1.  About this Manual
1.1  Introduction
This manual is designed to help acquaint you with the Messaging System
module of Oracle Lending.
In addition to this User Manual, you can find answers to specific
features and procedures, in the Online Help. It can be invoked by choosing
Help Contents from the Help Menu of the software. You can further obtain
information about to a particular field by placing the cursor on the
relevant field and striking the <F1> key on the keyboard.
1.2  Audience
This manual is intended for the following User/User Roles:
Role
Function
Back office data entry
clerk
Input functions for contracts.
Back office managers/officers
Authorization functions.
Product Managers
Product definition and
authorization.
End of Day operators
Processing during End of
Day/ Beginning of Day.
Financial Controller/Product
Managers
Generation of reports.
1.3  Organization
This manual is organized into the following chapters:
Chapter 1
About this Manual gives
information on the intended audience. It also lists the various chapters
covered in this User Manual.
Chapter 2
Messaging System - an overview
— It is a snapshot of the features that the module provides.
Chapter 3
Maintaining Messaging Branch
Preferences – This chapter specifies the messaging branch
preferences.
Chapter 4
Media Maintenance Types
- This chapter discusses the procedure to maintain details of the media
through which messages can be transmitted from and to your bank.
Chapter 5
Maintaining addresses for
a customer - Discussed in this chapter is the procedure for maintaining
addresses for the customers.
Chapter 6
Maintaining Advice Formats
– This chapter explains the procedure for maintaining advice
formats.
Chapter 7
Processing Outgoing Messages - This chapter
explains the procedure involved in generating an outgoing message.
Chapter 8
Defining Free Format Messages
- This chapter explains process of defining free format messages.
Chapter 9
Making a Query - This chapter
explains the query process.
1.4  Related documents
You may need to refer to any or all of the User Manuals while working
on the Messaging module:
- Core Services
 - Core Entities
 - Settlements
 - User Defined Fields
