The printer settings are saved in the registry for each SilverWhere user. Hence, each user has to assign the printer before a report can be printed.
SilverWhere .Net
For the report to print, you need to assign a printer to each Printer Type.
Open the Printer Assignment module under the System Setup tab.
Select each of the printer types and assign the printer from the drop-down list.
Click on the Save button.
SWMobile
For the reports to print, a printer needs to be assigned to each Printer Type:
On the SWMobile Main screen, open the Settings tile.
Figure 4-1 SWMobile Main screen
Click on the Printer Assignment tab
Select a printer type and assign the physical printer from the bottom list.
These steps need to be done for each printer type.
