This document provides an explanation and description of each of the exposed functions in the Oracle Hospitality Cruise SilverWhere SWReservation Web Service.
Audience
Third-party vendors who wish to integrate with SilverWhere.
This document should be used as a technical reference for external parties to develop applications that require interfacing to SilverWhere.
Customer Support
To contact Oracle Customer Support, access My Oracle Support at the following URL: https://support.oracle.com
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received
Screen shots of each step you take
Documentation
Oracle Hospitality product documentation is available on the Oracle Help Center at http://docs.oracle.com/en/industries/hospitality/cruise.html.
Revision History
Table -1 Revision History
| Date | Description of Change |
November 2022 |
Initial publication. |
