This document is designed to help acquaint you with the integration among Oracle FLEXCUBE products namely; Oracle Banking Enterprise Limits and Collateral Management system (FCELCM), Oracle FLEXCUBE Universal Banking Solutions (FCUBS) and Oracle Banking Corporate Lending (OBCL).
Besides this user manual, while maintaining the interface related details, you can invoke the context sensitive help available for each field. This help describes the purpose of each field within a screen. You can obtain this information by placing the cursor on the relevant field and pressing the <F1> key on the keyboard.
This manual is intended for the following User/User Roles:
Role |
Function |
Back office data entry Clerks |
Input functions for maintenance related to the interface |
Back office Managers/Officers |
Authorization functions |
End of day operators |
Processing during end of day/ beginning of day |
Implementation Partners |
Provide customization, configuration and implementation services |
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
This manual is organized into the following chapters:
Chapter |
Description |
Chapter 1 |
Preface gives information on the intended audience. It also lists the various chapters covered in this User Manual. |
Chapter 2 |
ELCM Integration with OBCL/FCUBS explains the various integration scenarios of ELCM integration with OBCL/FCUBS. |
Chapter 3 |
Annexure provides the technical changes of integration. |
Chapter 4 |
Function ID Glossary has alphabetical listing of Function/Screen ID's used in the module with page references for quick navigation. |
Abbreviation |
Description |
BC |
Bills and Collection |
CD |
Corporate Deposit |
EJB |
Enterprise Java Beans |
ECM |
Oracle Banking Enterprise Collateral Management system |
ELCM |
Oracle Banking Enterprise Limits and Collateral Management system |
ELM |
Oracle Banking Enterprise Limits Management system |
FCUBS |
Oracle FLEXCUBE Universal Banking |
JDBC |
Java Database Connectivity |
JPA |
Java Persistence API |
LC |
Letter of Credit |
MM |
Money Market |
OBCL |
Oracle Banking Corporate Lending |
ODT |
Open Development Tools |
POJO |
Plain Old Java Object |
SQLJ |
A SQLJ program is a Java program containing embedded SQL statements. |
TD |
Term Deposit |
XML |
eXtensible Markup Language |
This user manual may refer to all or some of the following icons.
Icons |
Function |
Exit |
Add row |
Delete row |
Option List |
Along with this user manual, you may also refer to the following related sources:
