The following sections describe the Webservice functions with their required parameters and return values.
Synchronization (SWSync)
This is a message from SWReservation with basic product information for a ship and the date range. Multiple ships and date ranges can be sent at the same time.
Table 3-1 Request XML Structure
| Column Name | Type | Length | Description |
Request ID |
Numeric |
9 |
Unique ID for this transaction |
Mode |
String |
1 |
‘F’ for Full synchronization mode ‘D’ for Detailed synchronization mode |
Ship Code |
String |
2 |
Two character ship code. Mandatory field. |
Sail Date |
Date |
8 |
Only details starting from this date will be included in the response message if passed in |
Sync starting from Date |
Date |
8 |
Sync Starting from Time |
Numeric |
4 |
Optional parameter. If passed in, details starting from this date and time will be included in the response message. (date is mandatory) |
Product Code |
String |
10 |
Code of the product. Required for detailed synchronization mode |
Single Date |
Date |
Inventory date |
Location Code |
String |
10 |
Code of the location |
Table 3-2 Response XML Structure
Request ID |
Numeric |
9 |
Response |
String |
4 |
OKAY, NTFD (Not Found) |
Request Detail |
Request Detail Item |
Product Level |
Optional, will only be sent if the product is new or was modified |
Product Information |
Ship Code |
String |
2 |
Unique ID for a ship |
Product Code |
String |
10 |
Code of the product |
Product Name |
String |
80 |
Name of the product |
Product Description |
String |
1000 |
Description of the product |
Product Duration |
Numeric |
2 |
Duration of the product |
Product Transition Lag Time |
Numeric |
3 |
Lag time |
Product Transition Lead Time |
Numeric |
3 |
Lead time |
Cancel Period Start Duration |
Numeric |
3 |
Cancel Duration |
Adult Cancellation Fee |
Numeric |
9,2 |
Not in SilverWhere Return 0.00 |
Child Cancellation Fee |
Numeric |
9,2 |
Min Age |
Numeric |
2 |
Minimum age the guest must meet to book this product |
Location Type |
String |
1 |
If Product Type = A then Location Type = A else O |
Location Code |
String |
10 |
Code of the location. |
IsVIPLocation |
String |
1 |
A flag that determines if this is a VIP location and restricted to VIP guests. Values are Y= YES or N=NO |
IsRestictedProduct |
String |
1 |
A flag that determines if the product event is restricted allowing only ONE reservation per product event. Values are Y= YES or N=NO |
IsComplimentary |
String |
1 |
A flag that determines a complimentary location. Values are Y= YES or N=NO) |
MinBookingTime |
String |
4 |
Returns the first available time for this product |
MaxBookingTime |
String |
4 |
Returns the Last available time for this product |
Presale flag |
String |
Pre-cruise |
Price Adult |
Numeric |
9,2 |
The price for this product on this date. |
Price Child |
Numeric |
9,2 |
Vendor Type |
String |
Vendor Type |
Item Level |
Optional level. Sent for new times or on changes |
Item Information |
Ship Code |
String |
2 |
Sail Date |
Date |
8 |
Sail Date for the product. |
Product Code |
String |
10 |
Product code for this response. |
Location Code |
String |
10 |
Location code on the ship where the Product is being offered. |
Date List |
Date Information |
Header name ‘date_information’. |
Offering Date |
Date |
8 |
Date for this product. |
Offering List |
Offering |
Header name ‘offering_information’ |
Time |
Numeric |
4 |
Time for this product on this date. |
Status |
String |
1 |
Open, Closed, Re-opened |
Heartbeat (SWBeat)
This message is used to determine if the SWReservation web service is available, and, optionally if the database is up and running.
Table 3-3 Request XML Structure
Request ID |
Numeric |
9 |
Ship Code |
String |
2 |
Required on shoreside instance |
Check Database |
String |
1 |
“Y” indicates that a database check is requested. |
Table 3-4 Response XML Structure
Request ID |
Numeric |
9 |
Database Status |
String |
1 |
“U” = Up, “D” = “Down” |
Reservation (SWAvail)
Inventory is a message to SilverWhere to check inventory for a specific ship, product, number of guests, date, and time. SilverWhere will first try to find an exact match for the requested time. If no inventory is found for that time, SilverWhere will see if there is any inventory for the product and date requested, and suggest the time closest to the requested time. If the time sent into is zero, SilverWhere will send back inventory for all times for the requested table size, but will not create a reservation. If a time is sent in, and the exact time is not available, other available times will be sent back.
If there is an exact time found, a temporary Reservation will be made with guest name and cabin values ‘TBA’ until all data is present and the reservation process completed. The temporary Reservation will only be canceled with a SWCancel message (it will not be automatically canceled after the number of minutes defined in the SWPARAM.xml file).
Table 3-5 Request XML Structure
Request ID |
Numeric |
9 |
Ship Code |
String |
2 |
Unique ID for a ship (Required) |
Location Code |
String |
30 |
The location for the request (Optional). If Blank, will return all location. Array of location separated by a comma indicates a Filtered request. |
Product Code |
String |
10 |
The product for the request (optional) if no product code is provided, no temporary reservation will be made. Call will be treated as a lookup |
Availability Type |
String |
1 |
A code requesting exact match or best: E – Exact: Exact match for the requested location/ product/ guests/ date/ timeB – Best: Exact match for the requested location/ product/ guests/ date and all inventory close to the requested time will be shown fit |
Date |
Date |
8 |
The date for the request |
Time |
Numeric |
4 |
The requested time. |
Number of Guests |
Numeric |
2 |
The number of guests for the Reservation. |
VIP Status |
String |
1 |
A code to indicate that this guest is a VIP guest with access to the Restricted location (Y= YES N=NO). |
Comments |
String |
50 |
Table preferences for dining reservation |
Reservation ID |
Numeric |
9 |
Sent from Third-Party System if this transaction needs to release a previous hold. |
DiningType |
String |
1 |
Defines Dining type for restriction to complementary locations. (T = Restricted access) |
FilterTimeFrom |
String |
4 |
Will filter results to ensure temporary booking time and Other times available are equal to or after specified time (optional) |
FilterTimeTo |
String |
4 |
Will filter results to ensure temporary booking time and Other times available are equal to or before specified time (optional) |
Guest Information List |
Guest Information |
Header name ‘guest_information’ |
Guest ID |
Numeric |
9 |
Unique ID for a guest |
Cabin |
String |
4 |
The cabin number for the guest |
Last Name |
String |
20 |
The last name of the guest |
First Name |
String |
20 |
The first name of the guest |
Group ID |
Numeric |
9 |
Unique ID for a group |
Table 3-6 Response XML Structure
Location Code |
String |
10 |
Location for this reservation |
Product Code |
String |
10 |
Product for this reservation |
Date |
Date |
8 |
The date for this reservation. |
Time |
Numeric |
4 |
The time for this reservation. This may NOT be what was requested alternate inventory was suggested. |
Type |
String |
1 |
Type of Inventory |
Reservation ID |
Numeric |
9 |
The SilverWhere generated Reservation ID. If no inventory, the value of Reservation ID will be zero. |
Price |
Numeric |
9,2 |
The price for this reservation. |
Other Times Available List |
Other Times Available |
Header name ‘other_times_available’. |
Location |
String |
10 |
Location code |
Time |
Numeric |
4 |
Another time that is available for this date and location and table size. |
Product |
String |
15 |
Product Code |
Type |
String |
1 |
Type of Inventory |
Reservation (SWAvailMultipleDays)
Inventory for multiple days is a message to check the inventory for multiple combinations of ship, product and number of guests, date and time. SilverWhere will first try to find an exact match for each of the requested time. If no inventory is found for that time, SilverWhere will see if there is any inventory for the product and date requested, and suggest the time closest to the requested time for each day. If the time sent into is zero, SilverWhere will send back inventory for all times for the requested table size for each day, but will not create a reservation. If a time is sent in, and the exact time is not available, other available times will be sent back for each day.
Table 3-7 Request XML Structure
Column Name |
Type |
Length |
Description |
Request ID |
Numeric |
9 |
DayDetail List |
Day Detail |
DayDetail |
Tag that repeats for each Day |
Ship Code |
String |
2 |
Location Code |
String |
30 |
The location for the request |
Product Code |
String |
10 |
The product for the request |
Availability Type |
String |
1 |
A code requesting exact match or best: E – Exact: Exact match for the requested location/ product/ guests/ date/ time B – Best: Exact match for the requested location/ product/ guests/ date and all inventory close to the requested time will be shown fit |
Date |
Date |
8 |
Time |
Numeric |
4 |
Number of Guests |
Numeric |
2 |
VIP Status |
String |
1 |
A code to indicate that this guest is allowed to book in the VIP reserved inventory. Values are Y= YES or N=NO |
Comments |
String |
50 |
Reservation ID |
Numeric |
9 |
DiningType |
String |
1 |
Defines Dining type for restriction to complementary locations. (T=restricted access) |
FilterTimeFrom |
String |
4 |
Will filter results to ensure temporary booking time and other times available are equal to or after specified time (optional) |
FilterTimeTo |
String |
4 |
Will filter results to ensure temporary booking time and other times available are equal to or before specified time (optional) |
Guest Information |
Header name ‘guest_information’. |
Guest ID |
Numeric |
9 |
Cabin |
String |
4 |
Last Name |
String |
20 |
First Name |
String |
20 |
Group ID |
Numeric |
9 |
Table 3-8 Response XML Structure
Request ID |
Numeric |
9 |
Response Details List |
Response Details |
Header name ‘response_detail_list’, tag repeats for each day’s response |
Ship Code |
String |
2 |
Location Code |
String |
10 |
Product Code |
String |
10 |
Date |
Date |
8 |
Time |
Numeric |
4 |
Reservation ID |
Numeric |
9 |
The SilverWhere generated Reservation ID. If no inventory, the value of the Reservation ID will be zero. |
Price |
Numeric |
9,2 |
Time |
Numeric |
4 |
Location |
String |
10 |
Location Code |
Product |
String |
15 |
Product code |
Inventory Book (SWBook)
This message is to complete the booking from the previous inventory request. “BOOK” will finalize the booking request.
Table 3-9 Request XML Structure
Request ID |
Numeric |
9 |
Ship Code |
String |
2 |
Share Table |
String |
1 |
Share table. Y = Yes |
Reservation ID |
Numeric |
9 |
Reservation ID. |
Guest Information |
Guest ID |
Numeric |
9 |
Cabin |
String |
4 |
Last Name |
String |
20 |
First Name |
String |
20 |
Group ID |
Numeric |
9 |
Payment Status |
String |
10 |
Payment status (P-Paid, A – waiting for authorization, D- declined). On create booking this will be set to ‘P’ for Paid only for certain bookings, if infants or price overridden and set to zero |
Booking Amount |
Numeric |
13,2 |
Booked Amount |
Email Address |
String |
255 |
Email Address |
Fax Number |
String |
25 |
Fax Number |
Remarks |
String |
100 |
User entered remarks |
Gift Flag |
String |
1 |
Y/ N for gift |
Onboard Currency Code |
String |
3 |
Currency code on the day of booking |
Onboard Currency Exchange Rate |
Numeric |
13,2 |
This is the amount in the onboard currency on the day of booking |
Owner Id |
Numeric |
9,0 |
Owner PAX ID for the booking |
Discount Amount |
Numeric |
13,2 |
Discounted Amount |
Amount Paid |
Numeric |
13,2 |
Paid Amount |
Transaction Ref Number |
Numeric |
9 |
Reference number |
Control Seq Number |
Numeric |
7 |
Sequence number |
Payment ID |
Numeric |
32 |
Unique ID for this payment |
Payment Type |
String |
2 |
Short code for the credit card, check or money order, for example CC, CK, MO, etc. |
Last 4 digits of CC |
String |
4 |
Credit card last four digits number |
Check / MO Number |
String |
20 |
Check # or Money Order # |
Table 3-10 Response XML Structure
Request ID |
Numeric |
9 |
Response |
String |
4 |
OKAY – Request succeeded NTFD – Reservation not found |
Inventory Book (SWBookMultipleDays)
Inventory Book Multiple Days is a message to complete the booking from the previous inventory request, for multiple days. “BOOK” will finalize the booking request. If the number of guests passed in SWBOOK transaction is lesser than the number of guests being held in the temporary reservation, this transaction should update the guest count in the reservation accordingly.
Table 3-11 Request XML Structure
Request ID |
Numeric |
9 |
Ship Code |
String |
4 |
Ship Code |
Reservation Details List |
Reservation Details |
Tag repeats for each reservation |
Reservation ID |
Numeric |
9 |
Reservation ID. |
Share Table |
String |
1 |
Yes – Guest is ok to share a table with other guests for the reservation No – Guest don’t want to share a table for the reservation |
Guest Information |
Reservation ID |
Numeric |
9 |
Reservation ID |
Guest ID |
Numeric |
9 |
Cabin |
String |
4 |
Last Name |
String |
20 |
First Name |
String |
20 |
Group ID |
Numeric |
9 |
Booking Amount |
Numeric |
13,2 |
Booked Amount |
Email Address |
String |
255 |
Fax Number |
String |
25 |
Remarks |
String |
100 |
Gift Flag |
String |
1 |
Y/N for gift |
String |
3 |
Onboard Currency Exchange Rate. |
Numeric |
13,2 |
Owner Id |
Numeric |
9,0 |
Amount Paid |
Numeric |
13,2 |
Amount paid for the guest |
Check/MO Number |
String |
20 |
String |
4 |
Credit card last four digits |
Payer Name |
String |
32 |
Name of the payer |
Payment Id |
Numeric |
32 |
Unique ID for the payment |
Payment Type |
String |
2 |
Payment Status |
String |
10 |
Discount Amount |
Numeric |
Discounted amount |
Numeric |
9 |
Reference Number |
Numeric |
7 |
Sequence Number |
Check /MO Number |
String |
20 |
Table 3-12 Response XML Structure
Request ID |
Numeric |
9 |
Response Detail List |
Response Detail |
Header name ‘response_detail’ |
Response |
String |
4 |
Calendar (SWCalendar)
The calendar function is a message to verify which active dining reservations are existing for a passenger in SilverWhere.
The replay will return booked dining reservation information’s in STATUS = EXPECTED for all guest included in the reservation only. Canceled, Waitlisted or Deleted Reservations will not be exposed.
Table 3-13 Request XML Structure
Request ID |
Numeric |
9 |
Ship Code |
String |
2 |
Guest Information |
List ID |
Numeric |
Unique ID for this list |
List Type |
String |
List Type |
Table 3-14 Response XML Structure
Request ID |
Numeric |
9 |
Guest List |
Guest Calendar Item |
Header name ‘guest_calendar_item’. |
Guest ID |
Numeric |
9 |
Unique ID for Guest |
Response |
String |
4 |
OKAY or NTFD |
Response Message |
String |
Meaningful response message |
Reservation Information List |
Reservation Information |
Header name ‘reservation_information’ |
Reservation Id |
Numeric |
Unique ID of reservation |
Ship Code |
String |
2 |
Shared Table |
String |
1 |
If REMARKS = OTHERS then Y else N. Y = Yes |
Product Code |
String |
10 |
Product for this reservation – “MAIN” for main dining time |
Date |
Date |
8 |
The date of the reservation. Main Dining room records will be generated for each day. |
Time |
Numeric |
4 |
The time of the reservation |
Duration |
Numeric |
4 |
The duration for the reservation |
Location Code |
String |
10 |
Location for this reservation – Blank for main dining time |
Product Reservation Status |
String |
10 |
Status of the dining reservation (E-Expected, W – waitlist, T – Temp Hold, X-canceled, D -deleted) |
Comments |
String |
50 |
Status |
String |
1 |
Guest Status |
Amount Paid |
Numeric |
13,2 |
Booking Amount |
Numeric |
13,2 |
Booked Amount |
Discount Amount |
Numeric |
Discounted Amount |
Check/MO Number |
String |
20 |
Control Seq # |
Numeric |
7 |
Sequence Number |
Transaction Ref # |
Numeric |
9 |
Reference Number |
Email Address |
String |
255 |
Fax Number |
String |
25 |
Remarks |
String |
100 |
Gift Flag |
String |
1 |
Y/N for gift |
String |
4 |
Credit card last four digit number |
String |
3 |
Numeric |
13,2 |
Payer Name |
String |
32 |
Name of payer |
Payment Id |
Numeric |
32 |
Unique id for payment |
Payment Status |
String |
10 |
Payment status (P-Paid, A – waiting for authorization, D- declined) |
Payment Type |
String |
2 |
Booking Creation Date |
Date |
8 |
Date of creation booking |
Booking Creation Time |
Numeric |
4 |
Time of creation booking |
Owner Id |
Numeric |
9,0 |
Order Id |
Numeric |
Order id for the booking |
Cancel (SWCancel)
Cancel is a message to cancel an existing booking or a waitlist.
Table 3-15 Request XML Structure
Request ID |
Numeric |
9 |
Ship Code |
String |
2 |
Reservation ID |
Numeric |
9 |
Reservation ID. |
Table 3-16 Response XML Structure
Request ID |
Numeric |
9 |
Response |
String |
4 |
OKAY – Cancel succeeded NTFD – Reservation not found |
Table Allocation (SWdmtTableAlloation)
Table Allocation is message to know which seating code and how many number of table already allocated to which group.
Table 3-17 Request XML Structure
Request ID |
Numeric |
9 |
Ship Code |
String |
2 |
Group ID |
Numeric |
Group ID |
Cruise ID |
String |
20 |
Cruise ID |
Table 3-18 Response XML Structure
Return Values List |
Return Values |
Header name ‘return_values’ |
Seating |
String |
1 |
Seating Code |
Dining Rule Id |
Numeric |
Id number |
Table Size |
Numeric |
The capacity of this table for this cruise. |
Allocated |
Numeric |
Total number of table. |
Inventory Extend (SWExtend)
Inventory Extend is a message to continue extending the temporarily hold for the requested space.
Table 3-19 Request XML Structure
Request ID |
Numeric |
9 |
Ship Code |
String |
2 |
Required |
Reservation ID |
Numeric |
9 |
Reservation ID. |
Table 3-20 Response XML Structure
Request ID |
Numeric |
9 |
Response |
String |
4 |
Guest Add (SWGuestAdd)
Guest Add is a message requesting a new guest to be added to an existing specialty restaurant reservation or a temporarily held reservation or waitlist. It is possible that the addition of the guest(s) may be denied due to inventory restraints.
Table 3-21 Request XML Structure
Request ID |
Numeric |
9 |
Reservation ID |
Numeric |
9 |
Reservation to which this guest is to be added. |
Ship Code |
String |
2 |
VIP Status |
String |
1 |
A code to indicate that this guest is allowed bookings in the VIP reserve. |
Guest Information |
Guest ID |
Numeric |
9 |
Cabin |
String |
4 |
Last Name |
String |
20 |
First Name |
String |
20 |
Group ID |
Numeric |
9 |
Table 3-22 Response XML Structure
Request ID |
Numeric |
9 |
Guest Response List |
Guest Response |
Header name ‘guest_response’ |
Guest ID |
Numeric |
9 |
Response |
String |
4 |
OKAY, NTFD (Reservation Not Found),NAVL (No Inventory) |
Guest Delete (SWGuestDelete)
Guest Delete is a message requesting guest(s) to be removed from an existing or temporarily held reservation or a reservation currently on the waitlist.
Table 3-23 Request XML Structure
Request ID |
Numeric |
9 |
Ship Code |
String |
2 |
Reservation ID |
Numeric |
9 |
Guest Information |
Guest ID |
Numeric |
9 |
Table 3-24 Response XML Structure
Request ID |
Numeric |
9 |
Guest Response |
Guest ID |
Numeric |
9 |
Response |
String |
4 |
OKAY, NTFD (Reservation Not Found), GNFD (Guest Not Found) |
Modify Reservation (SWModify)
This is a message requesting an old reservation to take over the inventory retained by a new reservation and to adjust the guest records associated with the old reservation. When completed, the old reservation id will still be active but will take over the time and guest count of the new reservation and the new reservation will be deleted. SWModify does not allow a reservation to be changed from one location to another.
Table 3-25 Request XML Structure
Request ID |
Numeric |
9 |
Ship Code |
String |
2 |
Old Reservation ID |
Numeric |
9 |
The original reservation ID |
New Reservation ID |
Numeric |
9 |
The revised reservation ID |
Share Table |
String |
1 |
Share table Y = Yes |
Deleted Guest Information List |
Deleted Guest Information |
Header name ‘deleted_guest_information’. |
Guest ID |
Numeric |
9 |
Added Guest Information List |
Guest Information |
Guest ID |
Numeric |
9 |
Cabin |
String |
4 |
Last Name |
String |
20 |
First Name |
String |
20 |
Payer Name |
String |
50 |
Name of the payer |
Payment Status |
String |
10 |
Status of payment (P – Paid, A- waiting for authorization, D - Declined) |
Amount Paid |
Numeric |
13,2 |
Booking Amount |
Numeric |
13,2 |
Booked Amount |
Check/MO Number |
String |
20 |
Control Seq # |
Numeric |
7 |
Sequence number |
Transaction Ref # |
Numeric |
9 |
Reference number |
Email Address |
String |
255 |
Fax Number |
String |
25 |
Remarks |
String |
100 |
Gift Flag |
String |
1 |
Y/N for gift |
String |
4 |
String |
3 |
Numeric |
13,2 |
Payment Id |
Numeric |
32 |
Unique id for the payment |
Payment Type |
String |
2 |
Discount Amount |
Numeric |
13,2 |
Discount Amount |
Owner Id |
Numeric |
9,0 |
Order Id |
Numeric |
Table 3-26 Response XML Structure
Request ID |
Numeric |
9 |
Response |
String |
4 |
OKAY, NTFD (not Found) |
Guest Response |
Guest ID |
Numeric |
9 |
Response |
String |
4 |
Payment Status (SWPaymentStatus)
This is a message to indicate the payment status for the dining reservation, after the payment got processed to the Third-Party System
Table 3-27 Request XML Structure
Request ID |
Numeric |
9 |
Ship Code |
String |
2 |
Reservation ID |
Numeric |
9 |
Dining Reservation Id |
Guest Information |
Guest ID |
Numeric |
9 |
Unique ID of the guest |
Payer Name |
String |
50 |
Name of the payer |
Payment Status |
String |
10 |
Amount Paid |
Numeric |
13,2 |
Booking Amount |
Numeric |
13,2 |
Booked Amount |
Check/MO Number |
String |
20 |
Control Seq # |
Numeric |
7 |
Sequence number |
Transaction Ref # |
Numeric |
9 |
Reference number |
Email Address |
String |
255 |
Fax Number |
String |
25 |
Remarks |
String |
100 |
Gift Flag |
String |
1 |
Y/N for gift |
String |
4 |
String |
3 |
Numeric |
13,2 |
Payment Id |
Numeric |
32 |
Payment Id |
Payment Type |
String |
2 |
Short code for the credit card, check or money order, for example, CC, CK, MO, etc. |
Discount Amount |
Numeric |
13,2 |
Discount Amount |
Order Id |
Numeric |
Order Id |
Table 3-28 Response XML Structure
Guest Response |
Guest ID |
Numeric |
9 |
Response |
String |
4 |
OKAY, NTFD (Reservation Not Found) GNFD (Guest Not Found) |
Inventory Release (SWRlse)
This is a message to release the temporary dining reservations.
Table 3-29 Request XML Structure
Request ID |
Numeric |
9 |
Ship Code |
String |
2 |
Reservation ID |
Numeric |
9 |
Reservation ID. |
Table 3-30 Response XML Structure
Request ID |
Numeric |
9 |
Response |
String |
4 |
Inventory Release (SWRlseMultipleDays)
This is a message to release the temporary dining reservations for multiple days.
Table 3-31 Request XML Structure
Request ID |
Numeric |
9 |
Ship Code |
String |
2 |
Unique ID for ship |
Reservations List |
Reservations |
Tag repeating for each reservation |
Reservation ID |
Numeric |
9 |
Reservation ID. |
Table 3-32 Response XML Structure
Request ID |
Numeric |
9 |
Release Response List |
Release Response |
Response |
String |
4 |
Waitlist (SWWaitlist)
This message is to retrieve the dining reservations, including passenger details, currently placed on the waitlist.
Table 3-33 Request XML Structure
Request ID |
Numeric |
9 |
Ship Code |
String |
2 |
Location Code |
String |
10 |
Product Code |
String |
10 |
Date |
Date |
8 |
Number of Guests |
Numeric |
2 |
The number of guests for the reservation. |
VIP Status |
String |
1 |
Comments |
String |
50 |
Table preferences for dining reservation and time for which the waitlist is done |
Guest Information |
Guest ID |
Numeric |
9 |
Cabin |
String |
4 |
Last Name |
String |
20 |
First Name |
String |
20 |
Comments |
String |
255 |
Table 3-34 Response XML Structure
Request ID |
Numeric |
9 |
Ship Code |
String |
2 |
Unique ID for Ship |
Location Code |
String |
Product Code |
String |
Product code for this response |
Date |
Date |
Response |
String |
4 |
OKAY, NTFD – Meal Period Not FoundCLSD – Meal Period Closed |
Reservation ID |
Numeric |
9 |
The SilverWhere generated Reservation ID. A zero will be returned if the product is closed on the requested date. |
