The Pager Setup module allows you to add and modify the pagers being used for Check In.
Adding A Pager
Select Pager Setup
Pager Group: Select the pager group from the drop-down menu
Short Number: Enter the short number of the pager
Long Number: Enter the long number of the pager
Pager Type: Select the pager type from the drop-down menu
Invert: Select if the pager text should be inverted or not from the drop-down menu
Baud Rate: Select the baud rate from the drop-down menu
Comment: Enter a comment if desired
Click Save
Editing a Pager
Select Pager Setup
Select the pager that should be modified
Make the required change
Click Save
Deleting a Pager
Select Pager Setup
Select the pager
Click on Delete Pager and confirm the deletion
