Membership Element
The <Membership> element triggers the evaluation of class memberships for all participants in a Group Customer and related Group Customers or for a Policy's Primary Member client. This is applicable to a Group Customer level activity or Policy level activity. The following describes the general behavior:
If configured in a Group Customer level activity and a ClientGUID is provided, membership evaluation is limited to all participants of the Group Customer identified by the <ClientGUID> element.
If the <ClientGUID> element is not configured in a Group Customer level activity, membership evaluation is processed for all participants of the activity's Group Customer and all its related Group Customers.
If the element is configured in a Policy level activity, membership is evaluated for the Policy's Primary Member role and to all related Group Customers the member is associated with.
The results of membership may be persisted in the AsClassMembership table.
The results of membership will be displayed in a Membership tab in Activity Details.
Element |
Parent Element |
Attribute |
Description |
<Membership> |
<Transaction> |
Optional: This element triggers Membership processing for the Activity. |
<ClassGroup> |
<Membership> |
Required, Repeatable: This contains the definition for evaluating membership of a Group Customer or membership of a Primary Member in its Group Customer. An activity may contain this element multiple times for the multiple memberships various clients may have. |
<ClassGroup> |
TYPE |
Required: This identifies the class group type by its code value. The definition in the parent element applies to this class group type. Values:
<ClassGroup> |
DISPLAYMEMBERSHIPCLASS |
Optional: Indicates which class membership types to display. Values:
<ClientGUID> |
<ClassGroup> |
Optional: This element identifies the Group Customer by its ClientGUID for which membership will be evaluated. If this element is not configured in a Group Customer activity, membership evaluation is processed for all participants of the activity's Group Customer and all its related Group Customers. If the element is configured in a Policy level activity, membership is evaluated for the policy's Primary Member role and for all related Group Customers the member is associated with. Values:
<WriteMembership> |
<ClassGroup> |
Optional: Indicates the persistence of Membership records in the database. Values:
<EffectiveFromDate> |
<ClassGroup> |
Optional: Provides the effective starting date of the Membership. The value must be a valid date. Values:
<EffectiveToDate> |
<ClassGroup> |
Optional: Provides the effective end date of the Membership. The value must be a valid date. Values:
XML Schema
<Transaction> ... <Membership> <ClassGroup TYPE="[class group type]" DISPLAYMEMBERSHIPCLASS="[class membership type]"> <ClientGUID>[field | variable]</ClientGUID> <WriteMembership>[Yes | No]</WriteMembership> <EffectiveFromDate>[system date | date field]</EffectiveFromDate> <EffectiveToDate>[system date | date field]</EffectiveToDate> </ClassGroup> <ClassGroup>...</ClassGroup> </Membership> ... </Transaction>
XML Example
<Transaction> ... <Membership> <ClassGroup TYPE="02" DisplayMembershipClass="All"> <ClientGUID>GroupCustomerMV</ClientGUID> <WriteMembership>No</WriteMembership> <EffectiveFromDate>Activity:EffectiveDate</EffectiveFromDate> <EffectiveToDate>SystemDate</EffectiveToDate> </ClassGroup> </Membership> ... </Transaction>
