Within the Mobile Updater tool, you can add and delete the application files, or perform an upgrade for the SilverWhere application suite, in which the new application files will be published to all other clients.
Adding an Application File
Select Mobile Updater
Select the group from the drop-down menu, that you would like to add a new application file
Click Add and Browse to the location where the application file is stored; select it and click Open
Deleting an Application File
Select the group from the drop-down menu, from where you would like to delete an application file
Select the application file that you want to delete and click on Delete
Confirm the deletion
Publishing Application Files
Select the group from the drop-down menu, to where you would like to publish the application files
Click on Publish and confirm the update process
You have to perform the above steps for each of the groups to automated the application upgrade process.
