifies the degree of parallelism. Applies only to Oracle. | |
| application.X-Frame-Options | AlphaNumeric | Fixed List / Free text Parameter | <=255 | DENY |
Value: DENY, SAMEORIGIN, ALLOW-FROM <url> |
To support against CSRF attacks. Applies only to IE8 and above. If this property is not specified, no system protection against CSRF is offered. DENY => Any application page is not allowed to be framed. SAMEORIGIN => Application is allowed to be framed in any page coming from the same root url. SAMEORIGIN means same root URL. ALLOW-FROM <url> => Application is allowed to be framed from any page coming from the root URL specified in the property. |
| application.AccessControlAllowOrigin | No | AlphaNumeric | Fixed List / * | <=255 | No |
Value: <url>,* |
To enable the web server for making the cross domain requests. <url> => list of allowed domains, which are making service calls. * => This allows access to all domains, but using this wildcard character is considered overly permissive policy. |
| jmx.notification.entities | AlphaNumeric |
Values: cycle, activity, activityprofiling, outboundeventpush, serviceauditlogging |
Here we can have one or more values define. Each value must be comma separated. | ||||
| dataIntake.corePoolSize | Yes | NUMBER | 50 |
Value: 50 |
The number of threads configured for Message Listener to submit in parallel. | ||
| cors.allowGenericHttpRequests | No | Boolean | true |
If property value is to true generic HTTP requests will be allowed to pass through the filter else only valid CORS requests will be allowed. | ||
| cors.allowOrigin | No | Alphanumeric | Fixed List / * | * (asterisk) | * or Origin list separated with space | By Default, all origins are allowed. This property allows to provide list of origins allowed to make cross domain requests. Using * (asterisk) means allowing any origin. | |
| cors.allowSubdomains | No | Boolean | false |
If this property value is set to true, allow requests from any origin which is a subdomain origin of the allowed origins ( cors.allowOrigin ). | ||
| cors.supportedMethods | No | Alphanumeric | Fixed List, Comma separated | GET, POST, HEAD, OPTIONS, PUT, DELETE | GET, POST, HEAD, OPTIONS, PUT, DELETE | HTPP supportedMethods This property defines through Access-Control-Allow-Methods header, list of HTTP methods allowed for the request. for Example, if GET is added in supportedMethods then only GET cross-origin requests is allowed. | |
| cors.supportedHeaders | No | Alphanumeric | * (asterisk) | This is any custom header set by the application through XMLHttpRequest.setRequestHeader() for example Content-Type, X-Requested-With | |||
| cors.exposedHeaders | No | Alphanumeric | empty list | This is list of headers which are safe to be exposed in the response and this information is sent through Access-Control-Expose-Headers for example , Custom-Exposed-Header-1 , Custom-Exposed-Header-2 | |||
| cors.supportsCredentials | No | Boolean | true |
This property value identifies in constructing Access-Control-Allow-Credentials header. | ||
| cors.maxAge | No | Integer | -1 | This property indicates how long the preflight request can be cached by the web browser; this value is mentioned in seconds. for example, if the value is mentioned as 3600 means browsers should cache preflight request for 1 hour. | |||
| isSharedCluster | YES | Boolean | false |
Value: false |
Specifies if Cycle and OIPA are configured to run on the same Coherence ClusterDefault value is false. Set it to true if they share the same Coherence Cluster |
| oipa.url | YES | AlphaNumeric | http://localhost:9090/PASJava/ | This Property is used to connect to OIPA server from Cycle. | |||
| application.archivalInUse | YES | Yes | 'Yes' or 'No' | This property determines whether the archival functionality is in use by the user. |
