You can create dining rotation codes for the Group and FIT Management modules in the Dining Rotation Setup module. These Rotations are used to automatically create dining reservations in a single or multiple restaurants.
Adding A Rotation
Select Dining Rotation Setup
Rotation Code: Enter the code of the Rotation
Rotation Time: Enter the time of the Rotation
Product: Select the product for the Rotation
Click Add
Status: Select the status of the Rotation
ACTIVE: Rotation is available for selection.
DEACTIVE: Rotation is disabled for selection.
REGULAR: Rotation to be used in the Group Management module
FIT USE: Rotation to be used in the FIT Management module
Restaurant: Select the restaurants for the Rotation, the order of them can be adjusted by selecting the restaurant and clicking on the Move Up/ Move Down buttons.
To remove a restaurant from the Rotation click Delete.
Click Save Changes
For Type = REGULAR: Only products set up as Book by Reservation is displayed and can be used for configuration of a Rotation.
For Type = FIT USE: All products set up as Book by Reservation and Book By Guest are displayed and can be used for configuration of a Rotation.
Editing A Rotation
Double-click on the Rotation to open the Rotation Detail Setup tab
Make the required change
Click Save Changes
Deleting A Rotation
Select the Rotation name and click Delete Rotation
You can only delete a Rotation if was not used already in Group or FIT Management.
Confirm the deletion
