5. Reports
This manual lists the details of various reports that you can generate for ELCM.
During the day, or at the end of the day, you may want to retrieve information on any of the several operations that were performed during the day in your bank. You can generate this information in the form of reports in ELCM.
For every module you can generate reports, which give you data about the various events in the life of a specific contract, or across contracts, at a specific point in time. You can have analysis reports, daily reports, exception reports (reports on events that ought to have taken place on the contract but have not, due to various reasons), history reports, and so on. A set of report formats is pre-defined for every module.
5.1 Generating Reports
From the Application Browser, select the Reports option. A list of all the modules to which you have access rights are displayed in the screen. When you click on a module, all the reports for which you have access rights under the selected module are displayed. Click the report you want to generate. You are given a selection Criteria based on which the report would be generated.
Click ’OK’ button when you have specified your preferences. The ‘Print Options’ screen gets displayed, where you can specify the preferences for printing the report.
5.2 Over Drawn Lines Report
The report is used to check the overdrawn balances with the respect to the credit lines being used. You can invoke the ‘Over Drawn Lines Report’ screen by typing ‘ELRPOVLN’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Line Code
Select the line code as All or Single.
List of Credit Lines
Select the credit line from the adjoining option list, if single line code is selected.
Note
The list of credit lines is disabled, if line code is opted as All. If line code is opted as single, then list of credit lines are mandatory.
5.2.1 Contents of the Report
The contents of this report are discussed under the following heads:
Header Section
The header contains the following:
Liability Number
The liability number of the customer is displayed.
Name
The name of the liability is displayed.
Customer Number
The customer associated with the facility is displayed.
Customer Name
The name of the customer associated with the facility is dis­played.
Line
The credit line number of the facility is displayed.
Serial
The serial number of the credit line is displayed.
Currency
The currency of the credit line is displayed.
Main Line
The main credit line of the facility is displayed
Effective Line Amount
The effective credit line amount is displayed.
Overdrawn Amount
The amount overdrawn by utilization is displayed.
Tabular Section
This report contains details of:
Contract Reference Account Number
The reference number of the contract account which uti­lizes the line with the primary key as the facility associated with the liability, is displayed.
Module
The associated module from which the transaction is gen­erated is displayed.
Utilization Amount in Con­tract Currency/A/c Cur­rency
The utilization amount in the contract currency is dis­played.
Utilization Amount in line currency
The utilization amount in the line currency is displayed. If full reinstatement is made to the utilization made, then utilization amount in contract currency/ account currency and utilization amount in line currency is 0. This is applicable for revolving lines only.
In case of non revolving lines, even if reinstatement is made, utilization amount remains as is.
Date of Overdrawn Amount
The date on which the transaction has overdrawn the line is displayed.
Reason/Remark
Reason or Remark of the overdrawn amount is displayed here.
Note
The subtotal of the overdrawn amount is displayed. The grand total displays the grand total of the overdrawn amount is also displayed. The sub total and the grand total are displayed in the branch local currency.
5.3 Utilizations Report Date Wise Report
This report is used to track the utilizations on a credit line. You can invoke the ‘Utilizations Report Date Wise’ screen by typing ‘ELRPUTLD’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Liability
Select All liabilities or Single liability.
From Date
Select the date from which the utilization is to be considered to generate this report.
To Date
Select the date till which the utilization is to be considered to generate this report.
Note
From Date and To Date fields are mandatory fields. The report lists all utilizations that have taken place between the From and To Dates selected. The From and To Dates cannot be a future date. ‘To Date’ cannot be more than ‘From Date’.
List of Liability Names
Select the name of the liability from the adjoining option list, if single liability is selected.
Note
The list of liability names is enabled only if Single Liability is selected. This field is disabled if ‘All Liabilities’ are selected.
5.3.1 Contents of the Report
Header Section
Liability Name
Line Code
The line code of the utilization line is displayed.
Serial Number
The serial number of the line is displayed.
Line Currency
The currency of the line is displayed.
Contract Refer­ence
Number
The contract reference number that emanates from the Product
Processor is displayed.
Contract Currency
The contract currency of the contract which utilizes the line is displayed,
Module
The module from which the transactions are triggered is dis­played.
Date
Date wise utilization on the credit line is displayed.
Utilization Line Currency
The line currency of the utilization amount is displayed.
Utilization Contract
Currency
The utilization in contract currency is displayed.
Note
The utilization remains the same even if a reinstatement is made as the utilizations are made for a line, date wise. The subtotal shows the liability wise total in liability currency and grand total displays the total utilizations in branch currency.
5.4 Collateral Details Report
This report is used to view the collaterals at any point in time. You can invoke the ‘Collateral Report’ screen by typing ‘ELRPCOLT’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Liability
Select all liabilities or single liability.
List of Liabilities
Select the liability from the adjoining option list, if single liability is selected.
5.4.1 Contents of the Report
Header Section
Liability Number
The liability number is displayed.
Liability Name
Customer Name
The name of the customer is displayed.
Customer Number
The CIF number of the customer is displayed.
Collateral Code
The collateral code is displayed.
Description
The collateral description is displayed.
Currency
The collateral currency is displayed.
Collateral Value
The value of the collateral is displayed.
Collateral Category
The category of the collateral is displayed.
Collateral Type
The type of collateral which is linked with the category is dis­played.
Shared
Indication on whether the collateral is shared or not is dis­played.
Note
The subtotal displays the liability wise total collateral value. The grand total displays the liability wise total collateral value. The sub total and grand total are displayed in the branch local currency.
5.5 Pool Linkage Report
This report is used to analyse the following information:
This report gives details of the pool linkage. You can invoke the ‘Pool Linkage Report’ screen by typing ‘ELRPOLNK’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Pool Code
Select All Pool Code or Single Pool Code.
Pool List
Select the pool from the adjoining option list, if Single pool code is selected.
Note
Pool Codes should not be selected from the Pool List, if All Pools are selected, else an error message is displayed. The pool code can be selected only if single pool code is se­lected.
5.5.1 Contents of the Report
Header Section
Pool Code
The collateral pool code is displayed.
Description
The description of the pool code is displayed.
Liability Number
Pool Currency
The collateral pool currency is displayed.
Pool Amount
The total collateral pool amount is displayed.
Pool Utilized
The utilized collateral pool amount is displayed.
Available Amount
The available amount post the transaction is displayed. This is calculated as Total Available Pool Amount - Transaction Amount of the Pool.
Link/Contract Link­age
The utilization line or contract linked to the pool is displayed.
Tabular Section
Collateral Code
Collateral Currency
Collateral
Contribution
The collateral contribution to the pool is displayed.
Linked Percentage
The linked percentage of the collateral is displayed.
Collateral Type
The type of collateral is displayed.
Note
The subtotal displays the pool code wise total pool amount. The grand total displays the pool code wise total pool amount. The sub total and grand total are displayed in the branch local currency.
5.6 Credit Movement Report
This report is used to analyze the credit movement of the customer exposure across different credit lines of the overall exposure limit given to the customer. Banks require this report to monitor the exposure limit of the customer for the fund based and non-fund based credit limits.
You can invoke the ‘Credit Movement Report’ screen by typing ‘ELRPCRMO’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button
Liability
List of Liabilities
Note
The liability from the list of liabilities field can be selected only if single liability is selected or else an error message is displayed.
5.6.1 Contents of the Report
Header Section
Liability ID
The liability ID for the credit movement is displayed.
Liability Name
Line Code
The line code of the credit facility is displayed.
Line Serial Number
The serial number of the facility line code is displayed.
Line Currency
Limit Amount
The limit amount of the facility is displayed.
Collateral Contribu­tion
The collateral contribution in the facility or the credit line is dis­played.
Liability ID
Liability Name
Line Code
Line Serial Number
Line Currency
Limit Amount
Collateral
Contribution
displayed.
Revolving line
The revolving line indicator is displayed.
Available Amount
The available amount is displayed. The opening balance is updated only after EOD and not after each transaction. After EOD, the closing balance is displayed as the opening balance for the day.
The opening balance is not updated for each utilization transac­tion.
Amount reinstated
today
The line reinstated amount is displayed. The re-paid amount on
the loan which is attached to the credit line is displayed.
Amount Utilized
Today
The amount utilized for the day in the line is displayed.
Opening Available
The opening available balance is displayed.
Tabular Section
Contract Reference Number
The reference of the contract which utilizes the line is displayed.
Contract Currency
The currency of the contract which utilized the line is displayed,
Amount
The amount of the contract which utilizes the line is displayed. Amount is displayed as 0, if full reinstatement is made to the utili­zation for a revolving line. In case of part reinstatement, the amount is updated based on the reinstatement.
In case of non revolving lines, there is no change in amount after reinstatement.
5.7 Limit Details Report
This report is used to view the limit details of the customer at any point in time. You can invoke the ‘Limit Details Report’ screen by typing ‘ELRPLIMT’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Line
Select all line codes or single line code.
Select the credit line from the adjoining option list, if Single line code is selected.
Note
The credit lines from the list of credit lines can be selected only if single line code is select­ed else an error message is displayed.
5.7.1 Contents of the Report
Header Section
Line Code
The line code of the limit details are displayed.
Line Serial Number
The serial number of the line code is displayed.
Currency
The currency of the line code is displayed.
Start Date
The start date of the line is displayed.
Expiry Date
The expiry date of the line is displayed.
Limit Amount
The limit amount of the line is displayed.
Available Amount
The available amount of the line is displayed.
Utilized Amount
The utilized amount of the line is displayed.
Blocked Amount
The blocked amount of the line is displayed.
Tabular Section
The reference number of the contract attached to the line is displayed.
Module Account Num­ber
The module or source from which the transaction is generated is displayed.
Currency
The contract currency is displayed.
Amount
The contract amount is displayed.
Line Currency Equiva­lent
The line currency equivalent of the contract currency is dis­played.
5.8 Line Summary Report
This report is used to view the liability details and the corresponding line details associated with the customer liability. You can invoke the ‘Line Summary Report’ screen by typing ‘ELRPML’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Line
Note
5.8.1 Contents of the Report
Header Section
Liability Number
The liability number of the line is displayed.
Liability Currency
The liability currency of the line is displayed.
Liability Limit
The liability limit of the line is displayed.
Liability Utilization
The overall utilization of the liability is displayed.
Overdrawn Amount
The overdrawn amount of the liability is displayed.
Tabular Section
Line ID
The overdrawn line ID is displayed.
Status
The status of the line is displayed.
Currency
The currency of the overdrawn line is displayed.
Limit
The overall limit of the line is displayed.
Utilization
The utilization from the contract as on date is displayed.
Overdrawn Amount
The overdrawn amount of the line is displayed.
The contract which has utilized the line and overdrawn is dis­played.
Module
The module or source which has utilized the line is displayed.
5.9 Exception Report
This report is used to identify any exception transaction. This report fetches two types of data:
You can invoke the ‘Exception Report’ screen by typing ‘ELRPEXCE’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Liability
Select Single or All Liabilities. If ‘All Liabilities’ is selected, then the report is generated with all exceptions that would have occurred in the transaction with different liabilities.
Select the liability name from the adjoining option list, if a single liability is selected. You can select multiple liabilities by adding multiple rows by clicking the ‘+’ sign.
From Date
Select the start date. This date should be less than or equal to the system date.
To Date
Select the end date. The date should be less than or equal to the system date.
Note
The From Date and To Date are mandatory fields. The exception transactions performed between the From Date and the To Date are listed.
5.9.1 Contents of the Report
Header Section
Liability Number
The liability number with which the line has created the exception in the transac­tion is displayed.
Tabular Section
Transaction Date
The date on which the exception transaction was made is displayed.
Source
The product processor or source from which the transaction with exception was generated, is displayed.
Line ID
The facility ID which created the exception transaction, is dis­played.
Customer Number
The customer number of the customer who has transacted in the line which has created the exception is displayed. For a liability where multiple customers are associated with the facility, the system fetches the customer number which is attached to the facility.
Customer Name
Currency
The currency of the facility is displayed.
Transaction Amount
The transaction amount which has created this facility is dis­played.
User ID
The user ID of the user who has made this transaction is dis­played.
Approver ID
The officer user who has approved the exception transaction is displayed.
Exception
The exception reason or the override captured while process­ing of the transaction during save or authorization is dis­played.
5.10 Bank Wide Clean Risk Tracking Report
This report gives details of the bank wide clean risk tracking. You can invoke the ‘Bank Wide Clean Risk Tracking Report’ screen by typing ‘ELRPCLBK’ in the field at the top right corner. of the Application tool bar and clicking on the adjoining arrow button.
Date
Select a Single Date or All Dates.
Select the list of dates from the adjoining option list, if a single liability is selected. You can select multiple liabilities by adding multiple rows by clicking the ‘+’ sign.
Note
The dates from the list of dates can be selected only if single date is selected else an error message is displayed.
5.10.1 Contents of the Report
The options that you specified while generating the report are printed at the beginning of the report. The contents of the bank wide clean risk tracking report are discussed under the following heads:
Header
The Header carries the title of the Report, information on the branch code, branch date, the date and time of report generation, the user-ID of the user generating the report, module, and the page number.
Body of the Report
Settle Date
Indicates the settle date
Eurtype lcy
Indicates the eurtype lcy
Eurtype CCY
Indicates the eurtype ccy
CCY
Indicates the currency
Risk Amount
Indicates the risk amount
CF LCY Risk Amount
Indicates the CF LCY risk amount
5.11 Collateral Utilization of Credit Lines
This report gives details of the collateral utilization of credit lines. You can invoke the ‘Collateral Utilization of Credit Lines Report’ screen by typing ‘ELRPCOUT’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Pool Code
Pool List
Note
Pool Codes should not be selected from the Pool List, if All Pools are selected, an error message is displayed. The pool code can be selected only if single pool code is selected.
5.11.1 Contents of the Report
The contents of the collateral utilization of credit lines report are discussed under the following heads:
Header
The Header carries the title of the Report, information on the branch code, branch date, the date and time of report generation, the user-ID of the user generating the report, module and the page number.
Liability No
Indicates the Liability No
Liability Name
Indicates the Liability Name
Line Code
Indicates the Line Code
Line Serial
Indicates the Line Serial
Line Currency
Indicates the Line Currency
Pool CCy
Indicates the Pool CCy
Facility Amt Pool Ccy
Indicates the Facility Amt Pool Ccy
CfLm Ccy Amt
Indicates the CfLm Ccy Amt
Line Ccy Type
Indicates the Line Ccy Type
5.12 Collateral Utilization of Collateral Party
This report gives details of the collateral utilization of collateral party. You can invoke the ‘Collateral Utilization of Collateral Party Report’ screen by typing ‘ELRPCOUL’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Issuer Number
Select All Issuer Numbers or Single Issuer Number.
Issuer List
Select the issuer number from the adjoining option list, if Single issuer number is selected.
Note
Issuer Number should not be selected from the Issuer List, if All Issuer Numbers are se­lected, else an error message is displayed. The Issuer Number can be selected only if sin­gle issuer number is selected.
5.12.1 Contents of the Report
The options that you specified while generating the report are printed at the beginning of the report. The contents of the collateral utilization of collateral party report are discussed under the following heads:
Header
Body of the report
Issue No
Indicates the issue number
Overall Limit Ccy
Indicates the overall limit currency
Overall Limit
Utilization
Indicates the utilization
Collateral Type
Indicates the collateral type
Liab Id
Indicates the Liab Id
Ccy
Collateral Value
Indicates the collateral value
Collateral Value In Limit Ccy
Indicates the collateral value in limit Ccy
5.13 Country Exposure Report
This report gives details of the country exposure. You can invoke the ‘Country Exposure Report’ screen by typing ‘ELRPCNEX’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Country
Select All Countries or Single Country.
List of Countries
Select the country from the adjoining option list, if Single country is selected.
Note
Country should not be selected from the list of countries list, if All Countries are selected, an error message is displayed. The country can be selected only if single country is select­ed.
Country Code
Indicates the country code
Description
Indicates the description
Currency
Indicates the currency of the exposure.
Exposure Utilization
Indicates the exposure utilization amount
Utilization Branch
Indicates the branch of utilization
The following fields are populated if Transaction is selected as the ‘Utilization Type’:
Exposure Code
Indicates the exposure code which is the same as the selected country.
Exposure Currency
Indicates the currency of the exposure code.
Exposure Amount
Indicates the amount of the exposure.
Available Amount
Indicates the available amount of the exposure.
Block Amount
Indicates the block amount of the exposure.
Headroom Limit
Indicates the Exposure Amount of the
Exposure minus the sum of effective line amounts of the facilities which are linked with this exposure
5.14 Country Utilization Report
You can invoke the ‘Country Utilization Report’ screen by typing ‘ELRPCUTI’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Exposure Name
Select All Exposures or Single Exposure.
List of Exposure
Select the exposure from the adjoining option list, if Single exposure is selected.
Note
Exposure should not be selected from the list of exposures list, if All Exposures are select- ed, an error message is displayed. The country can be selected only if single expo- sure is selected
5.14.1 Contents of the report
The contents of the report are discussed under the following heads:
Header
Body of the report
Exposure Code
Displays the exposure code.
Description
Displays the description of the exposure.
Currency
Displays the currency of the exposure.
Amount
Displays the exposure amount.
Utilization Amount
Displays the utilization amount.
Effective Date
Displays the effective date.
Renewal Date
Displays the date of renewal
Expiry Date
Displays the expiry date.
Freeze
Displays the freeze status.
Type
Displays the type.
5.15 Credit Rating Report
You can invoke the ‘Credit Rating Report’ screen by typing ‘ELRPLIAB’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Liability
List of Liabilities
Note
5.15.1 Contents of the report
The options that you specified while generating the report are printed at the beginning of the report. The contents of the credit lines by maturity dates report are discussed under the following heads:
Header
The Header carries the title of the Report, information on the branch code, branch date, the date, and time of report generation, the user-ID of the user generating the report, module, and the page number.
Body of the report
Liability ID
Displays the liability ID
Name
Displays the name of the customer linked to the credit line
Credit Rating
Displays the credit rating of the customer.
Revision Date
Displays the revision date of the customer.
5.16 Credit Lines by Maturity Date
This report gives details of credit lines sorted on the basis of their maturity dates. The maturity date of a line indicates the expiry date of the line. The report also prints the number of days to maturity.
You can invoke the ‘Credit Lines by Maturity Date Report’ screen by typing ‘ELRPCLMT’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Liability
List of Liabilities
Note
5.16.1 Contents of the report
Header
Body of the report
Liability Id
Indicates the liability code to which the customer is linked
Customer Name
Indicates the name of the customer linked to this credit line.
Line Id
Indicates the Credit Line to which the customer s Liability number has been linked.
Serial Number
Indicates the running serial number for the Liability-Line Com­bination
Start Date
Indicates the start date
Expiry Date
Indicates the date on which the Credit Line Matures. Maturity of a Credit Line indicates that the Line expires after this date.
Days to Maturity
Indicates the number of days left, before the Line matures
5.17 Exposure Details Report
This report gives details of the Exposure details. You can invoke the ‘Exposure Details Report’ screen by typing ‘ELRPEXP’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Exposure Code
List of Exposure
Exposure should not be selected from the list of exposures list, if All Exposures are selected, else an error message is displayed. The country can be selected only if single exposure is selected.
5.17.1 Contents of the report
The contents of the exposure details report are discussed under the following heads:
Header
Exposure
Name
Indicates the exposure name
Exposure
Currency
Indicates the exposure currency
Exposure Amount
Indicates the exposure amount
Exposure Type
Indicates the exposure type
Revolving
Indicates the revolving status of the
exposure.
Available Amount
Revolving Amount
Indicates the revolving amount
Block Amount
Head Room Limit
5.18 Foreign Exchange Clean Risk Report
This report gives details of the foreign exchange clean risk. You can invoke the ‘Foreign Exchange Clean Risk Report’ screen by typing ‘ELRFXCL’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Customer Number
Select All customer numbers or single customer number.
List of Customer Numbers
Select the customer number from the adjoining option list, if Single customer number is selected.
Note
Customer number should not be selected from the list of customer numbers, if All custom- er numbers are selected, an error message is displayed. The customer number can be se­lected only if single customer number is selected.
5.18.1 Contents of the report
The contents of the foreign exchange clean risk. report are discussed under the following heads:
Header
Customer Id
Indicates the customer id
CustomerName
Indicates the customer name
Settlement
Indicates the settlement
Currency
Amount
Total
Indicates the total amount
Limit
Indicates the days to limit
Overdraft
Indicates the overdraft
5.19 Issuer Details
This report gives details of the issuer. You can invoke the ‘Issuer Details Report’ screen by typing ‘ELRPISUR’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Issuer Number
Issuer List
Note
Issuer Number should not be selected from the Issuer List, if All Issuer Numbers are se­lected, else an error message is displayed. The Issuer Number can be selected only if sin- gle issuer number is selected.
5.19.1 Contents of the report
The contents of the issuer details report are discussed under the following heads:
Header
Body of the Report
Issuer Number
Indicates the issuer number.
Issuer Details
Indicates the issuer details
Issuer CIF No
Indicates the issuer CIF number
Overall Limit
Currency
Overall Limit
Indicates the overall limit.
5.20 Issuer Exposure Report by Security
This report gives details of the issue exposure by security. You can invoke the ‘Issuer Exposure Report by Security’ screen by typing ‘ELRPUSEX’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Issuer Number
Issuer List
Note
Issuer Number should not be selected from the Issuer List, if All Issuer Numbers are se- lected, else an error message is displayed. The Issuer Number can be selected only if sin- gle issuer number is selected.
5.20.1 Contents of the report
The contents of the issue exposure by security report are discussed under the following heads:
Header
Body of the report
Issuer Id
Indicates the issuer id
Overall Limit
Utilization
Security Id
Indicates the security id
Currency
Limit
Indicates the limit
Utilization
Price Code
Indicates the price code
Market Price
Indicates the market price
5.21 Issuer Exposure Report by Collateral Type
This report gives details of the issuer exposure by collateral type.You can invoke the ‘Issuer Exposure Report by Collateral Type’ screen by typing ‘ELRPISEX’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Issuer Number
Issuer List
Note
5.21.1 Contents of the Report
The report options that you selected while generating the report are printed at the beginning of the report.
Header
The Header carries the title of the Report, information on the branch code, the date and time of report generation, the user-ID of the user generating the report, and the page number.
Body of the report
The body of the report is contained in two sections:
● Issuer Details
● Security Details
Issuer Details
Issuer ID
The code you assigned to the issuer in the Issuer Maintenance screen.
Overall Limit
This is the exposure limit specified for the Issuer.
Currency
The currency in which the Limit was defined.
Utilization
The utilization of the limit.
Security Details
Security ID
The Code assigned specified in the Types Maintenance screen to identify the Security.
Currency
The currency in which the value of the security is expressed.
Limit
This is the exposure limit specified for the security.
Utilization
Price Code
The price code of the security.
Market Price
The current market price of the security, if it is a marketable secu­rity.
5.22 Liability Summary Report
This report gives details of the liability summary. You can invoke the ‘Liability Summary Report’ screen by typing ‘ELRPLB’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Liability
List of Liabilities
The list of liability names is enabled only if Single Liability is selected, or else an error mes- sage is displayed.
5.22.1 Contents of the report
The contents of the liability summary report are discussed under the following heads:
Header
Body of the Report
Auth
Indicates the authorization status
Liability
Liability Name
Indicates the liability name
Currency
Limit Amount
Indicates the limit amount
Utilisation Amount
Indicates the utilisation amount
Overdraft
5.23 Limit Tenor Restriction Details Report
This report gives details of the limit tenor restriction. You can invoke the ‘Limit Tenor Restriction Details Report’ screen by typing ‘ELRPUT’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Liability
List of Liabilities
5.23.1 Contents of the report
The contents of the limit tenor restriction report are discussed under the following heads:
Header
Body of the Report
Utilisation
Overdraft
Main Line
Indicates the main line
Limit
Indicates the limit
Overdraft
Line ID
Indicates the line ID
Reference No
Indicates the reference number
Tenor
Indicates the tenor
Amount Tag
Indicates the amount tag
Amount
Indicates the line currency equivalent
5.24 Limits Tenor Wise Details Report
You can invoke the ‘Limit Tenor Wise Details Report’ screen by typing ‘ELRPTN’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Liability
List of Liabilities
5.24.1 Contents of the Report
The report has distinct sections for each Liability Code. The utilization of tenor based limits is printed for both Main Lines and Sub-Lines.
Header
Body of the report
Liability
The Liability code of the customer.
Limit
The credit limit assigned to the Liability code and the currency in which it is defined.
Utilization
The utilization of the limit under the Liability Code.
Overdraft
This is the amount by which the customer has exceeded the limit set for the Liability Code.
For each Liability Code the following details are printed for the Main Line or sub-line.
Main Line
This is the code of the Main Line to which the customer s Liability num­ber has been linked.
Limit
The Limit set for the Main line and the currency in which the limit under the Main
Line or Sub-Line is defined.
Utilization
The utilization of the limit under this line is displayed here.
Overdraft
This is the overdrawn amount of the Line or sub-line.
After the details of the Line are displayed the following details are printed in tabular columns:
Tenor
This is the tenor code.
Limit
The limit assigned to the tenor.
Utilization
The utilization of the limit under the tenor code.
Overdraft
This is the overdrawn amount.
5.25 Line Details Report
This report gives details of the line. You can invoke the ‘Line Details Report’ screen by typing ‘ELRPLN’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Liability
List of Liabilities
5.25.1 Contents of the report
The contents of the line details report are discussed under the following heads:
Header
Body of the report
Liability ID
Indicates the liability ID
Limit
Indicates the limit of the liability
Utilisation
Indicates the utilisation for liability
Overdraft
Indicates the overdraft for liability
Main Line
Line ID
Currency
Limit
Indicates the limit for line
Utilisation
Indicates the utilisation for line
Overdraft
Status
Indicates the status
5.26 Movement to Non Revolving Lines
This report gives details of the movements to non-revolving lines. You can invoke the ‘Movement to Non Revolving Lines Report’ screen by typing ‘ELRPNRLN’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Line
The credit lines from the list of credit lines can be selected only if single line code is selected else an error message is displayed.
5.26.1 Contents of the report
The contents of the movements to non-revolving lines report are discussed under the following heads:
Header
Body of the report
Line Code
Indicates the line code
Line Currency
Util ID
Indicates the utilization ID
Limit Amount
Indicates the line amount
Available
Amount
5.27 Pool Utilization Report
This report gives details of the pool utilization. You can invoke the ‘Pool Utilization Report’ screen by typing ‘ELRPOLUT’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Pool Code
Pool List
Pool Codes should not be selected from the Pool List, if All Pools are selected, else an error message is displayed. The pool code can be selected only if single pool code is selected.
5.27.1 Contents of the report
The contents of the pool utilization report are discussed under the following heads:
Header
Body of the report
Liability Name
Pool Code
Indicates the pool code
Pool Currency
Indicates the pool currency
Pool Currency Type
Indicates the pool currency type
Pool Amount
Indicates the pool amount
Pool Utilization
Indicates the pool utilization
Collateral Currency
Indicates the collateral currency
Linked Amount
Indicates the linked amount
Utilization
5.28 Product Exposure Report
This report gives details of the product exposure. You can invoke the ‘Product Exposure Report’ screen by typing ‘ELRPPREX’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Product Name
Select All Product Names or Single Product Name.
List of Products
Select the product from the adjoining option list, if Single product is selected.
Product should not be selected from the list of products, if All Products are selected, else an error message is displayed. The product can be selected only if single product is selected.
5.28.1 Contents of the report
The contents of the product exposure report are discussed under the following heads:
Header
Body of the Report
Product
Indicates the product
Bank LCY
Indicates the bank currency name
Product
Description
Indicates the product description
CS Product
Amount
Indicates the CS product amount
CFF Product
Amount
Indicates the CF F product amount
Currency
CS Currency
Amount
Indicates the CS currency amount
CF Currency
Amount in
LCY
Indicates the CF currency amount in LCY
CFF Currency
Amount
Indicates the CF F currency amount
Amount
Branch
Indicates the branch code
5.29 Securities Details Report
This report gives details of security. You can invoke the ‘Securities Details Report’ screen by typing ‘ELRPSECM’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Security Code
Select All Security Codes or Single Security Code.
List of Securities
Select the security code from the adjoining option list, if single security code is selected.
Security code should not be selected from the list of security codes, if All Security Codes are selected, else an error message is displayed. The security code can be selected only if single security code is selected.
5.29.1 Contents of the report
The contents of the security details report are discussed under the following heads:
Header
Body of the report
Security Code
Indicates the security code
Description
Face Value
Indicates the face value
Currency
5.30 Utilization Report
This report gives details of the utilization. You can invoke the ‘Utilization Report’ screen by typing ‘ELRPUA’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Liability
List of Liabilities
5.30.1 Contents of the report
The contents of the utilization report are discussed under the following heads:
Header
Body of the report
Liability
Indicates Liability
Limit
Indicates limit
Main Line
Indicates main line
Line Id
Indicates line id
Reference No
Indicates reference number
Tenor
Indicates tenor
Amount Tag
Indicates amount tag
Amount
Indicates amount
Line Currency
Equivalent
Indicates line currency
Utilisation
Overdraft
