This manual is designed to help you get acquainted with the manner in which contracts in a product are settled in Oracle Lending.
It takes you through the various steps involved in processing a Settlement.
Besides this User Manual, you can find answers to specific features and procedures in the Online Help, which can be invoked, by choosing ‘Help Contents’ from the Help Menu of the software. You can further obtain information specific to a particular field by placing the cursor on the relevant field and pressing <F1> on the keyboard.
This manual is intended for the following User/User Roles:
| Role | Function |
| Back office clerk | Input functions for contracts |
| Back office managers/officers | Authorization functions |
| Product Managers | Product definition and authorization |
| End of day operators | Processing during end of day/ beginning of day |
| Financial Controller / Product Managers | Generation of reports |
This manual is organized into the following chapters:
This User Manual may refer to all or some of the following icons.
| Icons | Function |
 | Exit |
 | Add row |
 | Delete row |
 | Option List |
For further information on procedures discussed in the manual, refer to the following Oracle Lending manuals:
